Variation in Output Among 3 Buttkickers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-10-2012, 02:37 PM - Thread Starter
Stephen1254's Avatar
I've got 3 BKF4-4 transducers installed in 3 theater seats. Each transducer is mounted in exactly the same way and the 3 are wired to a BKA1000-N amp in series as described on their website. There is a noticeable difference in output between the three transducers, with the one farthest away from the amp the strongest, the center one a little bit less, and the one closest to the amp the weakest. I had wired the system with some old doubled 18 gauge wire, and went ahead this morning and rewired the system this morning using a heavier gauge wire (14 GA) but this had no effect. Anyone have any ideas?
Stephen1254 is offline
post #2 of 2 Old 01-02-2013, 12:42 PM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
curious, did you ever figure this out? I have 3 buttkickers, and just noticed that one of them is not producing much movement.
barhoram is offline
