Passive Subs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-15-2012, 12:37 PM - Thread Starter
Troyd's Avatar
Quoted: 66 Post(s)
Anyone know of a good 12" or 15" passive sub? I already have an amp, so i would like to take advantage of it. I see a lot on the pro audio side of things, but wonder how that would work out in a HT. Any suggestions?
Troyd is offline
post #2 of 4 Old 08-15-2012, 12:42 PM
qguy's Avatar
Quoted: 123 Post(s)
Liked: 91
Check out captivator, I think they have passive subs also check out the DIY section or diyaudio.com, there are drivers and enclosure manufacturers out there, you just need to mix an match
qguy is offline
post #3 of 4 Old 08-15-2012, 12:46 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
What amp do you have and what are you looking for in the sub? This for a 2 channel music system? Multi channel HT? What are the details of the room it's going in to?
From what I've seen of pro audio subs it's more about dj or performance of music and less about furniture than many home audio subs, but may not offer the lowest freqencies that you might want for LFE.
lovinthehd is offline
post #4 of 4 Old 08-15-2012, 03:44 PM
Hookedonc4's Avatar
Quoted: 26 Post(s)
We use a James powerpipe with a M1000 sub amp and EMB1000 all I can say is WOW!!!
Denon X4000, SC-91, VSX-51,VSX-81 Pioneer Elites and Denon 1611
James loudspeaker inwalls main and future theater
Control4
Other speaker zones DefTech, Polk, Russound, Boston Acoustics
Hookedonc4 is offline
