LFE to RCA? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-03-2012, 07:55 PM - Thread Starter
tommygunz325's Avatar
So I'm moving to a home that has an LFE cable already ran for a surround system subwoofer and my subwoofer doesn't have an LFE plug. It would be nearly impossible to rerun the cable because it is installed in a finished basement with blown insulation for sound proofing. I'm not really familiar with the LFE function.
Am I able to just buy a RCA splitter to go from 1 to 2 to able to use my subwoofer? I've looked for a LFE to RCA conversion cable but haven't been able to find one. Any suggestions besides buying a new subwoofer or running a new cable?
tommygunz325 is offline
post #2 of 4 Old 09-03-2012, 08:45 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
What subwoofer do you have? That info would help tremendously.
Afro GT
afrogt is online now
post #3 of 4 Old 09-04-2012, 06:05 AM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
LFE is the "low-frequency effects" channel. The LFE channel plus all bass (frequencies below the crossover setting in the AVR) from your other speakers channels are output through the "Subwoofer" output (sometimes incorrectly labelled the "LFE" output) on your AVR.
Subwoofers often have inputs labelled "LFE" in addition to a set of L+R RCA inputs. If your sub has an "LFE" input, that's what you connect to. If it doesn't have an "LFE" input - which is the situation you face - you should be able to connect to either the L or R RCA input, or to both inputs (using a Y-splitter). The owner's manual for the subwoofer should tell you which method to use.
eljaycanuck is offline
post #4 of 4 Old 09-04-2012, 09:37 AM - Thread Starter
Thanks ElJay! As long as I can use the y splitter I should be good to go! I don't want to get into changing any equipment or lines just yet.
