Smaller Subwoofer Advice - Help me choose - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-18-2012, 03:02 PM - Thread Starter
mab207's Avatar
Hi,
I am somewhat new to home audio systems but have done some research and narrowed down my results for a smaller subwoofer. Space is limited and I am trying to keep the width under 12". I live in a town house so I share a wall with my neighbor and do not care for wall-shaking/floor-thumping bass. I'm just looking for clear and controlled sound as most of my listening will be for music. I would like to spend around $250.
Here's what I've come up with...
Outlaw Audio M8 http://www.amazon.com/Outlaw-Audio-M8-Subwoofer/dp/B005SRS7XC/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1U74JNW57QD6F&coliid=ILJBKBA0O4JVC
Energy ESW-C8 http://www.amazon.com/Energy-ESW-C8-8-Inch-Subwoofer-Black/dp/B0021L9BMO/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1U74JNW57QD6F&coliid=I29VGULSIGUKDY
Mirage Omni S-8 http://www.amazon.com/Mirage-Omni-S8-8-Inch-High-Performance-Subwoofer/dp/B000F97FRM/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1U74JNW57QD6F&coliid=I3CGZI1BEUAFF4
Energy ESW-M8 http://www.amazon.com/Energy-ESW-M8-NA-1200-Watt-Subwoofer/dp/B004TA8YNW/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1U74JNW57QD6F&coliid=I3GZ1OC49MEFEK
Any advice on which to choose or even other sub recommendations is greatly appreciated! Thanks.
mab207 is offline
post #2 of 8 Old 10-18-2012, 08:22 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Look for the Energy 10.3 on sale but don't know if the 14" width will work for you. Outlaw maybe otherwise IMHO. I have an Energy ESW8 while okay for a small room, rather have something better (it's the least of my 5 subs).
lovinthehd is offline
post #3 of 8 Old 10-19-2012, 09:28 AM - Thread Starter
mab207's Avatar
Thanks for your response. I will consider the Energy 10.3 however I'd like to keep it under 12" wide due to furniture constraints. Any other opinions out there?
mab207 is offline
post #4 of 8 Old 10-19-2012, 09:51 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
get a Dayton 1200. very solid.
caloyzki is offline
post #5 of 8 Old 10-19-2012, 10:09 AM - Thread Starter
mab207's Avatar
Thanks but I'm looking for something smaller (under 12" total width)...the Dayton 1200 is 16" wide.
mab207 is offline
post #6 of 8 Old 10-19-2012, 09:59 PM
lovinthehd's Avatar
Liked: 4775
There are some nice smaller subs like Sunfires but they're out of your budget unless perhaps you look used. Maybe used DefTec Supercubes or others....
Also consider that just because a sub is larger doesn't mean it will cause your neighbor any less grief than a smaller one. Smaller subs usually just don't perform as well. WAF/budget isn't always the best way to determine the best sub for one's needs....
post #7 of 8 Old 10-19-2012, 11:40 PM
marvelousmarvyd's Avatar
You might want want to look at the goldenear forcefield sub:
http://www.goldenear.com/products/forcefield-subwoofers
marvelousmarvyd is offline
post #8 of 8 Old 10-20-2012, 09:32 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
vardo is offline
