Energy S10.3 Subwoofer Auto Power Mode Problem - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2012, 10:36 AM - Thread Starter
kars85's Avatar
I just got my Energy S10.3 Subwoofer from Newegg earlier this week. I have it hooked up via the subwoofer out on my Denon 1613 in which I've run the Audyssey setup with the mic positions as such:
............................. FRONT
_______.______4_____________5_______.______
llll....................l......................l....................llll
llll........ 3 .......-l.......... 1 .......-l........ 2 .......-llll
llll______.______l_______.______l______.______llll
lllllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllllll
\lllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllll-lllllllllllllllllllllllllllllllllll/
................................. 6
.............................. BACK
I absolutely cannot get the Auto power mode to work consistently, so to avoid having to get up and manually flip to to "On", I just leave it there for the majority of the time until I feel like trying Auto again. From what little documented cases there are on this issue online, a few conclusions have been drawn: an internal wiring problem with the amp or send it back under warranty with shipping on my dime.
At an estimated $40 to return ship it back, I don't think that investing 20% of the original cost is worth it without further troubleshooting first.
Can anyone give any insight as to what things I can do to work this out or is better I just suck it up and go through Newegg's warranty?
Karson
Denon X6200W | Klipsch RP-450CA Center | Klipsch RP-280FA Towers | Klipsch RP-140SA Atmos Heights | Klipsch RP-240S Surrounds | 2 x SVS PB2000 | Epson 2040 | Oppo BDP-103
kars85 is offline
Old 10-07-2012, 12:16 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
FYI, you should be running Audyssey in the following positions:
4 -- 5 -- 6
3 -- 1 -- 2
Re. your sub's auto-on function, it's possible that it's not consistently receiving enough signal from your AVR to trigger it. According to your AVR's speaker set-up menu, what level has Audyssey set the subwoofer to?
eljaycanuck is offline
Old 10-11-2012, 04:54 PM
grpape's Avatar
4 -- 5 -- 6
3 -- 1 -- 2
This. See what Audyssey set your sub at and raise it if needed. You can always run Audyssey again to see if that helps out your problem.
grpape is offline
