Isolation pads useful? HSU VTF3 MK3 in apartment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-10-2012, 02:31 AM - Thread Starter
metallicaband's Avatar
Liked: 100
Hello all,
I'm going to move to a new apartment within this month, it's only a building of 2 flats (ground/1st floor) and I'll be living in the first floor, I was wondering if I could do something to minimize the subwoofer sound going through the walls a bit (bottom walls most importantly), but since my Sub isn't bottom firing, will an isolation pad be any helpful in my case?
Any ideas/suggestions about minimizing noise through walls for sub or even speakers from people who have experience with using sound systems in apartments would be great.
KRP-500M | Kuro 9G 5020FD + e-lite mod | B&W 683 Fronts | B&W 685 Center | B&W DM601 S3 Rears | HSU VTF3 MK3 Sub | Yamaha RX-V663 AVR
metallicaband is offline
post #2 of 6 Old 09-10-2012, 04:18 AM
SaviorMachine's Avatar
Liked: 91
I live in a second-floor apartment and I have a down-firing 12-inch sub in my living room HT. Some facts: my neighbors are seldom around, and the walls of my apartment building are really well-insulated; also, all my listening spaces are pretty small and I'm not a true basshead like a lot of the other guys who post here, so my system's typical output levels are pretty low compared to most other posters'.
I've used an Auralex SubDude for most of the last nine months. To my perception--I have taken no measurements to corroborate--it *does* reduce some of the room vibration. I had no random object shimmies to start with, but after installing it, I perceived a difference in visceral impact. There seemed to be a change in the relationship between the amount of bass I felt and the amount I heard; with the SubDude installed, I felt less and heard more.
Recently I removed it, and returned it to its box in a closet. All things considered, I prefer feeling more of the bass. As for owning a sub in an apartment, I think there's no one-size-fits-all rule; I'm lucky because my walls are thick and my neighbors aloof. Some apartment dwellers aren't so lucky. I think you need to pay attention to things like whether you can hear your own bass when you are in the hallway outside your front door, or what it sounds like outside one of your windows (better yet, of course, if you can hear what it sounds like when you are in the downstairs apartment--bake a pie and introduce yourself smile.gif )
Also, my HT receiver uses Audyssey Dynamic Volume, which narrows the dynamic range of program material. When it's enabled, speech and other finely detailed midrange sounds are clearly intelligible at any volume, and yet I don't have to dive for the remote just in time for the underwater nuclear explosion earthquake cannon barrage crescendo. You know, the one that always comes right after the long whispered conversation full of essential plot points. Purists object, and I get their point, but for my money, this feature is a godsend. Your Yamaha has a Dynamic Range Compression option that should function similarly; I think you should try it and see if it helps. Good luck!
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #3 of 6 Old 09-10-2012, 05:17 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
ShaQBlogs is offline
post #4 of 6 Old 09-10-2012, 07:19 AM
guy80's Avatar
those pads & brick walls is about your only hope
guy80 is offline
post #5 of 6 Old 09-10-2012, 10:26 AM
Spanglo's Avatar
Quoted: 493 Post(s)
Liked: 436
I put my subs on platforms and it lessened nearby rattling of furniture significantly - so they definitely work to some degree. As far as them reducing the sound transmitting to your neighbors... I'm sure it does help slightly, but I was hard pressed to tell the difference.
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
post #6 of 6 Old 09-18-2012, 01:55 PM - Thread Starter
Liked: 100
Sorry for the delayed response guys, I've been caught up with the moving stuff.
Thanks a lot for the tips SaviorMachine and everyone else!
I'll definitely look into the pads and I think this time around I'm going to pay a lot more attention to room acoustics in general to optimize my audio overall which is something that I've never really cared for when calibrating my sound system, but I think it's about time to step it up.
Good news (hopefully it's not a bad thing lol) is that my room will be exactly on top of the building's grarage parking space, so there won't be a room direclty under mine, the ground flat will be next to the garage so hopefully sound travel won't be as bad, unless those garages will cause an echo or something then I'll be ****ed lol
