Center speaker on sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-03-2012, 12:18 PM - Thread Starter
drewsdad665's Avatar
I just moved into a new condo with very limited space and was thinking about putting my center on top of my sub just under my 60 inch Sharp. Any thoughts about sonic or audio issue? Thanks alot...
drewsdad665 is offline
post #2 of 3 Old 09-03-2012, 12:38 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Two thoughts:
1. The center of the front wall may or may not be a good spot for the sub. The only way to know is to try it out.
2. If the sub vibrates, and that vibration is transferred to the CC, it could have a sonic impact on the CC, or it could cause the CC to rattle against the sub.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #3 of 3 Old 09-03-2012, 12:45 PM
kong's Avatar
I have my Def Tech 3000 on top of the JTR S2 subwoofer. I am using 4 Mopads under the center channel as a buffer and a Great Gramma under the S2.. I have had NO issues with this setup. Also, I have my center/sub pulled away from the wall aligned up with the the mains...
http://www.avsforum.com/t/1075618/your-subwoofer-picture-thread/1950#post_22239641
Denon 2808CI
Emotiva XPA-2-Mains
Emotiva UPA-2-Bi-Amped-Center
Definitive Technology BP-7004 (Mains), CLR 3000(Center), BP 1.2x (Rear & Side Surrounds)
JTR Sealed Captivator S2, PE Titanic 1000 watt Sonotube
Panasonic PT-AE8000u Projector, Panasonic Blu-Ray Player BDT-500
Carada 88" Projector Screen
kong is offline
