Bass improvement with in wall sub over just in-ceiling speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-14-2012, 02:57 PM - Thread Starter
InWall guy's Avatar
I am in the process of building a new house and am at the wiring point. I have very limited experience with in-ceiling speakers. More often than not they sound flat and lack bass. For stereo set-ups in two seperate rooms I am considering adding passive in wall subwoofers and found great deals on:
Sonance 8 inch in wall single subwoofers. I don't want to add an additional sub woofer amp for stereo-set-ups and these rooms.
Here are my questions..
With a 6 1/2 inch woofer in the ceiling speaker will adding the sub give me much better bass response?
Do I have to buy a back enclosure or could I just add two extra 2x4s to create an enclosure in the wall?
Is it worth the extra cost? I know this last question is a very subjective.
Here are the specs on the sub:
Specifications
Woofer
8" (203mm) long throw carbon fiber cone, dual voice coil, with a rubber surround
Frequency Response
35Hz - 250Hz
Power Handling
150 watts
Sensitivity
90dB (2.83V/1meter)
Crossover Frequency
150 Hz
Optional Enclosures
Optional wooden acoustic enclosures optimize bass performance and reduces sound spillover to adjacent rooms.
Dimensions (WxHxD)
9 7/8" x 15 15/16" x 3 7/8" (251mm x 405mm x 99mm)
Cut-Out Dimensions (WxH)
8 1/2" x 14 1/2" (216mm x 368mm)
Shipping Weight
13 lbs (5.8kg) each
InWall guy is offline
post #2 of 3 Old 08-14-2012, 03:33 PM
DanLW's Avatar
Liked: 37
Did a quick google search, and the woofer being asked about is the Sonace P800D.
http://www.sonance.com/products/speakers/detail/321
An 8" will be better, but what would be best is if you got the powered version. This way it takes the load off your receiever, and gives you more control over bass management. 150Hz is awfully high for a crossover, and the 6 1/2" drivers in the ceiling should easily be able to make it down to 80Hz, which is a much more ideal crossover setting. What you would do is tell your receiver that your ceiling speakers are "Small", and set the crossover to 80Hz. Then, simply feed the subwoofer the LFE signal from your receiver.
You would also want an external amp because if you do get the passive version, which is crossed over at 150Hz, you'll easily be able to tell that lower sounds such as deep male voices are coming from the subwoofer, not from the ceiling speakers. 80Hz is harder to localize.
As far as the enclosure is concerned, I would get their enclosure. Unless you can get the Thiele/Small parameters of the woofer, it would be difficult to DIY the correct size of enclosure. Putting the woofer into a proper enclosure will get you better output. Just putting in extra 2x4s won't work, because an enclosure needs to be braced and airtight, except for the port (if there is one).
Is it worth the cost? I didn't notice any prices on their page, so I can't comment. If it absolutely has to be inwall, I'm not familiar with competing inwall brands, so I can't offer alternatives. If you're willing to go with a box sub, then there are options. Your budget and size limits will be the biggest determining factor.
DanLW is offline
post #3 of 3 Old 08-15-2012, 06:46 AM
kwkshift's Avatar
For an inwall sub, this is the nicest "affordable" unit I've ever seen:
http://www.artisonusa.com/subwoofers/rcc-600-sm-in-wall/
kwkshift is offline
