Subwoofer break in - Page 2 - AVS Forum
post #31 of 54 Old 10-29-2012, 09:50 AM
Bill Fitzmaurice's Avatar
Liked: 1771
Originally Posted by Chu Gai View Post
Let's say I take a rubber band and stretch it, but not so far that I stretch it to the point of permanent deformation or breaking. IOW, I stay within the rubber band's elastic region. If I measure the length of the band before and after a long series of stretchings it will be somewhat longer. But after a period of rest, the material cools down and the polymeric molecules return to roughly their original configuration and the rubber band's measurements will have come back to their original value. .
True, but that has no bearing on the subject at hand. Where a driver spider is concerned a correct comparison would be with a new versus old pair of jeans or leather shoes. Unless you buy your jeans pre-washed, ie., already broken in.
Bill Fitzmaurice is online now
post #32 of 54 Old 10-29-2012, 09:51 AM
tokerblue's Avatar
I've never heard a difference in any speaker setup that I've owned from the first hour or the hundredth hour. I'm not saying that there isn't a difference, only that I don't see it as being important in the grand scheme of things. Especially since it's easy to hit the "break in" period with normal listening habits.
tokerblue is offline
post #33 of 54 Old 10-29-2012, 10:24 AM
BeeMan458's Avatar
Liked: 801
I lot of it is taught thinking, Like wine tasting. If you've not learned what to taste for, one bottle is as good as the next. The same goes for coffee, bourbon, whiskey, steak, perfume or what ever product you're a connoisseur or aficionado of. In the case of speakers, you're listening for subtle sounds such as the decay of a single string note or the sizzle of a snare but if you're listening to compressed music, the compressed or lossy CODEC is going kill the expansion of sound and you're not going hear the difference in the note or sound when played on a new emitter vs the sound reproduced by a "broken in" emitter or driver.
In the short, the reproduced sound loses depth and feels cut off and chopped in nature. All I can say is, the life of a connoisseur/aficionado can be both a pleasure and a pain, as one never knows what they're going experience.
In the end, overall, it's an industry designed to kill sound quality so you won't know what you're missing and then when you wake up, it's too late cause it's gone and now you have to spend boatloads of money to get it back. tongue.gif
"Buy my speakers."
Why? Because they're cheap and those buying them don't know they're in the process of having the quality of their reproduced sound, killed.
"Buy my transport."
Why? Because it has a cheap DAC design inside that kills sound quality and it's okay because the buyer is clueless.
"Buy my CD."
Why? Because it's a cheaply recorded, lossy compressed recording and will be played back and reproduced with cheap ear buds and pocket player; the buyer will never know the manufactured playback chain has killed the sound quality.
Now the consumer has a cheap, sound quality killing system chain and then enters a pair of new speakers. Hopefully my above helps paint a semi-complete picture when I say, the industry is about killing sound quality so you won't know what you're missing. But once you go looking for quality sound, your education begins and the pain of it all becomes nightmarish as nobody should have to listen to sound that has been killed and then brought back to life.
David Susilo likes this.
BeeMan458 is offline
post #34 of 54 Old 10-29-2012, 10:31 AM
nismo604's Avatar
Break in thoughts from a world class speaker designer Paul Barton of PSB Speakers.
Finally, and perhaps most controversially, Barton talks about the supposed break-in effect of components that has become so popular in audio today. Break-in refers to running components for a long time (sometimes hundreds of hours) to the point where their components "settle" into their proper operating mode. Barton doesn’t doubt that some components do change subtly, but he thinks that the major improvements people think they’re hearing aren’t in the components at all. Barton doesn’t doubt that people are hearing these changes, but thinks that what they’re hearing is actually brain break-in.
Barton has examined his own speakers to test this. He has taken a Stratus Gold loudspeaker, built and measured some ten years ago, and re-measured it today. The deviation is slight, perhaps 1/4dB at most. Although that deviation can possibly be heard, it is certainly not a huge difference that one may attest to hearing. Instead, Barton surmises that the difference in sound that people are hearing over time is conditioning of the brain. He cites experiments done with sight that indicate the brain can accommodate for enormous changes fairly quickly and certainly within the hundreds of hours that audiophiles claim changes occur in. Could this apply to hearing, too? Barton thinks that more often than not, what happens is that the changes in perceived sound that are attributed to component break-in are simply the brain becoming accustomed to the sound. He warns listeners not to fool themselves.
nismo604 is offline
post #35 of 54 Old 10-29-2012, 10:43 AM
BeeMan458's Avatar
Liked: 801
There's both, brain familiarity (a true phenomenon) and break-in, removing the stiffness of the driver, more responsive. The problem, the brain has serious trouble with remembering sonic qualities. The way I was "taught" was, listen and make notes on a familiar piece when the headphones are new. Then let white noise play through the headphones, turning the headphones on and off over the break-in time of a hundred hours, never putting them on during the break-in period. Doing it this way one is not affected by the brain familiarity phenomenon and second by referring back to the notes, one gets notes in which to compare the new listening experience to.
What I found was, new headphones and IEM had a harshness to the highs like nails on a chalkboard but after being broken in, the highs were expanded and mellower. Since the headphones were not worn or listen to during the break-in period, I was not subjected to the brain familiarity phenomenon. Yes, admittedly, this phenomenon was experienced with headphones and IEM and not speakers but the principal is the same.
Everything mechanical goes through a break-in period. Tain't no thang.
post #36 of 54 Old 10-29-2012, 10:50 AM
repete66211's Avatar
Quoted: 66 Post(s)
Liked: 228
I'm a scientific skeptic, a firm believer in evidence-based thinking who strongly opposes much of the snake oil nonsense (i.e. power & speaker cables) in the A/V community. To pass the sniff test a claim must be plausible and measurable. In other words, not rely solely on subjective reporting and susceptible to blatant bias. That physical components of a speaker would change over time is a reasonable hypothesis. That these changes can be objectively observed and, more importantly, measured seems to put the concept to rest. However, I think some people may be confusing the break-in of the physical parts of a speaker with the more elusive electro-chemical burn-in phenomenon sometimes reported.
My anecdotal evidence in support of speaker break-in: My first subwoofer was the low-end Polk Audio 10" PSW110. I was sitting right in front of the thing when setting it up and witnessed the sub very clearly going from dead to full activity within about a minute.
Note: Some subwoofer manufacturers don't like you running sustained tones through their products for extended periods, so check your warranty before doing so.
repete66211 is offline
post #37 of 54 Old 10-29-2012, 10:58 AM
farsider3000's Avatar
Bill / Beeman... Chu Gai is thinking correctly in my opinion.
A bearing or other mechanical device can last forever if the mechanical forces do not exceed the design / material limits. For instance if a ball or roller bearing load is below a certain threshold, the bearing is properly lubricated, has no material defects large enough to cause a fatigue crack, and the load direction is within a certain envelope it can last forever.
For speakers it all depends on the forces placed on the mechanical speaker components and whether they will permanently deform based on the power put into the system.
I tend to think it has more to do with our brains starting to "like" or accept the new speakers sound but I am not a designer of speakers so I do not know the designed limits of the mechanical system and materials are.
If we are to accept that speakers take x amount of time to break in, then it certainly matters how much power is put into the system during the break in period.
It would take exponentially longer to break in speakers using 5 watts of power vs. 500 watts of power.[/
I]
farsider3000 is offline
post #38 of 54 Old 10-29-2012, 11:02 AM
bthrb4u's Avatar
Quoted: 12 Post(s)
Liked: 36
i can honestly say that break in has worked with every headphone i have ever used. i usually play heavy dubstep and this to loosen the drivers
http://www.jlabaudio.com/burn.php
not sure how the white noise works but they say it does. I play the dubstep to get the drivers to move as much as possible and loosen up whatever the driver surrounds materials are made out of.
who do i talk to around here about changing my title from "advanced member" to "specialED member"
bthrb4u is online now
post #39 of 54 Old 10-29-2012, 11:23 AM
Liked: 1771
One can think whatever they wish. My comments are based on the hundreds of measurements I've personally taken of both the T/S specs of drivers and response of speakers loaded with them going back 30 odd years.
Read my first post again, though in fact one doesn't use high power to accelerate driver break in, one uses a combination of low power and a sine wave signal at a low enough frequency to realize excursion close to xmax at that power level.
post #40 of 54 Old 10-29-2012, 01:12 PM
bthrb4u's Avatar
Quoted: 12 Post(s)
Liked: 36
I'm very sorry if i sound negative but, i have made a lot of assumptions on this website and made plenty of mistakes talking about things i can honestly say i probably shouldn't have bothered with till i found out more information. I can admit when i'm wrong. Headphones, to me, change A LOT when they are broken in. That is one thing i will stand up against no matter who says so. I have witnessed it soooo many times. Biggest changes were with my Denon AH-D2000's. I would go to church and swear to the good lord that i am not lying or imagining anything.
post #41 of 54 Old 10-29-2012, 01:24 PM
BeeMan458's Avatar
Liked: 801
A bearing or other mechanical device can last forever if the mechanical forces do not exceed the design / material limits. For instance if a ball or roller bearing load is below a certain threshold, the bearing is properly lubricated, has no material defects large enough to cause a fatigue crack, and the load direction is within a certain envelope it can last forever. [/[/B]I]
Having worked with bearings, due to load stresses to one side of the bearing (loads and stresses are not evenly distributed nor are they expected to be evenly distributed), bearings are tight in the beginning, do break in and will wear out, even if properly lubricated and used within stated tolerance, wear and replacement is expected.
post #42 of 54 Old 10-29-2012, 01:30 PM
BeeMan458's Avatar
Liked: 801
David Susilo and bthrb4u like this.
post #43 of 54 Old 10-29-2012, 01:40 PM
Chu Gai's Avatar
Quoted: 370 Post(s)
Liked: 631
Speaker break-in is not an unusual question to see on any audio forum. Generally someone's bought speakers and they're trying to figure out if those speakers are really for them. There's a lot of issues that come into play here: positioning, calibration, effects of the room. Often the person who posted the question is somewhat inexperienced and hasn't done the best job of placing the speakers. Or perhaps they've just bought the wrong speakers (but they sounded good in the store!) for the room that they're going in. The purpose of this post though, is not to deal with those issues, deserving as they may be of an in-depth discussion.
This is about the issue of speaker break-in. Scientifically, the topic of speaker break-in has been studied rather extensively using techniques such as laser interferometry, measurements of speaker parameters, and controlled listening tests.
David Clark, an AES Fellow presented "Precision Measurement of Loudspeaker Parameters", which was published in the March, 1997. Abstracting from that paper is the following quote:
"5.1 Break-In"
"A break-in process is recommended. Drive-unit storage may cause the diaphragm suspension to drift away from its normal or in-use position. Break-in, with the drive-unit axis in the in-use orientation (usually horizontal), restores the normal diaphragm position. The recommended procedure pneumatically stretches the suspension to one excursion extreme, then the other and continues to alternate, decreasing the excursion each time until x is at zero. This process can be completed in less than 1 min."
Mr. Clark also indicated that drivers which had been stored face-up or face-down sometime need 1 minute of pink noise to restore the original center position. This could also be accomplished by a few strokes of the suspension which many manufacturers do routinely when the speaker is at the end of the assembly line. This suggests that most speakers, are in fact broken in when you get them.
Further work has been performed by Tom Nousaine who has measured speaker parameters pre and post break-in as well as having conducted controlled listening tests. He has found that the Fs of the speaker falls however that is offset by a rise in Vas. Both these parameters were related to the changes in compliance that occurred. During the playing or exercising if you will of the speaker both the spider and the surround become more compliant (they move easier if you will). Additional measurements on samples of identical drivers indicated that the changes that occurred pre and post breakin on a single driver were smaller than the variations within a particular lot of drivers. Since there are manufacturing tolerances for drivers this indicates that whatever changes are that occur are smaller than those of manufacturing tolerances. This further indicates that the net effect of speaker breakin is nada, nothing, zilch, forget about it, etc.
In one experiment, Nousaine used a driver that was said to need 48 hours of break-in. Placing the driver in a 1.5 cubic foot box, he found the system resonance to be 53 Hz before break in. After 48 hours the resonance was 49 Hz. After a few minutes rest, the resonance had gone back to 51 Hz. The following morning it was back to 53 Hz. This indicates that whatever small changes that occur in a driver's characteristics during playback comeback to their original state after rest.
These experiments have been performed with other drivers such as from Dynaudio with similar results. Overall this indicated that whatever changes do occur, they do not change the sound quality.
Moreover, Richard Pierce, a well known consultant and speaker designer who has examined the parameters and behavior of thousands, if not tens of thousands of drivers. His findings also concur with Clark's and Nousaine's with regards to how drivers behave in the real world.
Ten years ago, he wrote the following in Usenet.
Well, there are, indeed, several mechanism that are, indeed, at work that cause the operating parameters of drivers to change through use. However, the notion that once one gets a speaker home it requires "breaking in" suffers from several problems.
First, as a driver comes off the line, it's actual performance is fairly far from it's intended performance target. Reasons for this include the fact that the centering spider, typically manufactured from a varnish- impregnated linen, is far stiffer than needed. Working the driver back and forth loosens the spider considerably. Now, one might say: there's objective proof of the need to "break in" a loudspeaker! Not so fast. The break-in period for the spider is on the order of several seconds, and if it takes you several seconds or
minutes or whatever once you get the speakers home to loosen the centering spdier, it's not proof of the need to break time in, it's proof that the speaker you just bought HAS NEVER BEEN TESTED!
But, on to other points. When I measure a driver, I can see a significant change in a variety of operating parameters as the speaker is driven. Usually, in a woofer, the resonant frequency drops as the speaker is used, often by as much as 10-20%. This is due, as you suggest, to a relaxing of the elastomers used in the suspension. However. If I turn the stimulus off, within a few minutes most, if not all, of the change has completely recovered, and we're back to go again. The elastomer has recovered from its stresses (this is
especially true of certain polybutadene-styrene surround formulations).
There are plenty of other, real, physical changes. For example, one can see a reduction of the electrical Q with time under heavy use, simply because of the positive temperature coefficient of the resistance of the voice coil. Allow the speaker to cool down, and it's completely recoverable. Get it hot enough, and you might permanently loose some flux density in the magnet. But you have to get REAL hot to do that. Hotter than most of the compounds used in making a speaker can endure without catastrophic failure (damned few glues, varnishes, cones and insulating materials can withstand the temperatures needed to reach the Curie points of the typical magnetic materials found in loudspeakers).
What I really think is at play in all this is the adaptive signal >processing abilities of the brain. It is not the speakers which get broken in, rather it is ones 'ears'.
When this has been suggested, despite the fact there's about a century of research backing it, it is more often than not greeted with jeers and cries. See, you can't sell special "break-in" CD's if the speakers aren't broken in.
So if the sound quality does not change in any significant way, what then does occur? Well listening adaptation would then have to be looked upon as a very strong reason for the perception of speaker break-in. Anyone who has spent time listening to audio systems or components knows their opinions with regards to the nature of the sound changes with time. In the case of speakers, when one buys them and brings them home, you become used to the sound of that particular speaker. That sound may grow upon you or you may find there's something that you don't like about it. Nonetheless, however they sound in your particular home, it'll be different from the way they sounded either in someone elses home or the stores where you heard them.
Now I've had a few emails that I've sent to various speaker manufacturers over the years and these are some of the replies on this subject of break-in.
We've found (as have our dealers and customers) that the most significant changes occur within the first 75-150 hours, with smaller incremental changes occurring up to a few hundred hours. After that point, you shouldn't notice much change at all, as the speakers would be broken in thoroughly. This time is the same for each model and is best accomplished by just playing music through them.
Thank you for your interest in Revel.
Todd Sutherland
Madrigal
Original Message
Sent: Tuesday, July 30, 2002 8:37 AM
To: admin@madrigal.com
Subject: speaker breakin
Dear Sir/Madam,
Thank you for your enquiry into Krix Loudspeakers. Most speakers will benefit from a 'run in' time and our speakers are no different. We suggest running speakers at moderate listening levels for between 20 - 50 hours. After this time you should hear some differences as the components of the speakers start to 'free up',
I hope this information has helped, should you have any further queries please feel free to reply to this email.
Kind Regards
Ben Ormsby
National Consumer Sales
With all mechanical parts they do require a running in period, this ideally should be about 36 hours, what I suggest you do is listen to your speakers at a moderate level when you can over this period. Following this procedure will help prolong the life of your speakers.
Best Regards,
Gabriel O'Donohue
Customer Specialist Support
Tannoy Ltd
Tel: +01236 420199
Fax:+01236 428230
E-mail: gale.o'donohue@tannoy.co.uk
Thanks for your recent email to Definitive Technology.
In order to break-in your BP10Bs, we recommend playing them at a moderately loud volume for about 40 hours. (After this period, the suspensions on the speaker cones loosen up a bit.) Generally, you'll hear a smoother high frequency response as well as a greater openness or transparency.)
If you need any other information, please email me at cpelkowski@definitivetech.com
Thanks Again,
Chet Pelkowski
Now if studies have indicated there is no significant change during pre and post breakin and that whatever changes in driver parameters that do occur, are restored to their original values over time, one must ask the question, if the speaker companies are aware of this, and larger companies, that have access to such data as I've presented here do, what is the purpose for specifying breakin that amounts to around 40 hours, give or take? To my mind, the reasons would have to do with ensuring that the customer keeps the speakers in their home for a couple of weeks to hopefully either get used to them or to convince themselves, rightly or wrongly, that they do like the speakers. During this process of listening, the customer, as can be seen on some of the posts on this forum, is actively seeking out other users opinion, corroborations, justifications, positive/negative opinions. So myself, I would recommend that anyone purchasing speakers listen to them in their homes and if during that time, which should be well before the RETURN PERIOD, they don't like them to take them back where they bought them and rethink the choice they made. Any salesman who says you need this CD or this procedure to break-in is doing so for either a couple of reasons...they're ignorant, or they're hoping you need a little more time for the speakers to grow on you so you don't return them and he/she doesn't blow the sale and commission.
As to why Thiel, and for that matter others like Anthony Gallo, subscribe to significant loudspeaker break-in, I don't know. Yet the late John Dunlavy thought it was much ado about nothing. Arnie Nudell didn't bother addressing it Neither did Kantor or Barton. I just don't know. Maybe it's a marketing position that they've taken. Maybe they say different things to different people. Maybe they're not aware of the research that's been done and that might not be so surprising considering that their focus is more pragmatic based. Other than resorting to the oft stated, "That's what I hear.", I don't think they've done any work in this area. At least none that's been shared in anything approaching a rigorous fashion. Nor do I don't think anyone's pinned them down after a couple of pitchers of beer and a few margaritas. That might be interesting.
As for my position, it seems that the work has been done to answer this question but it just hasn't been widely disseminated to the general public in a fashion that's easy to comprehend. Further, one should never break-in the speakers for so long that their ability to return them if unsatisfied is compromised.
gtaylor0 likes this.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is online now
post #44 of 54 Old 10-29-2012, 03:28 PM
nastynice's Avatar
I have experienced very noticeable break ins (ESPECIALLY the bass smoothness), I highly doubt it was my mind playing tricks on me. I have some creative t10's, which only play down to 80Hz, and at first the bass was unbearable. Its still pretty crappy, but at least I don't feel completely ripped off anymore. They sound like how much they cost, 40 bucks. At first they sounded like 5 bucks.
nastynice is offline
post #45 of 54 Old 10-29-2012, 04:03 PM
ivanpino's Avatar
Quoted: 25 Post(s)
Liked: 33
I wonder what $80 speakers sound like? Twice as good maybe? LOL
ivanpino is offline
post #46 of 54 Old 10-29-2012, 04:29 PM
nastynice's Avatar
post #47 of 54 Old 10-29-2012, 05:22 PM
N8DOGG's Avatar
Quoted: 356 Post(s)
Liked: 372
I've had and built well over 60 subs in the last 10 years. Subs do break in, somewhat. I've never gone so far as to hear a major difference in how it sounds though. I will generally not run tons or anything else through them. I crank them up and enjoy them. There is no major change. I find the same with headphones, my current Senn 700's sound great but it took my time to adjust to their sound. I actually like the sound of my Ultrasone Sig's better than the 700's. They sound the same to me as the first time I ever played anything through them.
N8DOGG is offline
post #48 of 54 Old 10-29-2012, 05:32 PM
kevon27's Avatar
Quoted: 57 Post(s)
Liked: 106
If you use a speaker it would get broken in even if you did not consciously set out to do so. So if after playing the speaker for awhile results in "better" performance, great, if not and it still sounds the same, that's still a win.. End of story.. and End this thread.
kevon27 is offline
post #49 of 54 Old 10-29-2012, 06:10 PM
lovinthehd's Avatar
Quoted: 723 Post(s)
Liked: 1143
You mean it's just beating a dead horse....tried the little image but maybe can't....
"I realize that somebody playing free music isn't as commercial as a hamburger stand. But is it because you can eat a hamburger and hold it in your hand and you can't do that with music? Is it too free to control?" - Don Van Vliet (aka Captain Beefheart) discussing commercial success in the music biz
lovinthehd is online now
post #50 of 54 Old 10-29-2012, 08:58 PM
Sorry guys... waaay off topic but I have to address Beeman ...
Beeman: you are misguided regarding the bearings. A bearing that is not overloaded runs on a hydrodynamic wedge of lubrication and there is no actual contact between the rolling element and the raceway. A bearing under ideal conditions with ideal lubricant can run forever assuming proper alignment, minimal loads, load direction etc. A bearing can certainly wear and loosen up but it was due to either lack of lubrication film, load or misalignment to cause the wear....
I can see the point that a speaker may change it's sound over time due to enough movement t to physically change the speaker mechanical elements.
Just trying to clear the point on bearings so we can all keep each other honest around here... bearings what an enthralling topic... smile.gif
post #51 of 54 Old 10-29-2012, 09:05 PM
lovinthehd's Avatar
Quoted: 723 Post(s)
Liked: 1143
post #52 of 54 Old 10-29-2012, 10:06 PM
jonathanc's Avatar
Liked: 48
With theads like these, with a lot of opinions and without a lot of data obtained through scientific method, one can really only read opinions from people who sound like they know what they're talking about, and then pick the answer that seems the most logical.
Here is a copy/paste from Bob Crites' website, which seems more or less similar to Bill Fitz's. Both of these guys know what they're talking about, and both give an answer that seems pretty logical:
Q: Do components have a break-in time?
A: Some do and some don't. Capacitors would be a definite NO. Let's look at this one a bit.
You have new good quality capacitors installed in your crossovers. Capacitors have exactly two qualities that effect the sound of your music that goes through them. Those are capacitance (what we use them for) and ESR. ESR is the sum of all other qualities of a capacitor other than capacitance expressed as an Equivalent Series Resistance. ESR is a bad thing. Good caps have ESR so low it is barely measurable, on the order of a couple of hundredths of an ohm. ESR is made up of stuff like the resistance of the leads and their connections to the foil inside the capacitor or stray inductance or dielectric absorption.
So, we put our new caps in the crossovers. These new caps are right on the capacitance value the design calls for and the ESR is almost unmeasurably low. What exactly of these two qualities do you expect to change with break-in? And if either of them changed, why would you expect the sound to get better since the only way they could change is to go away from the "perfect" values they had to start with? I hope any caps you use in your crossovers are good enough that they do not change at all for many years of use.
Q: But my speakers sound so bright after putting in the new caps that I have to hope they change with break-in. In fact I am pretty sure they are getting better as I listen longer. They must be changing.
A: Sounding brighter is a good thing. That means your old caps were really bad and had high ESR. That high ESR had the impedance all upset on the crossovers and you had the drivers all trying to play at the wrong frequencies. Also, the high ESR was directly attenuating the high frequencies. Now with the new good caps, the frequency and level relationships are back to where the factory had them when the speakers were new. The fact that you think they are changing now is because you are getting used to them sounding like they should. The break in is occurring but it is inside your head instead of inside the speakers.
Q: How about break in time for wires and interconnect cables?
A: None
Q: How about break in time for drivers or new driver diaphragms?
A: Yes, and depends on the size of the driver. Tweeter diaphragm probably break-in at a matter of seconds. They are very low mass and move very little, so any break in would happen almost instantly. Probably happened when the factory tested the diaphragm after manufacture.
Midrange are a bit bigger and have a bit more mass. Break-in is probably on the order of minutes with these.
Woofers would take the longest. I think that break-in on a 12 to 15 inch woofer would be less than an hour played at pretty good volume using music with a lot of low frequency content.
jonathanc is offline
post #53 of 54 Old 10-30-2012, 10:26 AM
Avliner's Avatar
Some food for thought downhere guys:
http://www.audioholics.com/education/loudspeaker-basics/speaker-break-in-fact-or-fiction
Regards, Chuck
Hold on tight to your dreams - ELO
Avliner is offline
post #54 of 54 Old 02-16-2014, 01:07 AM
kramskoi's Avatar
Liked: 26
Originally Posted by Bill Fitzmaurice View Post
That's not the case. The specs will creep back towards the original values after a period of rest, but they never go back to the original values. Moreover, once the initial break in has occurred the time frame for the spec values to fall back to the post break in figure is reduced from hours, if not days, to minutes, if not seconds. With each subsequent use the amount of creep back is reduced, as is the time required to get back to spec.
Also noteworthy is that the break-in process never stops, because the surround and spider continue to grow softer with use. I had one woofer that measured 60Hz Fs out of the box, and after initial break in it came down to the 53Hz spec. I used this same woofer in a number of cabs, swapping it out every few years. and with each subsequent testing the Fs had dropped a bit more. The last time I measured it was 20 years after the initial break in, by then Fs had dropped to 46Hz.
I know this is old but I just love for guys that don't test and measure to be put in their "stupid" place. You go Bill!cool.gif
"Frequency response is NOT efficiency response."
Klipsch RB-35's main
Klipsch RB-35's surround
Acoustech HT-65 center
Cerwin-Vega CV-2800
Subwoofer
B&C 21SW152-4  [21" critical-Q]
kramskoi is offline
