Upgrade from Bic H-100 to Klipsch RW12D? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-09-2012, 03:14 PM - Thread Starter
Derko's Avatar
I'm wondering if this would be a considerable upgrade? I have been contemplating getting a new sub, but wanted to get something in the $500-$700 bracket. I've been looking around and it seems that a lot of comparisons are made of the RW12D against much more expensive subs. Would this be a considerable upgrade from what I currently have?
My usage is mainly games/movies 75%, music about 20% and CableTV only around 5%.
Derko is offline
post #2 of 11 Old 10-09-2012, 03:50 PM
spyboy's Avatar
Liked: 47
I could be wrong, but I seem to remember seeing the Klipsch RW-12 D for as low as $280. At that price (or even at $300), dual RW-12 D would be a huge upgrade, within your budget smile.gif
Archaea likes this.
spyboy is offline
post #3 of 11 Old 10-10-2012, 07:37 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 186
The BIC pl-200 is an even better upgrade for the same price.
Lumenlab "Community driven video lab".
blake18 is offline
post #4 of 11 Old 10-10-2012, 07:55 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
at that price point why not try a ID such as svs pb12? would be a HUGE upgrade
Brian Fineberg is offline
post #5 of 11 Old 10-10-2012, 06:04 PM - Thread Starter
Derko's Avatar
Well actually the SVS is exactly what I wanted to get originally... so do you guys suggest I continue saving and pass up the Klipsch? Doing a dual set up is totally out of the question. The room is too small and I would not have a proper spot for the second sub. Plus the WAF would not work... tongue.gif
Derko is offline
post #6 of 11 Old 10-10-2012, 06:27 PM
capricorn kid's Avatar
Liked: 25
If you are looking to get just one sub, I would get the SVS. I have two Klipsch RW12d subs and they are great for my use. In the $500 to $700 range, there are many better subs you can look at. HSU, Outlaw, Epik etc. If your room is really small you might look at the Epik Legend.
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
Velodyne SMS-1
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #7 of 11 Old 10-10-2012, 06:57 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 186
My vote still goes to the Bic pl-200, it is a massively underrated performer.
blake18 is offline
post #8 of 11 Old 10-11-2012, 06:29 AM
kesando's Avatar
Liked: 31
The Pl200 is a great sub for the money but I'm sure many would agree that the Klipsch is an overall better performer and value when priced at $300 or less. The BIC is more comparable to the Lava LSP12
kesando is offline
post #9 of 11 Old 10-11-2012, 04:48 PM
grpape's Avatar
I went from dual H100s (very similar to the pl200) to dual Klipsch 12ds. The biggest difference is the sound. The Klipsch subs are so much tighter sounding. Yes the Bic will give you bass, but it is VERY boomy sounding. I am much happier with the Klipsch subs. As others have said, in the price range you're in, you should look at the other options (SVS,HSU,etc.). The only reason I went with the Klipsch subs; shipping was gonna be crazy and SVS wouldn't even ship to me.
grpape is offline
post #10 of 11 Old 10-12-2012, 07:20 AM - Thread Starter
Derko's Avatar
Thanks guys... my main thought pattern was that if I could get something like the Klipsch that would be worth the price of a much more expensive sub, that I could save some cash. But I'll just continue to shoot for the higher priced ones. I'll look into the others mentioned too.
Derko is offline
post #11 of 11 Old 10-12-2012, 07:45 PM
wichitadisciple's Avatar
You could always look for a used SVS.... a PB or PC-12 can normally be had for under $500. If you can find one with a warranty still valid, you'll be set.
wichitadisciple is offline
Klipsch Rw 12d 12 Subwoofer Each
