Any very short, but potentially wide/long subs that can be placed under a coffee table? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-21-2012, 02:45 PM - Thread Starter
gustama's Avatar
New guy here who knows nothing.
Are there any quality subs that are designed to be placed underneath a coffee table? Obviously most of the subs discussed here are ones that are too tall to fit. I haven't measured it but I would imagine a height of 8 or 10 inches would probably fit.
gustama is offline
post #2 of 3 Old 09-21-2012, 03:34 PM
Kini62's Avatar
Quoted: 1507 Post(s)
Liked: 1370
That's not a lot of room. Is that the only place for the sub? If so check out the Paradigm Millenia sub. It's expensive but will fit and seems to perform pretty well. Check out HomeTheater.com and Sound and Vision.com for reviews.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 3 Old 09-22-2012, 01:24 PM - Thread Starter
gustama's Avatar
Thanks. Not sure yet what/where I will put a sub, but it just occurred to me that would be an inconspicuous place.
gustama is offline
