Too much subwoofer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-17-2012, 10:13 AM - Thread Starter
weekendtoy's Avatar
Quoted: 240 Post(s)
Liked: 177
I'm just curious if there is such a thing as having 'too much subwoofer'.
Based on my current speaker and room setup I'm ready to pull the trigger on a new SVS PC12-NSD.
However, within a couple hour drive I have a line on a gently used SVS PB12-ULTRA/2 that, whilst streching the buget a bit further, is not un-doable.
Now as you know this is a huge sub both in terms of weight and size, but evidenced by the proposed purchase of the PC12, the WAF is very low on this matter.
My question is, because the PC12 should more then meet my needs, is the SVS PB12-Ultra just overkill?
Is there such a thing as 'too much sub'.
Dan
PS. I'm using NHT towers, center, and (4) surrounds.
I reject your reality and substitute my own.
weekendtoy is offline
post #2 of 10 Old 08-17-2012, 10:19 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2988
No. No such thing as overkill since you'll integrate the sub into your setup. smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 10 Old 08-17-2012, 10:20 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Dan
No, Dorothy, there is no such thing as too much sub. I for one would find your choice totally lacking. I have no WAF to contend with, though.
lovinthehd is offline
post #4 of 10 Old 08-17-2012, 10:25 AM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
Dan
You can never have to much bass.
I would get dual SVS PC12-NSD subs, instead of a PB12 ULTRA 2.
There's no substitute for smooth bass response.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #5 of 10 Old 08-17-2012, 10:32 AM
Auditor55's Avatar
Dan
Yes. Don't break your budget for something you don't need.
Auditor55 is offline
post #6 of 10 Old 08-17-2012, 11:11 AM
SaviorMachine's Avatar
Liked: 90
I think it's too much sub when it damages your lifestyle. In reality, you already know whether it's too much (PB12 Ultra/2 is too much for you).
On the other hand, if the PC12-NSD meets your significant other's approval, it's possible that you may be free, some months from now, to add a second one. This would close some of the output gap between the two subs, and you might be able to make an easier case for it than you would for a huge box-type sub like the PB12-Ultra/2.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #7 of 10 Old 08-18-2012, 09:15 AM - Thread Starter
weekendtoy's Avatar
Quoted: 240 Post(s)
Liked: 177
Thanks for the replys folks. I decided to stick with the orginal plan and just placed my order for the PC12-NSD.
post #8 of 10 Old 08-18-2012, 01:18 PM
spiritfox's Avatar
My PC-13 Ultra is perfectly happy in my rather smallish 10x12 HT--might even enjoy the company of a mate. smile.gif
Bob
spiritfox is offline
post #9 of 10 Old 08-18-2012, 01:37 PM
av addiction's Avatar
av addiction is offline
post #10 of 10 Old 08-18-2012, 02:03 PM
pukemon's Avatar
Quoted: 275 Post(s)
Liked: 70
Originally Posted by av addiction View Post
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
