VTF3 MK 2 and VTF15 work together? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-17-2012, 12:36 PM - Thread Starter
Richr 13's Avatar
Or do I just dump the MK3 when the VTF arrives?
Richr 13 is offline
post #2 of 2 Old 08-17-2012, 01:00 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
If you intend to place the VTF15 in a corner, you might try to use the VTF3 in a near-field position like you would with an MBM-12. If you can't do that, I wouldn't bother trying to use the VTF3 with a VTF15h, as you would have to push the VTF3 pretty hard just to keep up with the VTF15h if they are at the same distance from the listening position.
shadyJ is offline
Hsu Vtf 15h Subwoofer
