wow a 155 pounds!!!!!!! - AVS Forum | Home Theater Discussions And Reviews
Old 10-22-2012, 10:15 PM - Thread Starter
keyboardcat's Avatar
keyboardcat is offline
Old 10-25-2012, 10:41 PM - Thread Starter
do any of you own that subwoofer? if so do you like it?
Old 10-26-2012, 06:51 AM
Bill Fitzmaurice's Avatar
Liked: 4692
1000 watts and 155 pounds may seem impressive, but what matters is Hz and dBs. In those respects the SVS is better than your average $500 sub, but nothing extraordinary.
Bill Fitzmaurice is online now
Old 10-26-2012, 07:06 AM
lwj81's Avatar
http://www.avsforum.com/t/889659/official-svs-ultra-13-thread
lwj81 is offline
Old 10-26-2012, 07:41 AM
BeeMan458's Avatar
Liked: 813
How does a 3,500 cuft, with a 12' cathedral ceiling that opens into an entryway and kitchen area, (entryway/kitchen cubic footage not included in the living room figures) do with just one SVS, PB13-Ultra? At this time, our budget (my wife) won't accommodate two and personally, I'm a buy once and fer-tet-about-it type of guy. When I buy, I want to close this issue out and move onto other toys.
Would the PB13-Ultra blend with two smaller, older, grossly inferior, 12" subs?
Currently, I'm entertaining the purchase of two SVS, PB12-NSD's to later, be married to a Hsu, ULS-15.
As an alternative choice, I'm looking at adding a Hsu, ULS-15 to be married up to our existing Klipsch, SW12-II subs that are some eighteen years old and later upgrading to SVS, PB12-NSD's. The video skews my thinking to buying one SVS, PB13-ULD which will be married to our existing Klipsch subs and budget wise, will have to consider it a day. I'll even consider an Emotiva, XPA-5. coupled to addition of a pair of Klipsch, 12D-RW hooked up in stereo mode to the mains with a SVS, PB13-Ultra on the side. Originally, the overall amplifier/subwoofer upgrade budget was $2,400.00 and in my above, I see the budget being upped to $3,500.00 so due to the possible increase in budget, that's why I'm making that my budget limit for bass and amplifier improvements.
I'm pretty much sold on Emotiva amplifiers and for various reasons, Klipsch, SVS and Hsu as to sub manufacture choices. Can anybody add suggestions that work with my above?
BeeMan458 is offline
Old 10-26-2012, 08:31 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Save the few extra bucks and get a Seaton Submersive and be done with it biggrin.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 10-26-2012, 08:34 AM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
mdf is cheap, 13'' driver is weak... at that price i would expect a 18''
Rmb1080p likes this.
cookieattk is offline
Old 10-26-2012, 08:42 AM
BeeMan458's Avatar
Liked: 813
How will one killer sub blend in a 3,500 cuft room with two lesser subs? I can budget for one killer sub and I understand, two subs are better than one.
Old 10-26-2012, 08:46 AM
Rmb1080p's Avatar
At that price you can almost get a JTR Captivator 2400.... which will eat an Ultra13!!!
Happy to be here
Rmb1080p is offline
Old 10-26-2012, 09:17 AM
BeeMan458's Avatar
Liked: 813
Thanks for the Captivator suggestion but considering I've increased my budget by 46%, I'm locking my budget increase down.
Any insight as to how a single large subwoofer would do in the room described, when coupled with the subs described? My choices are limited as I described so I'm asking for suggestions that work within the posted budget and combination constraints described.
Old 10-26-2012, 09:22 AM
Rmb1080p's Avatar
How much was the budget? 2400$ or 3500$?
Happy to be here
Rmb1080p is offline
Old 10-26-2012, 09:45 AM
flickhtguru's Avatar
Liked: 110
I wouldn't suggest it. Because in a properly calibrated system the better sub will be held back by the limitations of the cheaper smaller less powerful sub. I would highly recommend dual identical subs for your situation. Or get a good capable sub and place it in a front corner where the bass will be reenforced and then get the Mid Bass Module from HSU and place that either next to or behind the seating postion.
But what is your actual budget???
Shawn
flickhtguru is offline
Old 10-26-2012, 10:00 AM
BeeMan458's Avatar
Liked: 813
$2,400.00 and I've increased it to $3,500.00 which allows for a killer sub with two smaller Klipsch subs hooked up in stereo and an Emotiva Amp.
The alternative is a medium killer Amp, two smaller killer subs and an Emotiva Amp.
Old 10-26-2012, 10:09 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Get a Submersive or Cap.
bsoko2 is offline
Old 10-26-2012, 10:11 AM
BeeMan458's Avatar
Liked: 813
$2,600.00 for subs. Our room furniture placement and budget won't accommodate a pair of SVS, PB13-Ultra's.
Room placement of the sub/subs is being limited by room aesthetics and to a certain extent, WAF; compromise. And if two smaller subs will hold back one killer sub, I'm limited to the two smaller subs as my focused is on both the 20Hz and the 60Hz - 120Hz area of the frequency response graphs. And placement is limited by the room as I've pushed the WAF with what I currently have. At this time and point, I'm seeing if I can find a compromise between the wife killing me in my sleep and getting the desired impact bass for home theater reproduction.
Based on your above, trying to marry a SVS, PB13-Ultra up with our current pair of subs is a no go. Our mains are older versions of today's Klipsch, RF7-II's so we're not in need of Mid Bass Modules from Hsu as we're good to 35Hz. No disrespect intended towards SVS, I don't see the SVS, PB12-Plus as a worthy upgrade over the PB12-NSD. And all the graphs and waterfall charts point me in the direction of SVS or Hsu as the main subwoofer show. Your comments steer me to a pair of Hsu, VTF-15H in Rosenut finish and even that may be limited out by their physical size not fitting into our room. To make them fit, I'd have to buy a new (shorter) entertainment credenza, or smaller great chairs that flank the main/subs, which would have the affect of increasing the subwoofer budget.
Currently I'm trying to find out if one killer sub can be married up with a pair of smaller subs and so far, the sad answer is no.
(Boo, hoo, hoo; inconsolably he weeps, openly showing his manly, man frustration. tongue.gif)
club968 likes this.
Old 10-26-2012, 10:29 AM
spyboy's Avatar
Liked: 47
$2,600.00 for subs.
Room placement is being limited by room aesthetics. And if two smaller subs will hold back one killer sub, I'm limited to the two smaller subs as my focused is on both the 20Hz and the 60Hz - 120Hz area of the frequency response graphs. And placement is limited by the room as I've pushed the WAF with what I currently have. At this time and point, I'm seeing if I can find a compromise between the wife killing me in my sleep and getting the desired impact bass for home theater reproduction.
Dude, I attended the recent get-together hosted by Andrew (Gorilla83), and I have to tell you that bsoko2, Mike Duke, and other members who have recommended the Seaton Submersive know what they are talking about. I listened to the Submersive at the get-together and you can't go wrong with it. The Captivator is also very fine. Either the Submersive or the Captivator would be great smile.gif
spyboy is offline
Old 10-26-2012, 10:41 AM
BeeMan458's Avatar
Liked: 813
I'm not challenging anybody's credentials. I am budget limited. And room aesthetics are limiting our choice (size) as I'm up against replacing furniture to make larger subs fit. Are the Submersives/Captivators fine in solo or are they only fine in pairs? Size wise, as to pairs, a pair of Hsu ULS-15's (18"x18"x18") seem to be the most our room can accommodate. As it seems that it's not a good idea to marry single killer subs up with a pair of smaller, inferior subs, that setup is out.
Old 10-26-2012, 10:51 AM
BeeMan458's Avatar
Liked: 813
Originally Posted by Steve1981 View Post
I think a pair of FV15HPs with the 550 watt amplifier for $2374 shipped would be mighty tempting... They're also a bit narrower and not as deep as the PB13 if that helps any.
Thanks for the suggestion. I took the Rythmik off the list because I'm not partial to the right hand side of the FR graph; 90Hz - 120Hz dB drop. A flat graph means a lot to me as it means the higher frequencies aren't going be rolled over by the lower frequencies, mashing the mid-bass.
Based on everybody's ever so thoughtful efforts, I'm back to first base and a pair of SVS, PB12-NSD's as it seems a killer sub is not in the cards due to aesthetic room placement limitation due to furniture size and subwoofer size constraints due to where I can place the subs.
FWIW, the wife and I have had the WAF dust up with tears and the whole drama scene (I know I'm not the only one here who's been down that road) with the result being, her saying, okay, I'll do it for you but only because I love you. That means it's compromise time on my part as my wife is willing to accommodate my home theater needs but within conservative limitations that acknowledges her needs equally. Being a good spouse has it's compromises.
Old 10-26-2012, 10:53 AM
Rmb1080p's Avatar
A single Cap or Submersive is going to be pretty good!
Happy to be here
Rmb1080p is offline
Old 10-26-2012, 11:00 AM
Rmb1080p's Avatar
I'm not going to flame but I will "Giggle"
Happy to be here
Rmb1080p is offline
Old 10-26-2012, 12:18 PM
sb1
sb1's Avatar
Quoted: 392 Post(s)
Liked: 286
Two properly eq'd subs of relatively close specs (and in the same room) sound quite similar. Only at the edge of output ability have I ever noticed any real difference from subs in the same price catagory, or even a little higher or lower priced than each other. I can't speak for anyone else, but I know most of my viewing sessions aren't treating my subs like they'd be treated at a get-together to test them.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
Old 10-26-2012, 12:30 PM
BeeMan458's Avatar
Liked: 813
FWIW, during action movies, I prefer to crank the volume control to 0dB - +5dB.
Old 10-26-2012, 12:55 PM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
On a calibrated system, with your size room, if you're listening at reference levels and above, youre gonna need some hefty fire power to keep things like distortion in check. Headroom also come to mind.
edoggrc51 is offline
Old 10-26-2012, 01:02 PM
bfreedma's Avatar
Liked: 51
I am. To be quite frank, the reason I nixed the Captivator and the Submersive off my list of prospects was due to a lack of objective measurements from guys like Ricci.
I mean, the PB13U has been run through the ringer by the guys at AV Talk, Ilkka, and Ricci. The FV15HP has been measured by Paul at AH and run through the ringer by Ricci. When you purchase these subs, you know exactly what performance you're buying, and for me at least, that's a comfort.
OTOH, what exactly does it say when Gene at AH says he's requested a Submersive from Mark three times and gotten no response? It doesn't really matter to me how well a sub does in a get together if the designer doesn't have enough apparent confidence to send it in for a real review.
Flame away.
Edit: For those that think I'm full of it with respect to my claims regarding Mark and Gene:
http://forums.audioholics.com/forums/906454-post34.html
While seeing Ricci test the Subm and Cap would be fantastic, there are plenty of these in the wild that have been measured and a GTG a few years ago where it was done in the same room. By any standard, while the PB13 is a strong performer, it simply can't keep up with the extension and output of the Subm and Cap.
What does it say that Seaton hasn't send AH a review sample? Rather than a big conspiracy, it could mean that he's got a steady stream of orders and doesn't want to donate one for review at this time while he fills customer requests (and makes some money). I find that a lot more likely than any lack of confidence in their products.
bfreedma is offline
Old 10-26-2012, 01:04 PM
cel4145's Avatar
Liked: 2991
One advantage of the Submersive is the choice of finishes. Let the wife pick.
cel4145 is offline
Old 10-26-2012, 01:07 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
. . . and the Submersive is one sub that you can listen to at reference without distortion. I do!
bsoko2 is offline
Old 10-26-2012, 01:11 PM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Yup! I've had a chance to hear one. FANTASTIC sub!
Old 10-26-2012, 01:12 PM
ccotenj's Avatar
Liked: 101
oh noes... gene hasn't reviewed the subm.... i guess i'd better sell it.... tongue.gif
there's no shortage of measurements available for both the cap and the subm...
- chris
ccotenj is offline
Old 10-26-2012, 01:34 PM
Sick Mother's Avatar
+1. I never got hung up on the numbers much. What I did do is observe the tremendous feedback Mark Seaton and his SubMersive HP have gotten. That, in addition to the consistently high scoring the SubMersive HP received in relation to other $1,000+ subs was very reassuring. Mark is a class act, extremely helpful, and builds a rock solid product. I have never been left wanting more (or better sounding) bass.
I bought the first vintage cherry SubMersive Mark ever made. I have Klipsch RF-83s and an RC-64 in cherry and getting a sub to match their color was important to me. Because I wanted a sub that could not only crush a man's skull, but also sound good doing it, I didn't consider Klipsch subs, and the aftermarket cherry sub list was (at least at that time) VERY short. I was concerned the images I was seeing on my computer being markedly different than the real thing, so Mark quickly sent out samples of wood he was then using. None of them worked. After talking to him on the phone, he said he might be able to do a custom finish (albeit at a slightly longer wait). He then sent me another sample, this time with vintage cherry (He may have changed the name by now), and I said let's give it a shot. After getting the SubMersive HP and putting it next to my Klipsch speakers, I'm very happy. The match is VERY close (I would say slightly less orange and just a hint darker), and the quality of finish on the sub is better than my speakers. After giving Mark my feedback, it appears he started offering Vintage cherry in the lineup just for customers like me who want their cherry components to match.
If a SubMersive HP is in the budget and you would prefer to go with one sub, I would personally put it at the top of my short list. You will not be disappointed.
John
Sick Mother is offline
Old 10-26-2012, 02:02 PM
Frohlich's Avatar
Quoted: 1165 Post(s)
Liked: 1112
That is YOUR perception. That is not everyone's perception. I trust hands on feedback from many AVS members just as much or more than technical reviews.
Frohlich is online now
