Can I add a sub to a crossoverless amp and keep freq response even? - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2012, 07:29 AM - Thread Starter
flargosa's Avatar
My amp has no crossover adjustment. It is basically a stereo amp(Nad C356BEE). Is adding a sub even an option?, or would it just bloat some bass freq due to bass overlap?
flargosa is offline
Old 10-07-2012, 07:41 AM
eljaycanuck's Avatar
Quoted: 1235 Post(s)
Liked: 1808
Adding a sub is an option, and you'd use the crossover control (as well as the phase and gain controls) on the back of the sub to blend it with the mains.
Get a sub with speaker-level connections and run speaker wires:
- from the L+R main speaker terminals on your receiver to the speaker-level inputs on the sub; and
- from the speaker-level outputs on the sub to your L+R speakers.
eljaycanuck is offline
Old 10-07-2012, 08:12 AM - Thread Starter
flargosa's Avatar
Got it, thanks!
flargosa is offline
