Sub for $150.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-31-2012, 02:34 PM - Thread Starter
mark62's Avatar
Liked: 88
Forgive me for asking, this forum is mind numbing.
I just ordered the Jamo 426 package to replace a BA MCS-90 package (hope this will be an upgrade?) and need a sub that wont break the bank.
I dont need ultra low extension but i do not want one note boomy bass. Down to 35hz or so would be fine.
my room is not small but not huge either...
thanks for the help, mark.
mark62 is offline
post #2 of 15 Old 10-31-2012, 02:51 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
I ... need a sub that wont break the bank. I dont need ultra low extension but i do not want one note boomy bass.
IMO, you'll be hard-pressed to find anything at ~$150 that meets your requirements. I suggest you keep an eye out for a gently-used Energy S10.3. smile.gif
Roughly how big (l x w x h) would that be?
eljaycanuck is offline
post #3 of 15 Old 10-31-2012, 03:45 PM - Thread Starter
mark62's Avatar
Liked: 88
15x20 but is open to rest of house, also does not have high ceilings.
also i am not unhappy with the little sub that came with the BA MCS-90. it does add bottom to the sound... so i dont need liver shaking bass....
I should note that i did use to have the top of the line paradigm sub at one time ($1500). and paradigm all the way around, but divorce took care of that!
My wants are dictated by my means... i cant afford alot now.
mark62 is offline
post #4 of 15 Old 10-31-2012, 05:14 PM
Liked: 1964
Fair enough, which is why I suggested something that would fit your budget. smile.gif
post #5 of 15 Old 10-31-2012, 05:29 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Velodyne VX-11 is close to your price. Sounds pretty good for a budget sub. Won't fill a very large room with bass (only a 10").
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #6 of 15 Old 10-31-2012, 07:03 PM
pumbaa071's Avatar
the martin logan dynamo 300 is in your budget
pumbaa071 is offline
post #7 of 15 Old 11-01-2012, 01:55 AM - Thread Starter
mark62's Avatar
Liked: 88
what about the polk psw10, i would guess it is crap? i like the velodyne for 169.... any other recommendations?
mark62 is offline
post #8 of 15 Old 11-01-2012, 05:21 AM
Liked: 1964
The PSW10 is inexpensive (usually $99 on sale) and its performance is commensurate with its price. IMO, it is best suited to smaller rooms and/or modest HT set-ups.
post #9 of 15 Old 11-01-2012, 05:49 AM - Thread Starter
mark62's Avatar
Liked: 88
ok one more question.... does anyone know anything about the pure acoustics lord 10? it is 119 with free shipping.... thanks again.
mark62 is offline
post #10 of 15 Old 11-01-2012, 06:25 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
Having bought several sub $200 subs in the past, I would save a little. For $200-$250, you can find much better subs on sale.
The thing is, shipping a sub is expensive, so you're $150 sub is really a $75 sub. A $225 sub is really a $150 sub. For $75 more, you're getting twice as good a sub.
KidHorn is offline
post #11 of 15 Old 11-01-2012, 09:50 AM
Liked: 1964
... does anyone know anything about the pure acoustics lord 10? it is 119 with free shipping ...
According to Pure Acoustics, the Lord 10 has a "200 Watts (150 max)" amp and a FR of 40-200Hz +/- ?dB. According to Amazon.de, the Lord 10's amp is rated at 150W RMS.
post #12 of 15 Old 11-01-2012, 03:08 PM - Thread Starter
mark62's Avatar
Liked: 88
thanks for the replies, after searching it looks like the lord 10 was actually part of package system from pure acoustics... called the lord 10 also, i think im not interested.
would the dayton audio 1200 blend with the jamo 426 package? or maybe i should go with the 1000. maybe i will wait for awhile, i dont know
thanks.
mark62 is offline
post #13 of 15 Old 11-01-2012, 07:34 PM
vardo's Avatar
Quoted: 56 Post(s)
Liked: 148
Maybe this for $100. Looks like shipping is waived..... (don''t) really know.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
I've got 2 10" Dayton Titanic subs.....they are kits for $400, so I don't know how this would stack up.
The kits are pretty damn good....so maybe this would do (temporary).
vardo
vardo is offline
post #14 of 15 Old 11-02-2012, 02:20 AM - Thread Starter
mark62's Avatar
Liked: 88
will the dayton audio sub 1200 blend with the Jamo 426's? i know it would with the mains which have 2 -5 1/2" drivers, the specs says the 3 1/2" center and sats go to 90HZ but i dont know if i believe that...
thanks for the replies and help....
i kinda double posted this in another thread.... but need advice...
mark62 is offline
post #15 of 15 Old 11-27-2012, 11:08 AM
yankomr's Avatar
So did you got the Dayton? Tomorrow i will get the jamo 426, but i am not sure what sub should i get, the specs of the 1200 look great for the price.
yankomr is offline
