The best sub for ht/ tv for 2,000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-18-2012, 07:49 PM - Thread Starter
Sfniner's Avatar
For clean tight bass
Sfniner is offline
post #2 of 10 Old 08-18-2012, 07:59 PM
carp's Avatar
Quoted: 2495 Post(s)
Liked: 1757
Check this thread. I would spend a little more and get a submersives and then save up over time for a second one but that's me.
http://www.avsforum.com/t/1425179/the-subwoofer-recommendation-by-pricepoint-thread#post_22318553
carp is online now
post #3 of 10 Old 08-18-2012, 08:08 PM - Thread Starter
Sfniner's Avatar
I saw that but looking for other peoples opinions thanks.
Sfniner is offline
post #4 of 10 Old 08-18-2012, 08:37 PM
D.T.MIKE's Avatar
Clean and tight I say go for sealed either dual (CHT18.1) or one big boy (18.2) if duals are not an option. Either of these will give you the best of both worlds, home theater and music.
D.T.MIKE is offline
post #5 of 10 Old 08-18-2012, 08:52 PM - Thread Starter
Sfniner's Avatar
My budget max would be 2,000 but if I can spend less that would be great I have no clue what a 18.2 is
Sfniner is offline
post #6 of 10 Old 08-18-2012, 08:56 PM
av addiction's Avatar
Here you go https://www.chasehometheater.com/index.php?option=com_virtuemart&page=shop.browse&category_id=29&Itemid=53&TreeId=2&redirected=1&Itemid=103
And check out of "Sticky" Threads for the "Subwoofers, Bass, and Transducers" forum tons of info. you looking for.
av addiction is offline
post #7 of 10 Old 08-18-2012, 09:11 PM - Thread Starter
Sfniner's Avatar
Is a rythmic Fv15 hp a better sub than svs pb12 plus, pb13 ultra for the price
Sfniner is offline
post #8 of 10 Old 08-19-2012, 12:18 PM - Thread Starter
Sfniner's Avatar
Has anybody reviewed all three subs rythmic fv15hp, svs pb 12 plus and svs pb 13 ultra.
Sfniner is offline
post #9 of 10 Old 08-19-2012, 12:38 PM
SaviorMachine's Avatar
Liked: 90
Yes, Audioholics.com has. Also the Data-Bass.com site has reviews for the PB13-Ultra and the FV15HP.
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #10 of 10 Old 08-21-2012, 06:36 PM - Thread Starter
Sfniner's Avatar
I should be getting my svs pb13 on Thursday thanks for everything. I might be upgrading my speakers next.
Sfniner is offline
