JBL Venue Sub12 making odd sounds - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-26-2012, 08:35 PM - Thread Starter
Ace H's Avatar
I have a JBL Venue Sub12 subwoofer. Lately it's been making ODD sounds after it has been off for about 10 or 15 minutes. The sound is like a like a gurgling type sound with a brief rumble (not the good kind of rumble). Any idea what happening?
Ace H is offline
post #2 of 14 Old 09-27-2012, 08:01 AM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
Off, as in powered off, or off as in standby mode?
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3 of 14 Old 09-27-2012, 08:09 AM - Thread Starter
Ace H's Avatar
Off as in standby.
Ace H is offline
post #4 of 14 Old 09-27-2012, 08:27 AM
JimWilson's Avatar
Liked: 1560
Try disconnecting the RCA cable from your receiver. There may be some type of interference, and if so you'll need to isolate the source.
post #5 of 14 Old 09-27-2012, 12:43 PM - Thread Starter
Ace H's Avatar
The sub has been in the same place for over 3 years. Just yesterday, 9/26/2012, installed a better, thicker cable but it still makes that odd sound after being on standby 10 or 15 minutes.
Ace H is offline
post #6 of 14 Old 09-27-2012, 01:24 PM
JimWilson's Avatar
Liked: 1560
But does it make the same sound without a cable connected?
post #7 of 14 Old 09-27-2012, 03:01 PM - Thread Starter
Ace H's Avatar
I'll have to give that a try later this evening.
Ace H is offline
post #8 of 14 Old 09-28-2012, 07:07 AM - Thread Starter
Ace H's Avatar
It does not make that sound when I disconnect the cable, but about 30 minutes after I reconnect the cable it does make the sound.
Ace H is offline
post #9 of 14 Old 09-28-2012, 08:48 AM
JimWilson's Avatar
Liked: 1560
Do you have cable TV?
post #10 of 14 Old 09-28-2012, 11:38 AM - Thread Starter
Ace H's Avatar
Yes, Cox Communicaions is my cable provider.
Ace H is offline
post #11 of 14 Old 09-28-2012, 12:35 PM
JimWilson's Avatar
Liked: 1560
You may have a ground loop issue. Although historically the noise associated to that is pretty consistent, it might not be a bad idea to consider using an isolator on your cable line. Another thing you may want to try is an electrical adapter to remove the ground path on your subwoofer.
post #12 of 14 Old 09-29-2012, 09:08 PM - Thread Starter
Ace H's Avatar
Thanks. I'll have to look into that.
Ace H is offline
post #13 of 14 Old 12-01-2014, 10:18 AM
Liked: 0
I am also having this issue
I also have a Venue Sub12 with these symptoms. Purchased in 2008, started making these sounds in 2014. To me, it sounds like a power discharge through the woofer after the unit has entered standby mode. The clicking at the very end sounds like the relay that controls the power amp. Right now I'm trying to research more details to make a decision between repair and replace. When the unit is on, it still sounds great. I don't think it is a ground loop issue or a bad RCA cable, and all my components including the receiver haven't changed since the initial setup in 2008.
Ryan McNair is offline
post #14 of 14 Old 01-05-2015, 05:19 PM
ickysticky74's Avatar
I have a venue 12 sub. It makes a hiss sound when powered up and when the bass kicks in it makes a loud muffle sound. Would this be the board or the sub woofer. Any help would be greatly appreciated.
ickysticky74 is offline
