Upgrade driver and plate amp in an old sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-17-2012, 11:19 AM - Thread Starter
Tweaked05's Avatar
Quoted: 42 Post(s)
Liked: 26
I have an 18 year old JBL 10" 100w sub that in wholly inadequate for either music or movies. I recently had the idea of replacing just the driver and the plate amp and reusing the box. Would this be a good idea or a waste of money? If it's a good idea can you guys recommend a plate amp and driver for music only? My goal is excellent music reproduction.
Tweaked05 is offline
post #2 of 3 Old 08-17-2012, 11:34 AM
pukemon's Avatar
Quoted: 283 Post(s)
Liked: 71
Probably the money used for that would better be used towards the klipsch rw 12d on new egg.
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #3 of 3 Old 08-17-2012, 06:37 PM
Archaea's Avatar
Quoted: 3004 Post(s)
Liked: 2584
yes. boxes are custom built for specific sub parameters allowing for port tune, and proper mated frequency response. You'd likely end up with a worse sounding product if you randomly selected a budget sub driver and stuck it in your existing box.
If the box is sealed, your idea has merit, because sealed boxes are more forgiving than ported for mismatched driver parameters. If it's ported, put it by the curb, or let somebody on craigslist think they found a good deal on a box.
If you really want to play download winisd and hit the DIY forums and see if the guys can help you match a driver to that box.
Problem is you'll end up paying more for a plate amp and 10" driver for an underperforming product than you can buy in something like the aforementioned Klipsch RW-12D on newegg for $300 right now.
Archaea is online now
