Need expert advice to purchase new sub to match existing system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-12-2012, 05:14 PM - Thread Starter
jimmycrank's Avatar
So, I was searching this forum and came across my thread from 2 years ago. http://www.avsforum.com/t/1241948/need-help-with-sub-issue-cycling-power
The same issue has reared its head again after I got the sub repaired, so I'm looking to purchase a new sub and recommendations on what to buy. I'm replacing a JBL e250p Northridge Sub. Currently have the same Northridge E Series Towers, Center, and some for rears. Can anyone suggest a new sub to purchase that would go well with the existing system?
1) Budget... No more than 500.
2) Size requirements/limits. standard cube form factor for a 12" sub
3) Room dimensions: Good size open plan family room with high ceilings
4) Primary use: 80% TV/movie viewing, 20% Music
5) Listening habits. Like crisp bass for movie watching
6) Appearance: Black Box is fine
JC
jimmycrank is offline
post #2 of 11 Old 08-12-2012, 05:32 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
JC
check the deals found thread and check out the klipsch sub that can be had for a great price off and on.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 11 Old 08-12-2012, 07:12 PM
skally's Avatar
I would suggest the Epic Lendgend but with shipping it would cost $565.00 . So thats a little over you budget
THe best deal would be the Klipsch RW-12D right now at Newegg but that ends at midnight I believe
www.newegg.com/Product/Product.aspx?Item=N82E16882780078
skally is offline
post #4 of 11 Old 08-12-2012, 08:56 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
The Premier Accoustic PA-150 will fill your room with strong mid bass. It won't expend much pass 25hz, but for your budget it will do the trick. Watch for deals, I have seen this go for $299. I would make an offer at $300 and see what they counter with. I paid $350 for mine a few years back:
http://www.ebay.com/itm/Premier-Acoustic-PA-150-Subwoofer-15-1000-Watt-Sub-/140456860774#ht_1764wt_1413
Review:
http://www.data-bass.com/data?page=system&id=48
For mid bass this sub can hang with some subs that cost twice the price. It also has a nice finish.
ack_bk is online now
post #5 of 11 Old 08-12-2012, 09:48 PM
skally's Avatar
I would agree with ack_bk as the PA-150 is an excellent sub for the money. I will clarify the post hat Ack_bk made thou..... as its strength its between 30hz and beyound. I have an Outalw EX as it digs deep into the 18 to 30 range but when the 35 & abouve hits I can tell the PA-150 kicks in just as good and better on the upper end. I know it can be had for $380 shipped as thats what I paid for it but it may be cheaper as well. It has an excellent build and finish & yes it does weigh 80LBS's.
skally is offline
post #6 of 11 Old 08-15-2012, 10:04 PM - Thread Starter
jimmycrank's Avatar
Ok, I appreciate the input. I wish there was a way to listen in to these, although I'd probably not have a clue what to look for. I'll try and find some reviews pitting the PA-150 versus Klipsch RW-12D versus another JBL.
Thanks all...
JC
post #7 of 11 Old 08-15-2012, 11:53 PM
Archaea's Avatar
Quoted: 2863 Post(s)
Liked: 2441
No question in my mind the Klipsch RW-12D is the better value if you can catch the $300 sale price.
Another potential option - though largely unvetted around here is the Jamo Sub 650 from vanns.
http://www.vanns.com/shop/servlet/item/features/549645163/jamo-sub-650?s_c=site_search
Make sure and check out the classified section on this board. There are some great older model subs for sale currently.
Archaea is offline
post #8 of 11 Old 08-16-2012, 05:54 PM
mmbuckwa's Avatar
Quoted: 49 Post(s)
The Jamo sub 650 is on sale for $259 at wwstereo.com with promo code TECHB50 through this weekend if anyone is interested.
mmbuckwa is offline
post #9 of 11 Old 08-16-2012, 06:34 PM
BTTOG's Avatar
Thanks lot. I am thinking about this sub.
However, I am looking more feed back information about this one.
BTTOG is offline
post #10 of 11 Old 08-20-2012, 06:28 PM - Thread Starter
jimmycrank's Avatar
Thanks for all the help. I jumped on the newegg deal thinking I got a misprint deal at $300 for the RW-12D. Turns out everyone gets that deal! So instead of a good sub at a great price, looks like I'm getting a good sub at a good price.
Although what is up with the bronze speaker? Thank god it has a cover.
JC
post #11 of 11 Old 08-20-2012, 07:57 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
The gold speaker never made production status. Too expensive and not enough excursion.
butter and jelly please.
pukemon is offline
