Subwoofer upgrade question...Please help... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-06-2012, 07:29 AM - Thread Starter
allen9917's Avatar
This is for a room about 19'x17'x9'. My current system is Polk RTi A5/CSi 3/FXi A4 with Mirage Omni S8 for a 5.1 setup. The receiver is Onkyo NR608. It is 50/50 for music and movie/TV.
I'd like to upgrade the sub for a more powerful one and move the mirage to bedroom. My budget is around $300 or a bit higher than that. Currently I'm debating between Klipsch RW-12d (onsale at newegg for $280) and Jamo SUB 650 (under $300 at Vanns). For all you gurus please give some advice on which one is a better sub or better fit for my system and my needs? I usually do not play things very loud or want to literally shake the house.
Appreciate any input!
allen9917 is offline
post #2 of 2 Old 10-06-2012, 11:17 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
lovinthehd is offline
