Need help tuning my HT subwoofer. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-14-2012, 10:06 AM - Thread Starter
DERG's Avatar
Quoted: 36 Post(s)
My theater is in the basement & measures 14' wide x 26 deep & 8 feet high. All the walls have sound dampening materials inside the walls & on the theater walls inside. All 4 corners have ceiling to floor bass traps. Nothing rattles.
The sub is a Definitive Tech SuperCube Reference which is located in the front center of the room - aimed at the prime listening area as I can't place it in a corner. This sub features a 14" woofer with two 14" radiators in a sealed 17" cube that weighs a whopping 97 lbs. I've read plenty of blogs on sub setup but haven't been satisfied with the results. I thought I'd step through my setup & maybe pickup where I'm going wrong.
The surround receiver is a Marantz SR8002. I've never cared for the Audyssey feature so I've fallen back to using a Radio Shack audio meter. After setting the Marantz to subwoofer ON & speakers to SMALL, I adjust the sound level to a typical movie listening level (I don't play many CDs in here) , then balance all 7 speakers to 75db at the prime listening location. I then adjust the sub to about 81db as I like a bit more bass. Any lower & it sounds flat; any higher in db & it seems to boom.
So whats wrong, you might ask? It's hard to explain but I'd call it a lack of punch. Maybe that's just the way the sub is designed for audio accuracy. Maybe the room is too small.
I guess I'd start with my setup & got from there. Any ideas?
Marantz VP15s Projector, CIH Man-Cave Home Theater, Marantz SR 8002, Oppo BDP-103 Blu-ray Player, 6 - HSU HB-1 MK2 Front & Surrounds, 1 - HSU HC-1 MK2 Center, 2 - HSU VTF-15H Subwoofers
DERG is offline
