2 SVS PB-12NSD vs 1 PB12 Plus - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-10-2012, 12:28 PM - Thread Starter
RyanJE's Avatar
Hello All,
What are your thoughts on Dual SVS PB-12NSD vs 1 PB12 Plus?
My room is about 3300^3 feet. I will be running these along a Paradimg Monitor Series 7 setup, Monitor 11s.
An Onkyo 709 amp that has 7.2 functionality with Audessy Multeq XT.
HELP!
RyanJE is offline
post #2 of 9 Old 08-10-2012, 12:53 PM
SaviorMachine's Avatar
Liked: 90
I think you're definitely better off with two NSDs, provided that you locate and calibrate them well. To my mind this means locating them equidistant to the MLP because you don't have any hardware to set different distances for your two subs.
There's an extension advantage that the Plus affords over the NSD, but I suspect (and the crew at SVSound have confirmed) that this extension advantage is easily outdone by the frequency response advantage of having two or more subs. Me, I'm about to add a second NSD to my own room; I was considering either a factory return-upgrade or repurposing my NSD to a different room, but the SVSound folks made a credible case that doubling up on NSDs would be a better move.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #3 of 9 Old 08-10-2012, 12:56 PM
eljaycanuck's Avatar
Quoted: 1225 Post(s)
Liked: 1794
Having enjoyed a BASH-equipped PB12-NSD in my ~3,250 cu.ft basement HT space, I think duals would provide terrific output in your ~3,300 cu.ft. room, as well as smoother FR than a single sub.
That being said, the PB12-Plus is more powerful and more flexible overall than the PB12-NSD. Either way (dual NSDs or a single Plus), you really can't lose.
eljaycanuck is offline
post #4 of 9 Old 08-10-2012, 01:24 PM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
ALWAYS go with dual identical subwoofers in any HT setup.
You'll get smoother bass response in your room.
Going with a single sub is always a bad idea.
I'am rocking with four subwoofers in my HT, two of which are SVS PB12-NSD's.
Audyssey, with MultEQ XT32 and Sub EQ HT, did a superb job in calibrating my subs.
After calibration, I sampled the train wreck scene, from the movie Super 8 on BD.
I fully expected, that all the windows in my place and my neighbors, would shatter at any moment! wink.gif
WARNING
SECURE ALL LOOSE ITEMS ON SHELVES IN YOUR HOUSE BEFORE THE TRAIN WRECK SCENE
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #5 of 9 Old 08-10-2012, 04:14 PM
Liked: 90
Hahaha. I came to AVSForum for the info, but I stayed for the passion.
post #6 of 9 Old 08-12-2012, 05:52 AM - Thread Starter
RyanJE's Avatar
Thanks everyone for the input!
So I guess my next question is, will Audessey Mult EQ XT handle the 2 subs properly with respect to EQ?
For what its worth, they will be placed the same listening distance from my main listening position. Also the will be symetrical across the front wall (if that makes any sense).
RyanJE is offline
post #7 of 9 Old 08-12-2012, 06:24 AM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
Xt? Not really. You will need a y adapter. But it will be fine. I could be wrong, but having the subs ~equidistant from lp if room is pretty much symmetrical by design and furniture might help best. But there are lots of other factors. If a receiver upgrade is in the cards look for one with Xt32, dual sub outputs and sub eq if possible.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #8 of 9 Old 08-12-2012, 10:40 AM - Thread Starter
RyanJE's Avatar
My receiver is 7.2 currently so it has two sub outs. What is the question on the XT though. Not sure I understand the XT?, part.
RyanJE is offline
post #9 of 9 Old 08-12-2012, 11:03 AM
gtpsuper24's Avatar
Liked: 99
Multi EQ XT32 with Sub EQ (Denon 4311, Onkyo 3009,5009) pings each subwoofer separately and sets delay, phase and level and then does a second sweep together after it sets them separate. XT does about the same but only calibrates the two subs as one it doesn't ping them separately. XT also doesn't have as many filters or resolution at XT32.
XT can still do a good job of eqing dual subs.
gtpsuper24 is offline
Onkyo , Onkyo Tx Nr709 , Amplifier Speaker , Audyssey
