sub in wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-19-2012, 06:14 AM - Thread Starter
sound64's Avatar
i have a JBL sub i am trying to find a home for in my new theater. i was thinking of placing it behind the wall and using a return duct grill to cover the hole in the wall. my concern is the port on the back of the sub will be buried and affect the sound, not to mention fill the closet with sound and travel through the exposed duct work in there. any advice?
sound64 is offline
post #2 of 5 Old 08-19-2012, 06:34 AM
ccotenj's Avatar
Liked: 101
imo, this is unlikely to work very well...
- chris
ccotenj is offline
post #3 of 5 Old 08-19-2012, 08:08 AM
guy80's Avatar
my understand of audio would be it needs to vent into the room, also placing a return grate would screw with the wave too much (assuming not a tiny sub?)
guy80 is offline
post #4 of 5 Old 08-19-2012, 08:14 AM - Thread Starter
sound64's Avatar
I read on Polk Audios web site they recommend grates to cover their in wall subs. I also had some concerns about how that would muddy the bass response. All my speakers are in wall, so i am really looking to hide the sub, but i do not want to kill the bass response.
Are there any in wall subs which are cheap and good? Anyone have experience with them?
sound64 is offline
post #5 of 5 Old 08-19-2012, 08:21 AM
pukemon's Avatar
Quoted: 281 Post(s)
Liked: 71
You could just build a hole in the wall that will give it plenty of airspace and not cover it up. Not exactly what you want but do you want bass still or do you want to spend a lot of money and do it right?
butter and jelly please.
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
