Any very short, but potentially wide/long subs that can be placed under a coffee table? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-21-2012, 02:46 PM - Thread Starter
gustama's Avatar
New guy here who knows nothing.
Are there any quality subs that are designed to be placed underneath a coffee table? Obviously most of the subs discussed here are ones that are too tall to fit. I haven't measured it but I would imagine a height of 8 or 10 inches would probably fit.
gustama is offline
post #2 of 11 Old 09-21-2012, 09:18 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
Can't think of any worthy candidates myself. What are your requirements? Why is that the only location? Sub performance can be very dependent on location in your room in any case. How about a cylinder sub if floor space is an issue? Some subs can do dual duty as a table, too...
lovinthehd is offline
post #3 of 11 Old 09-22-2012, 02:51 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Paradigm Reference MilleniaSub. Not a heavy hitter below 30hz, but seems to have decent bass on up. Here are some measurements.
But you might not like the price.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 11 Old 09-22-2012, 05:02 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
you can lay down a cylinder sub from svs horizontally i have the pc13u which is 42" tall and 16" wide. reverse those of course if using horizontal configureation. it is 1700.00 though.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #5 of 11 Old 09-22-2012, 09:57 AM
cel4145's Avatar
Liked: 3001
He's only got about 10" vertical height though. He'd need SVS to come out with a cylinder sub that has an 8" driver to fit in that space. If there was 16" of vertical room, then there are also 12" sealed subs that would probably fit in that space.
cel4145 is offline
post #6 of 11 Old 09-22-2012, 11:40 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
yeah, i didn't know what he was playing with height wise.
edit: oh look he says 8-10" my bad...
post #7 of 11 Old 09-22-2012, 11:50 AM
Audiophile2k's Avatar
Liked: 46
The Sunfire Subwoofers have some models that would work.
Audiophile2k is offline
post #8 of 11 Old 09-22-2012, 03:27 PM
vardo's Avatar
Quoted: 54 Post(s)
Liked: 146
This Pinnacle sub might do....worth a look IMO. It's pretty small, but can get into low 30 hz
range. (or so claimed)
http://www.amazon.com/Pinnacle-Speakers-SUBcompact-Powered-Subwoofer/dp/B0021AERB0
vardo
vardo is offline
post #9 of 11 Old 09-28-2012, 08:56 AM
kbuzz's Avatar
Quoted: 27 Post(s)
What about the TBI models?
kbuzz is offline
post #10 of 11 Old 10-04-2012, 09:25 PM
VBallerLefty's Avatar
This:
http://www.danleysoundlabs.com/products/subwoofers/tapped-horns/th-spud/
19hz @ -3dB
120 dB continuous
11" tall
Guaranteed to kick the ass of anything else that size. Not a dealer, just a Danley fanboy.
VBallerLefty is offline
post #11 of 11 Old 10-04-2012, 10:33 PM
lovinthehd's Avatar
Liked: 4780
Originally Posted by VBallerLefty View Post
This:
19hz @ -3dB
120 dB continuous
11" tall
Looks awesome but that'd be one big coffee table to fit underneath! What do those go for?
