Y Adaptor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-07-2012, 11:43 AM - Thread Starter
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
Hi,
Do you use the Y Adaptor to connect from your subwoofer to your receiver? Does the Y Adaptor improve the sound quality of the subwoofer.
I have a Y Adaptor but not sure if I should use it. I would use it to connect the back of the subwoofer (L/R). Right now, I am only using the "L" to connect the cable.
Please click on the image to enlarge:
Thanks for any advice!
mantaraydesign is offline
post #2 of 8 Old 10-07-2012, 12:09 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1802
If your subwoofer has a dedicated LFE input, run a single RCA-to-RCA connection from your AVR's subwoofer output to the LFE input on your sub.
If your subwoofer doesn't have a dedicated LFE input, you can usually connect to:
- the L or R input on your sub;
or, using a Y-splitter,
- to both inputs.
The owner's manual for your sub will indicate the preferred (or permitted) connection options.
eljaycanuck is offline
post #3 of 8 Old 10-07-2012, 12:27 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
- to both inputs.
Very good and thanks!
The owner's manual only recommend using the L but was wondering if the sound would improve with the Y Adaptor.
post #4 of 8 Old 10-07-2012, 12:39 PM
Liked: 1802
Ooops, I missed that question in your initial post! redface.gif My answer to it is: The adaptor should not have any effect on the quality of the sound.
post #5 of 8 Old 10-07-2012, 12:42 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
According to Rythmik you will get an improvement of a couple of db (?) if you use a Y-adaptor.
Jeff
pronghorn/az is offline
post #6 of 8 Old 10-07-2012, 02:41 PM - Thread Starter
Quoted: 133 Post(s)
Liked: 33
@ eljaycanuck,
Not a problem but you provided a lot great information. Thanks!
@ pronghorn/az,
I will give it a try to see any improvement. Thanks!
post #7 of 8 Old 10-07-2012, 04:01 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
Jeff
Jeff-this is really just the same as turning up the gain knob on the sub or bumping up the trim level in your AVR.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #8 of 8 Old 10-09-2012, 09:31 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
The only improvement you will get with a Y connector is when you are using the auto-on function. The slight increase in input gain will help the sub kick in sooner with out raising the sub output trim level of your AVR.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
