noob TRUE/FALSE question about sub 20Hz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-06-2012, 08:41 AM - Thread Starter
prefetch's Avatar
TRUE or FALSE: my new NAD T 777 will clip anything below 20Hz, so my expensive subwoofer will not produce < 20Hz audio when attached to the NAD.
so you don't have to look it up, this is the data on the NAD T 777:
Amplifier Section Frequency Response ±0.8dB (ref. 1kHz, 20Hz-20kHz)
Preamplifier Section Frequency Response ±0.5dB (ref. 20Hz-20kHz)
very much appreciate answers to my naive question.
prefetch is offline
post #2 of 16 Old 10-06-2012, 09:04 AM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
False. Look up the specs for any AVR, amp, or preamp and you're likely to see the same "20 - 20 KHz" range. That's the standard range used when measuring distortion figures or the flatness of the response curve, eg. +/- 0.8 dB. Your receiver will send the sub all the low frequencies that are encoded on the disc, so no worries...
henrich3 is offline
post #3 of 16 Old 10-06-2012, 09:10 AM - Thread Starter
prefetch's Avatar
ah. okay, so the spec sheet is just saying that within a certain range of dB it won't send < 20Hz, but it will send signal < 20Hz.
that makes sense. thank you!
prefetch is offline
post #4 of 16 Old 10-06-2012, 09:21 AM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
The preamp may be just as flat down to 10 Hz, but one can't tell from the manufacturer's specs. It's probably very good however.
henrich3 is offline
post #5 of 16 Old 10-06-2012, 02:13 PM
eljaycanuck's Avatar
Quoted: 1233 Post(s)
Liked: 1804
IIRC, the "20Hz-20KHz" spec deals only with the speaker channels, and has nothing to do with the LFE channel (0-120Hz) or the Subwoofer output.
eljaycanuck is offline
post #6 of 16 Old 10-07-2012, 02:50 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
The spec does not say how the device performs above 20KHz or below 20 Hz. So you cannot, by definition, tell from the spec what power the device will make at any given frequency below 20 Hz or above 20KHz before "clipping," however one defines it (is it one percent distortion" a tenth of a percent" ten percent?) You'd need to see testing at whatever frequency you think is relevant to know the answer.
Car analogies are awvul, but a spec of 0 to 60 Mph in 6 seconds does not mean a car won't go faster than 60.
JHAz is online now
post #7 of 16 Old 10-07-2012, 08:17 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
As others have said, you can't tell anything about the response below 20 Hz from those spec's. However, there is another way to "know" the response below 20 Hz. Your receiver is Dolby TrueHD and DTS-MA capable. The spec's for those formats REQUIRE response to 3 Hz from the subwoofer output. So you can rest assured that your receiver will definitely not "clip anything below 20 Hz." It will definitely send sub-20 Hz content to the subwoofer.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #8 of 16 Old 10-07-2012, 08:30 AM
SaviorMachine's Avatar
Liked: 90
Once again, I am sorry to take a sledgehammer to so small and fragile a nut. -- Richard Dawkins, The Greatest Show On Earth
SaviorMachine is offline
post #9 of 16 Old 10-07-2012, 01:50 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Craig
This. I didn't focus on the fact the questio relates to the sub out, not the receiver's amp performance.
To the OP "clip" in the amplifier context means "distort" not "roll off" as I think you may have had in mind, and as you move along in your audio learning curve using the terms the way folks in the business use them will make it much easier to communicate.
JHAz is online now
post #10 of 16 Old 10-08-2012, 07:47 AM
Steveo1234's Avatar
Liked: 37
Craig
Got a source for that? Id love to read more about it.
Steveo1234 is offline
post #11 of 16 Old 10-08-2012, 01:03 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
From Dolby's "5.1 Channel Production Guidelines:
5.1-channel audio typically consists of five discrete, full range main channels (Left,
Center, Right, Left Surround, and Right Surround) plus an optional band-limited Low
Frequency Effects (LFE) channel for added bass (the .1). Dolby Digital bitstreams
deliver full frequency bandwidth main channels, from 3 Hz to 20 kHz, and a limited
frequency bandwidth LFE channel, from 3 Hz to 120 Hz
Dolby 51 productions guidelines.pdf 487k .pdf file
Or, do a Google search for "Dolby Full Range Channel 3 Hz." You find many references.
Craig
Lombardi said it:
My System
post #12 of 16 Old 10-08-2012, 03:19 PM
desertdome's Avatar
Quoted: 1122 Post(s)
Liked: 1226
Craig
According to this webpage at Genelic's website, the LFE channel for both Dolby-HD and DTS-HD is full bandwidth and there is no upper cutoff specification. Now those that want to reproduce the LFE channel as intended need a speaker to go with their subwoofer. biggrin.gif I have the Red Cliff Blu-ray and the DTS-HD LFE channel has content up to about 400 Hz.
High Impact AV
desertdome is offline
post #13 of 16 Old 10-08-2012, 04:30 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Craig
Interesting note about DTS-HD. There is a steep (60 dB per octave) 100 Hz (-3 dB) high pass filter applied in a DTS DECODER.
Table Note (1): in all DTS ‘Coherent Acoustic’ codec the LFE channel is band limited at the encoding stage at 120 Hz. In the DTS-HD codec only [DTS-HD Master Audio™ (lossless) and DTS-HD High Resolution Audio™ (lossy)] the DTS-HD decoder applies a low-pass filter at 100 Hz (-3 dB) with a 60 dB/octave roll-off onto the LFE channel.
J_Palmer_Cass is offline
post #14 of 16 Old 10-08-2012, 04:33 PM
Quoted: 393 Post(s)
Liked: 118
Craig
Even the standard CD / CD player spec reads the same way. There is a 3 Hz capability spec for the low end.
post #15 of 16 Old 10-08-2012, 04:38 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
No, you don't want to add a speaker to the LFE channel for the LFE Channel of Dolby TrueHD and DTS-MA. These *are* full range channels, but the LPF of LFE blocks all content above the set point, usually set at 120 Hz. That's exactly what the LPF of LFE id for.
Craig
Lombardi said it:
My System
post #16 of 16 Old 10-08-2012, 05:05 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Originally Posted by J_Palmer_Cass View Post
Interesting note about DTS-HD. There is a steep (60 dB per octave) 100 Hz (-3 dB) high low pass filter applied in a DTS DECODER.
There I fixed it for you.
Lombardi said it:
My System
