Subwoofer on carpet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-09-2012, 02:08 PM - Thread Starter
Ninjabiker's Avatar
Hi, I just got a Polk PSW505 and I was wondering if it can be put directly on carpet? I noticed when I did that the bottom of the grille was touching/maybe sinking into the carpet.
Feeling like a noob,
-Ninjabiker
Ninjabiker is offline
post #2 of 3 Old 10-09-2012, 02:17 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
If the slot port at the back of the sub isn't being blocked, there's no problem. But if you're still worried about it, cut a piece of wood to the width x depth dimensions of the sub, put the wood on the carpet and sit the sub on top of the wood.
eljaycanuck is offline
post #3 of 3 Old 10-09-2012, 02:29 PM - Thread Starter
Ninjabiker's Avatar
Thank you kindly! It definitely isn't blocking anything.
