A comparison of three tactile transducers - ButtKicker Mini LFE vs. Clark Synthesis TST209 vs. Aura Bass Shaker Pro - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #211 of 235 Old 12-05-2014, 09:54 AM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
I am trying to decide between Clark and Aura due to budget constraints. Your comparison actually has me leaning towards Aura because of your comment regarding the Clarks feeling like they are always on. If these are correctly crossed over and the LPF and HPF are set, what causes this difference? Is it a sensitivity thing? Like the Aura require a louder "volume" at a given frequency to shake than the Clarks, or is it as simple that since the Clarks shake harder its more noticeable than the aura's?
jvh4 is offline
post #212 of 235 Old 12-05-2014, 10:20 AM - Thread Starter
Archaea's Avatar
Quoted: 2898 Post(s)
Liked: 2494
I don't know that the auras particularly struck me - at least that I remember one way or the other to that always on effect, but I do recall that with the buttkicker vs the clark.
The clark is basically a speaker that produces tactile feedback in the same way a speaker does. If signal is applied it moved.
The buttkicker is more like a rod that is driven back and forth from what I understand. It takes a little more power to get it started - or perhaps a little more power to be noticable anyway. The clark is a good transducer. We perhaps just had it turned up too much to be as subtle as I prefer. Now that I understand a little more about the transducers I'd like to retry my experiment again - but at this point it probably won't happen. I have nearfield 18" subwoofers, and they beat the crud out of anything I've felt from the transducer world. --- the only thing better than neafield 18" are nearfied 21" or 24" subs.
jvh4 likes this.
Archaea is online now
post #213 of 235 Old 12-05-2014, 01:33 PM
dominguez1's Avatar
Quoted: 918 Post(s)
Liked: 638
Here is a member who recently purchased and measured the Aura's vibration capability on his couch in the ULF thread. 4 of these were very capable on his system; strong down to 13hz!
dominguez1 is offline
post #214 of 235 Old 12-05-2014, 02:29 PM
derrickdj1's Avatar
Quoted: 890 Post(s)
Liked: 598
I had six of the transducer at the time of the test Dom. The Aura Pro's are mounted on 3 large boards in the sectional.
derrickdj1 is offline
post #215 of 235 Old 02-04-2015, 11:30 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
I have used Clark Platinums for about couple of years and more more recently have tried Aura's current offerings due to mounting constraints of some new home theater recliners.
I prefer the "subtle" feel of augmenting subwoofers as opposed to some sort of theme park experience.
If your goal is the subtle effect, I would say that Aura can offer just about the exact same subjective experience as the vastly more expensive Platinum Clark's. The overall experience to me is really indistinguishable in any way that you would consider meaningful. I don't know if the longevity of the devices will vary since I don't know the build quality of the Aura transducers. Since the construction of these things is fairly simplistic, I don't see how they would stop working unless burned out with too much power.
I am currently using a crown XLS1000 and it is pretty sufficient and can do basic crossover tasks. I am running the Aura with a 50hz high pass crossover which is pretty effective.
My subwoofers powered by 10000 watts and and 8 15" drivers can EASILY make your body move but the transducers help at nights and not to irritate the hell out of neighbors. Subwoofer vibrations don't automatically resonate with your couch evenly either which the transducers help with.
Hopefully this review helps...
Blazar!
blazar is offline
post #216 of 235 Old 02-04-2015, 06:14 PM
derrickdj1's Avatar
Quoted: 890 Post(s)
Liked: 598
I can see your point on the comparison of the Clark and Aura Pro. The Clark and some other brand report a response down to the 5-10 Hz but, those numbers can't be done with enough force even though the RMS wattage is much greater than the Arua Pro. The transducer are not RMS limited since they use stronger amps, the problem is excrusion. The Aura Pro's are an excellent choice for HT. I have 8 under a large sectional and get great vibrations.
post #217 of 235 Old 02-04-2015, 06:34 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Yes not only are the aura bass shaker's sufficient but really not much material is recorded in the 10-20hz range. Even if it was, the vibrations would have a good chance of rattling some part of your couch and causing problems.
the 20-50hz range via the aura feels pretty decent, and I don't feel like I am missing anything in the overall experience. in fact, for music it almost seems like its unnecessarily distracting on some tracks that are recorded too hot. I plan on setting up to not 12v trigger the bass shakers for music.
blazar is offline
post #218 of 235 Old 02-07-2015, 11:27 AM
B1ueleader's Avatar
Quoted: 22 Post(s)
I use two Auro Pro's per recliner in my HT and that is a lot of shaking going on. I watched Fury yesterday and WOW the explosions rattled my teeth I really liked how the far off explosions you could barely hear I also gently felt. I'm using an Inter-M Reference Amp and it drives 8 total Auro's.
My riser seats which were made with a mounting board for shakers, carpet coming soon:
B1ueleader is offline
post #219 of 235 Old 06-07-2015, 03:54 PM - Thread Starter
Archaea's Avatar
Liked: 2494
I haven't felt the BK LFE transducer on a riser so I can't comment - but i will say that the mini's in a recliner are fun -- just be prepared to non stop tinker if you are like me.
MusiciansFriend and GuitarCenter run 15% off coupons regularly at holidays and are probably the cheapest place to buy your kit if you can take advantage of a 15% off coupon.
I have felt a BK LFE on a riser at @Luke Kamp 's since this post and it was excellent.
Luke played the Edge of Tomorrow intro with the 10hz note, and the full size buttkicker LFE transducer rattled the riser around perfectly. I like the Buttkicker LFE on the riser better than I like the buttkickers mounted directly to my chair. It feels more natural.
post #220 of 235 Old 06-07-2015, 04:15 PM - Thread Starter
Archaea's Avatar
Liked: 2494
I decided to sell my four buttkickers because my nearfield 18" subs do everything the buttkickers do, and then + some.
I had two friends last night and was comparing the difference between the nearfield 18" subs and the buttkickers and I asked them which they liked better. One liked the subs better, one was indifferent. I liked the subs better myself. One friend asked how much the price difference is. I said the buttkickers cost $90 each, the subs cost about $550 each.
He said he'd just go with the buttkickers with that price delta. But to me, and to the other friend, I'd rather have the nearfield subs.
Any rate - I'm selling my four on ebay - so if anyone is interested you can look up the auction link here.
http://www.ebay.com/itm/-/221795469208?
They work perfectly and look new - just outclassed by my nearfield 18" sealed subs IMO.
post #221 of 235 Old 06-08-2015, 01:31 PM
ApolloCreed's Avatar
Quoted: 382 Post(s)
Liked: 449
Great, so after silently researching this thread and others to make a decision on my first transducers, I pulled the trigger on 2 minis and 1 advance with an iNuke 1000dsp a couple of days ago. Would've definitely bought your set if they were available last week. Oh well, I only paid about $80 more for the transducers, I guess....... and I have the ability to return them if I choose to, so not the end of the world.
OG October Horrorfest Contributor
ApolloCreed is offline
post #222 of 235 Old 06-16-2015, 09:07 AM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
Archaea,
I think I just bought your Clark transducer on flea-bay. Curious before giving up on transducers and going w/nearfield subs (BTW, a very cool idea); Did you ever try low-passing the Clark at ~40Hz?
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #223 of 235 Old 06-16-2015, 09:27 AM - Thread Starter
Archaea's Avatar
Liked: 2494
@cuzed2,
You did!
and I didn't.
I used the Clark only shortly when I was testing with it, in this thread. You are getting a practically new unit, it's been in the box nearly the entire time I've owned it. I had some intent to install it later to play with it more, to try to fine tune better, but never did. If it didn't sell in this auction, at the price I was asking, I was going to go ahead and install it again, since I also recently sold the four buttkickers that were installed for the last couple years. I hope you enjoy it and it suits your purposes well!
I'll be shipping it out today.
Ultimately, for my part, I might be done with transduscers, I've experienced all the major brands at this point, and IMO sealed nearfield subs beat the transducers in everyway - even the mighty $500 Crowson. I do understand nearfield subs can't work for everyone, space wise but when they can work (placed directly behind the seat, firing directly into the back of the chair) - they really are the superior solution in my opinion. Caveats are the nearfield subs have got to be big (18", 21" 24" preferably - or if smaller - placed ridiculously close - so close you can't really recline your seat), they've got to dig low - plenty of cone excursion capability, and they've got to be CLOSE, so you can easily feel the acoustic energy the cone movement puts off. If you move the sub out two foot, it's pretty much worthless as a nearfield tactile experience, because that acoustic energy gets lost.
post #224 of 235 Old 06-16-2015, 12:26 PM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
@cuzed2,
You did!
and I didn't.
Archaea,
Wow; that was a quick response! I did skim thru your transducer thread and got a pretty good feel for your decision and direction. By the way that thread is very good, and well done. Unfortunately, I do not have the space to implement a near-field sub solution.
So at this point I am happy picking up where you left off with the Clark transducers. In fact; I JUST picked up a 2nd TST209 (open box unit from PE), and 50Hz f-mod low-pass filters to experiment with.
Previously I was using original Aura shakers (non-pro units) with no filtering and thought they worked well enough for what they cost, at least as a novelty. However; when doing some crude vibration/shake tests with some LF sweep tones; I confirmed that they were providing "shake" between 30Hz~100Hz, which was no longer feeling realistic for me.
Will be interesting to see if I can make it more realistic by "shifting the shake" down to a range of ~15hz to <50 Hz? Perhaps then it will be a better accompaniment to my 3-SVS 16hz cylinders...
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #225 of 235 Old 06-17-2015, 02:44 PM
carp's Avatar
Quoted: 2530 Post(s)
Liked: 1803
@cuzed2,
You did!
and I didn't.
IMO the Crowson has a lot more energy down low (below 20hz) than the nearfield sub. Above 20hz the nearfield sub smokes it. I think you are too heavy for the Crowson. Watching a scene like The Incredible Hulk or the beach scene from X Men the difference is massive between having the Crowson and not having it.
So... I went over to Luke's to experience the buttkicker and hear his new 1099's. I really liked the 1099's and loved the feel on the riser...I felt like it was a little weak compared to what you described but it turned out his transducer was off the whole time and he didn't realize it until after I left!! Oh well, maybe next time. Sounds like something I would do when demoing something for a friend. I remember when you guys came over to hear the Submersives I had one of them muted the whole time.
saginawjuggalo likes this.
carp is offline
post #226 of 235 Old 06-17-2015, 04:28 PM - Thread Starter
Archaea's Avatar
Liked: 2494
Perhaps, but so far I'm not inclined to agree with what you've showed me so far. That Crowson is nothing short of excellent, but more subtle than my three nearfield IMO. We'll have to do some more comparisons for you to convince me.
hey hey hey!
Yeah you do need to give it another go. Luke told me. Ha we've all done stuff like that!
I do think he's full size buttkicker is very cool on the riser!
post #227 of 235 Old 06-18-2015, 09:06 AM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
Archaea,
Jonathan,
Big Thank You! I received a like new TST209 deliver this AM
Craig
(aka cuzed2)
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #228 of 235 Old 06-18-2015, 09:11 AM - Thread Starter
Archaea's Avatar
Liked: 2494
Good!
Enjoy!
post #229 of 235 Old 06-22-2015, 03:18 PM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
Archaea,
So I received both of the TST209s and the f-mod 50Hz filters and made some quick comparisons over the weekend. This was done with the transducers on the floor and running sweeps (to make sure they work - keep in mind one was a PE open box special), and to see how they compare. The Clarks both work just fine and were comparable to each other . However; when comparing the Clarks to the Auras
Going from 15Hz up what I found:
- the non-pro auras did not have any significant "shake" until they hit 35 Hz
- The Clarks started to shake at 17Hz,, and were strong from 20Hz up
- Adding in the 50Hz lo-pass filters attenuated the shake nicely from about 55Hz and up
Next - to get them mounted under my Berklines. another Thanks to Archaea for the excellent mounting photos in this thread
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #230 of 235 Old 08-21-2016, 06:56 PM
acmeavs's Avatar
Quoted: 26 Post(s)
I am looking to do something similar. I am looking to buy a Clark TST209 and hook it up to a Dayton APA150 and set the LPF to 50Hz. If I do that, will I need the FMOD 50Hz connector? Will the APA150 sufficiently drive the Clark?
acmeavs is offline
post #231 of 235 Old 08-23-2016, 01:32 PM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
acmeavs,
Sorry I am not familiar with the Dayton APA150.
However; if this amp has a low-pass filter you can set for 50Hz you should be good to go. You will not need the FMOD filter.
Good Luck - and let us know how it works out
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #232 of 235 Old 01-09-2017, 08:33 PM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
A tactile transducer -vs- near-field adventure:
First; props to @Archaea for his excellent comparison and research!
On the other hand; this same research created another trip down the rabbit hole as explained below
VBBShaker
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #233 of 235 Old 01-25-2017, 12:58 AM
isamu's Avatar
Quoted: 34 Post(s)
Greetings gentlemen:
In your opinion, which is the better transducer between the Clark Synthesis TST329 Gold:
http://www.parts-express.com/clark-s...haker--300-862
and the Buttkicker Advanced:
http://www.parts-express.com/buttkic...ucer--300-9404
The Buttkicker is about $165 cheaper, but of all the videos and comparisons I've watched, the one thing that keep coming back is how much more refined the effects of the Clarks are. Maybe for sim-racing both are adequate enough?
A few people seem to be running the Clark TST209s. The 209s seem to get the job done, but I think I'm looking for a bit more power. Do you think the Clark Synthesis TST329 Gold is a nice step up, or do you think it'd be overkill for sim-racing, with a max wattage of 400? Would the Clark silver be more appropriate? At $364.95 x 4 for the TST329 Gold, it would be just under $1500. I *could* swing it but I'm not sure what to do....
isamu is offline
post #234 of 235 Old 01-25-2017, 04:30 AM
Marc Alexander's Avatar
Quoted: 909 Post(s)
Liked: 515
@isamu why not consider the Crowson MAs?
I went a different (budget) route and used the Earthquake MQB-1 minis on each seat. Very satisfied!
Can you provide more details regarding your room, subs, sub placements, seating, etc.?
Marc Alexander is offline
post #235 of 235 Old Today, 06:02 AM
THE GUNSLINGERS's Avatar
I don't use room correction. I run audyssey to set distances and then turn it off. My bluray player is the ps3 so no analog.
I manually eq subs post AVR, and the transducers are running off sub channel 2, which allows for separate distance settings on my AVR.
what device are you using to eq the sub post AVR? or does your sub have built in eq abilities?
THE GUNSLINGERS is online now
Buttkicker Bk Lfekit Low Frequency Effect Kit With Amplifier For Home Theater
