Newbie that needs help quick. MartinLogan Dynamo 300 8" for $109 or Klipsch Synergy Sub-10 10" for $179? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-02-2012, 10:36 PM - Thread Starter
redlightracerLS's Avatar
I am ordering my speakers this weekend and I do not know what sub to get, I read the ML isn't great for movies and that the Klipsch has problems with boards burning out. This is my price range and they seemed like the best bang for the buck but I just don't know what would be best. It would be used for about 50% TV, 30% Movies and 20% Games. The room is 22 x 22 and I will be using a Denon 2112ci, with Polk Monitor50 series II towers and Monitor30 series II surrounds. Thanks in advanced
redlightracerLS is offline
post #2 of 8 Old 11-03-2012, 12:40 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
For a little more than the Klipsch, you can get the BIC F12. That's the budget entry level HT sub that get's recommended most around here. It's a 12" and has more output than the subs you are considering.
As for as the 8" vs 10" subs you are considering? What sub is best is tied to room volume. A little 8" sub like the ML won't give you a lot of output. So unless you are using it in a bedroom, the 10" makes more sense.
redlightracerLS likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 8 Old 11-04-2012, 08:11 PM - Thread Starter
OK now I am starting to second guess myself, I am falling down the subwoofer rabbit hole. I am just about ready to pull the trigger on the F12 but I am worried it will be too much for my speakers (cs1, monitor50s and monitor30s for surround). Will this be a good match or should I look for something else?
post #4 of 8 Old 11-04-2012, 08:59 PM
cel4145's Avatar
Liked: 2991
Won't be too much. In fact, a smaller, less powerful sub in your room would probably not be enough. You'll calibrate your setup using Audyssey on your Denon receiver. Set the speakers to small and a crossover of 80hz, and Audyssey will typically have done a good job of setting the rest.
One tip: subs tend to work better with Audyssey when the gain (volume) on the sub is set such that Audyssey arrives at a subwoofer channel level close to 0db. You may have to adjust the gain on the sub and rerun Audyssey more than once to achieve that. I usually do it for just one listening position the first time or two to get it close, then run it for all listening positions.
cel4145 is offline
post #5 of 8 Old 11-05-2012, 04:44 AM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
No, I don't think one f12 would be too much. My theater room isn't huge and I am running two of them.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #6 of 8 Old 11-05-2012, 03:12 PM - Thread Starter
Good advice, I will give that a shot and see how it does. I guess it is better to get to much and turn it down if need be than to get too small.
post #7 of 8 Old 11-05-2012, 04:11 PM
cel4145's Avatar
Liked: 2991
You won't have to turn it down. Audyssey will level match it with your speakers for optimal integration smile.gif
cel4145 is offline
post #8 of 8 Old 11-13-2012, 09:12 AM - Thread Starter
Everything is up and calibrated and it sounds great! Thanks for the help everyone.
Klipsch Synergy Sub 10 Subwoofer Speaker
