How to wire up IB sub setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-19-2012, 09:42 PM - Thread Starter
Silock's Avatar
So, I have a Yamaha A800 and a Behringer 2000w amp. Going to power up 4 AE IB15s. I know it's not optimal, but it's what I got. If this won't work, I might just go with 4 sealed 15s instead.
I'm assuming I just run the sub outs to the amp as normal, but how do I physically wire up the subs? What's the best configuration, and what kind of wire should I use to handle the power?
Thanks in advance.
Silock is offline
post #2 of 8 Old 08-21-2012, 04:47 PM - Thread Starter
Silock's Avatar
Anyone?
Silock is offline
post #3 of 8 Old 08-21-2012, 10:05 PM
Jesse S's Avatar
It depends on the impedance of each driver and if they are single or dual voice coil. Generally you want a 4 ohm final load so you can run the amp bridged. 2 ohm load is too low and 8ohm won't draw the full potential of the amp.
Jesse S is offline
post #4 of 8 Old 08-21-2012, 10:08 PM
RobertR's Avatar
Quoted: 494 Post(s)
Liked: 660
2 ohms is not too low with a Behringer if you run it in stereo mode. I've been running 8 drivers this way for several years, and it works fine.
RobertR is offline
post #5 of 8 Old 08-22-2012, 07:28 AM
desertdome's Avatar
Quoted: 1335 Post(s)
Liked: 1524
My IB15 drivers are 8 ohms but they can be ordered either 8 or 4 ohm. Which ones do you have? It should say on the sticker that is attached to the magnet.
High Impact AV
desertdome is online now
post #6 of 8 Old 08-22-2012, 11:21 AM - Thread Starter
Silock's Avatar
They are 8 ohms.
Silock is offline
post #7 of 8 Old 08-22-2012, 12:00 PM
desertdome's Avatar
Liked: 1524
You can use 14 gauge wire or thicker. Wire two of the drivers in parallel and connect to one channel of your amp. You do this by using a wire from + to + on each speaker and then a wire from + on the amp to + on one of the drivers. You can strip a section of the wire with a knife and put the wire through the binding post with the end going to + on the 2nd driver and the stripped part at + on the first driver with the beginning of the wire attached to + on the the first channel. Do the same with the - .
High Impact AV
post #8 of 8 Old 08-22-2012, 08:54 PM
Jesse S's Avatar
So do I but that is 2 ohm stereo. 2 ohm bridged mono is actually 1 ohm internally.
Jesse S is offline
