Need sub advice (duals for ~ $2.5K) -- Rythmik vs. Hsu vs. Power Sound; one specific constraint - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-11-2012, 06:08 PM - Thread Starter
richard11's Avatar
Hi everyone,
I'm looking for some sub advice for an upcoming theater room.
Dedicated theater room, 22 x 15 x 9 (2,970 cu ft); perfect rectangle, flat ceiling
On the 2nd floor; standard construction drywall over wood frame
One window on right side (will be sealed off), double doors at back left corner, no other openings
Will have room treatments
Two rows of seating; main listening position ~12 ft. from front of room
90% movies
10% music, TV, other
Speakers: most likely JBL Cinema -- 3677 fronts, 8350 side and rear surrounds
Receiver: Denon 4311 or similar (something with XT32)
Image: Epson projector onto AT screen
Sources: media PC, Blu-ray
I'm looking for a pair of subs for ~ $2,500 shipped.
Goals:
Listen at reference level with no dynamic compression (keep up with the speakers)
Bass slam you feel in your chest like at live music concerts
No port chuffing or other bad noises
Solid output to 16Hz (lower is great)
Good accuracy for music (somewhat less important)
One major constraint -- size (one dimension only -- I'll explain)
I plan on putting one sub on the front wall, center, and the other sub at the back wall, center, for smoother response across the seats. Since the screen will be very large, the front sub will need to go behind it, but I don't want to bring the screen too far into the room. Also, at the back of the room, I plan on a platform for the 2nd row of seating. I don't want to bring the platform too far into the room either.
Because of this, I need a sub that is relatively slim (<20") in either width or depth (or both). Height is not an issue (within reason). For a front firing sub, where the driver face is slimmer than the depth, I would turn it sideways and have it firing toward the side wall. Same thing at the back of the room. Hopefully that makes sense. It needs to be a "box" style sub, no cylinders. Looks don't matter, but it needs to at least have a grille or hidden driver (because the rear sub is accessible).
Here are some subs I'm considering:
Rythmik E15 - 17" width
Rythmik F15HP - 19" width
Rythmik FV15HP - 18" width
Hsu ULS-15 - 18" cube
Hsu VTF-15H - 18" width
Power Sound Audio XS15 - 18.5" width
Power Sound Audio XV15 - 18.5" width
Please let me know what you think of these or suggest others I should consider. I'm not opposed to 12" drivers, but I feel like they might have trouble achieving my goals. Not opposed to 18" drivers either, but I don't know of one that fits the "slim" criteria. Also, I'm okay with passive boxes and outboard amp.
Thank you!
richard11 is offline
post #2 of 16 Old 11-11-2012, 06:55 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
Add a pair of Epik Empires. Maybe consider to build a single DTS10 or F-20.
lovinthehd is offline
post #3 of 16 Old 11-11-2012, 07:28 PM - Thread Starter
richard11's Avatar
Thanks for the reply.
Anything Danley is way too big. And I really want to go duals for smoother response.
Epik Empire is 18" width, but there's a driver on each side. So, placed sideways it would need at least 3-4" of clearance for the "back" driver and no longer passes the slim criteria. If I placed it with drivers firing left and right the normal way, it's 24" deep and still needs a bit of clearance for plugs. Before I thought of all that, I did consider the Empire.
post #4 of 16 Old 11-12-2012, 07:59 AM - Thread Starter
richard11's Avatar
I may end up putting both subs in front, behind the screen. Doesn't change the size requirements though.
One thing I wonder about is sealed vs. vented and how much room gain I'll have. Any easy way to estimate room gain with given dimensions?
post #5 of 16 Old 11-12-2012, 09:20 AM
rush2049's Avatar
Quoted: 85 Post(s)
Liked: 101
If it is volume you want and 19/20hz is the lowest you care about:
Get the Rythmik FV15HP. It was a stand out winner for mid to low bass with very clean output at the gorilla83 get together.
If it is low notes you are after:
I own a HSU ULS-15 and would recommend them. They go as low as you want..... but that is also their major fault. You need to have a high pass filter to get rid of 10-12hz and below content. It will attempt to play it and fail.
The power sound I don't have any experience with.
rush2049 is offline
post #6 of 16 Old 11-12-2012, 09:26 AM
Quoted: 171 Post(s)
Liked: 150
Richard,
I just purchased 2 FV15HPs that should arrive this week. I had the PSA and HSU on my list also. I felt like the FV15HPs were going to give me the best performance for my dollar. I spoke with the heads of each company and they were all a pleasure to deal with. Based off the information from each I determined I would get the most performance out of the Rythimk subs.
I think if you are looking to save some money, the PSA subs would provide a lot of performance for the least amount of investment.
I, like you, had a limit on what I wanted to spend. $2400 and I ended up spending $2370 shipped for my duals.
HT - JVC RS520 - Anthem AVM 60 - XPA-7 - XPA-5 - GE Triton 2 - GE Supercenter XXL - GE Invisa 650 x 8 - Xbox One - PS4 Pro - Oppo BDP-203 - Dual Rythmik FV15HP's - Lumagen Radiance Pro
My Media Room
kaotikr1 is online now
post #7 of 16 Old 11-12-2012, 05:10 PM - Thread Starter
richard11's Avatar
Thanks everyone for the feedback.
I'm sure the FV15HP will check all boxes. I'm wondering if the XV15 will also check the boxes for less money. Where's that pro review?? =)
post #8 of 16 Old 11-12-2012, 06:51 PM
Cowboys's Avatar
Liked: 107
For your room size, dual of any of those will shake your room. The FV15hp can go real low with authority. I would get a pair of FV15hp's and not worry about the 'what if' question. Someone mentioned that Audioholic posted on Facebook that the PSA XV15 review will be out this or next week.
Cowboys is offline
post #9 of 16 Old 11-12-2012, 07:34 PM
ack_bk's Avatar
Quoted: 614 Post(s)
Liked: 697
Might as well wait for the PSA review, but I tend to agree that the Rythmik will most likely be the best of the lot since you have the budget. But they (FV15HP duals) would be considerably more then dual Hsu VTF-15's or two PSA XV15 subs.
ack_bk is offline
post #10 of 16 Old 11-12-2012, 08:15 PM - Thread Starter
richard11's Avatar
I have some time before the room will be done so I'll definitely look for the XV15 review and see others impressions.
I definitely hate those "what if" questions too but $1K could be used towards better fronts. And if the XV15 are just as capable in my room then I would certainly rather have better fronts with the XV15. But then you get to thinking "why not get the FV15HP *and* better fronts?" But then it never ends.... wink.gif
post #11 of 16 Old 11-13-2012, 12:13 AM
Cowboys's Avatar
Liked: 107
Exactly
Cowboys is offline
post #12 of 16 Old 11-13-2012, 05:52 AM
wingnut4772's Avatar
Liked: 29
I love my Hsu ULS15s ( I have 5 of them) but, having said that, they tend to be fragile. I have had to utilize quite a bit of warranty work with them. Their customer service is very good though.
Kaboom.
wingnut4772 is offline
post #13 of 16 Old 12-03-2012, 08:35 PM - Thread Starter
richard11's Avatar
Looks like I'm going to go with a pair of Power Sound Audio XS30. (They weren't out when I first started this thread!) They checked all the boxes I was looking for, and no question about output capability! It won't happen for a few months, but I'll reply in the official thread when I get them.
Thanks for the input everyone.
post #14 of 16 Old 12-04-2012, 10:04 PM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2714
If you haven't seen this...
you should
http://www.avsforum.com/t/1441673/2-x-passive-2011-jtr-captivators/0_20
Archaea is offline
post #15 of 16 Old 12-05-2012, 08:14 PM - Thread Starter
richard11's Avatar
Wow, great deal for someone there. Won't fit behind my screen. Or rather, they would make me push the screen too far into the room. Plus, I'm really intrigued with getting into the super low frequencies with sealed subs. Thanks for the heads up though.
post #16 of 16 Old 12-05-2012, 09:47 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I was in the same boat as you Richard; I ended up ordering dual XS30s last Sunday. Now the hard part, waiting!!!
jbrown15 is offline
