Subwoofer connection options to AVR: 'SUB OUT' vs 'Surround out' - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-23-2012, 06:42 PM - Thread Starter
megabyzus's Avatar
Is there an advantage/disadvantage connecting each of my two subwoofers to the TWO sub woofer outputs on the AVR vs connecting them to the L/R surround outputs?
I am new and not very technical but have tried to learn as much so any thoughts on this subject is greatly appreciated!
megabyzus is offline
post #2 of 9 Old 08-23-2012, 06:45 PM
Skylinestar's Avatar
Quoted: 1044 Post(s)
Liked: 182
Connecting the subs to the TWO sub woofer outputs on the AVR is the right thing to do (and with proper bass management). Why would you plug them to the surround outputs? rolleyes.gif
Skylinestar is offline
post #3 of 9 Old 08-23-2012, 06:46 PM
gtpsuper24's Avatar
Liked: 99
Sub out is for subwoofers, which means it passes the bass and low frequencies to the subwoofer. Surround out is for an external amp to power you surround speakers. Hook subwoofers to Sub out.
gtpsuper24 is offline
post #4 of 9 Old 08-23-2012, 08:05 PM - Thread Starter
megabyzus's Avatar
That's the question. Why not?
post #5 of 9 Old 08-23-2012, 08:07 PM - Thread Starter
megabyzus's Avatar
I don't understand and perhaps it is semantic, but I currently have speakers(not an external amp) connected to my surround outputs. So I don't understand your response.
post #6 of 9 Old 08-23-2012, 08:13 PM
gtpsuper24's Avatar
Liked: 99
What brand/model is your receiver? Does the subwoofer use RCA or does it use speaker wire? Surround speaker inputs for speaker wire is a direct connection to the receiver so it can power your surround sound speakers. You could also have RCA jack inputs to add an external amp and then you hook the speakers up to the external amp. A power subwoofer uses an RCA jack to connect to the RCA output on the receiver its usually colored purple.
post #7 of 9 Old 08-24-2012, 06:44 AM
ccotenj's Avatar
Liked: 101
because you will not be sending the sub channel to the sub...
stop and think a minute... what you are proposing doesn't make sense...
- chris
ccotenj is offline
post #8 of 9 Old 08-24-2012, 08:17 AM - Thread Starter
megabyzus's Avatar
The receiver's an Onkyo TX-NR616. The two subwoofers are POLK PSWi225 wireless subwoofer. I see the subwoofer has two types of inpouts: 1. Single Input (with 'LFE' printed below it) and An 2. L/R RCA input pair.
This is where my question comes from: Why the two types of inputs on the subwoofers and why can't I connect the L/R's to my 'regular' speaker outs on the back of my AVR?
post #9 of 9 Old 08-24-2012, 03:35 PM
Oliver Deplace's Avatar
Liked: 33
Your subs' LFE inputs likely bypass their on-board crossovers and are designed to use the low-passed feed from the AVR's bass management along with the band-limited LFE. The L/R RCA inputs likely invoke the subs' on-board crossovers. Read your sub's manual or contact Polk's support for confirmation of the correct course. I see you've now moved to selecting the "regular speaker outs", I don't know if that is referring to the front channels. If it is, then you could set the front speakers to LARGE with LFE and send their pre-outs to your subs. But, your subs will need a very steep low-pass filter (and/or a very low filter frequency) to keep the subs from muddying-up dialog. This is a very unusual connection scheme that isn't often seen (and is full of pitfalls), so it's difficult to recommend.
The pre-outs for the surround channels will not carry LFE (a tremendous loss for movies) and the surround channels are likely high-pass filtered, so you've now removed almost all the bass from the subwoofer feed.
This connection scheme is so wobbly that it boggles me.
I'm rather surprised to see your resistance to using the subwoofer outputs of your AVR.
The outputs carry the label "SUBWOOFER" for a reason, they are designed to be used with subwoofers.
Oliver Deplace is offline
