Connecting sub to amp using speakon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-30-2012, 11:44 AM - Thread Starter
ShaQBlogs's Avatar
Quoted: 27 Post(s)
I have 2 passive sub which i am connecting to the amp. The amp has a speakon connector and it has 2 channels. So one sub gets connected to each channel respectively using a speakon connector for each channel.
But the speakon has the following connections 1+, 1-, 2+, 2-. How do i connect one single sub to this connector?
I checked with multimeter and all the 4 connections are independent. of each other. I expected 2 pairs to be shorted such that 2 subs can be connected in parallel using just one connection. A little confused here.
ShaQBlogs is offline
post #2 of 8 Old 10-30-2012, 12:30 PM
Fidlefadle's Avatar
What do you mean by one single sub.. do you not have two separate subs?
If you do have 2 subs then I believe you just run 2 speaktrons out of the amp, one for each channel. you only wire the first channel to 1+/1- and you wire the second channel to 2+/2-
(edit: My experience is limited. I have a single sub run off of my EP4000 in bridged mode so that 1+ is positive and 2+ becomes negative out of channel 1, and I just run a single wire to the sub)
Fidlefadle is offline
post #3 of 8 Old 10-30-2012, 12:44 PM
cubalis2's Avatar
Quoted: 28 Post(s)
Liked: 50
If connecting a single sub to one channel of the amp, using a 4 pole speakon connector, you would use 1+ (pos) and 1- (neg). If connecting both subs, then simply use the 2+ and 2- for the second sub - giving each sub one channel of the amplifier. This is the speakon going into the amp.
cubalis2 is offline
post #4 of 8 Old 10-30-2012, 01:33 PM - Thread Starter
ShaQBlogs's Avatar
Quoted: 27 Post(s)
thanks for the replies
i am still a little confused.
I got how to connect one sub. Connect to one channel of the amp with the speakon with 1+ and 1- connected to one subwoofer.
For second subwoofer, I connect to amp's second channel with second speakon connector. But, You mean to say I should connect the second sub to 2+ and 2- and not 1+ and 1- of the second speakon?
post #5 of 8 Old 10-30-2012, 01:53 PM
cubalis2's Avatar
Quoted: 28 Post(s)
Liked: 50
It should be possible both ways.
Using the amp I have as an example, the Behringer inuke 6000, I have two passive subs connected using a single 4 pole speakon as I described earlier. I could have used separate connectors - one for each sub instead. If doing it with two connectors you would use the 1+ 1- on each connector.
Simply speaking, you don't need to use 2 speakon connectors for 2 subs, provided your amp can take a 4 pole connector (it should be labelled on the back of the amp- see image ) .
Each sub would still get its own amp channel, one from the 1+ 1-, and one from the 2+ 2-.
You can use two connectors if you'd rather, in which case the 2+ 2- are just not used.
Hope this makes more sense.
ShaQBlogs likes this.
cubalis2 is offline
post #6 of 8 Old 10-30-2012, 01:53 PM
Bill Fitzmaurice's Avatar
Liked: 4628
What does the amp manual say? There's no set rule as to how Speakons are wired. They may be +1/-1 on one channel, +2/-2 on the other. But they may not.
Bill Fitzmaurice is online now
post #7 of 8 Old 10-30-2012, 02:10 PM - Thread Starter
ShaQBlogs's Avatar
Quoted: 27 Post(s)
yup...got it. Assuming that this is how it works in my amp.
I have a crown XLS 1500
I have checked the manual multiple times. It has barely info on this - except a bit on page 7.
I zoomed the image on page 7 and i think it is what cubalis2 mentioned.
Pls confirm its same.
Here is a pic of the back panel of XLS 2500. It is the same in the XLS 1500 back panel
post #8 of 8 Old 10-30-2012, 05:35 PM
cubalis2's Avatar
Quoted: 28 Post(s)
Liked: 50
Yep, that looks to be the same as the inuke. You can use two separate speakons, one to each channel, or a single 4 pole speakon connected to the 'channel 1' input.
cubalis2 is offline
