$400-500 sub recommendations for my home theater. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-12-2012, 06:47 AM - Thread Starter
JakeRobb's Avatar
I'm getting ready to set up a small movie-viewing room, and my subwoofer choice is still up in the air.
The room is L-shaped. The theater space is 16' x 11', with another 12' x 10' space to the right of the seating area, and a 4' hallway leading away at the front-right of the theater. 8' ceilings, so it works out to about 2600 cubic feet, not counting the hallway. I'll be using a 100" AT screen which may block a portion of the hallway when it's down. The room is in a walkout basement, so the majority of it is underground. Vinyl flooring over concrete and plaster-over-cinder-block walls means everything is very solid, but the room has noticeable reverb. I'll probably quell some of that with an area rug. It's a somewhat compromised arrangement, but it's the best I could do while staying in my budget and still keeping my wife happy. smile.gif
My current plan is that the rest of the speakers will be Ascend Acoustics -- CBM-170 fronts, CMT-340C center, and HTM-200 surrounds. Everything will be driven by a Denon AVR-2313CI.
I'm hoping to spend around $4-500 on subwoofer(s). In my living room, I have a BIC V1020 that I'm quite happy with, but I want to go a step beyond that for my movie room. I was thinking that a pair of F12s would be excellent (one on either side of the primary viewing area), but all of the recommendations I've found recommend a single sub at that price range, and nobody seems to consider recommending pairs. I want the most theater-authentic sound I can get for that price. As an added bonus, I think my wife would be more amenable to the idea of spending $200 on a sub, and then I can convince her that we need more and buy the second one once I point out what's missing. wink.gif
Thoughts, advice?
Living Room: Denon 2113ci + BIC V1020 + Panasonic BDT220 + AppleTV + uVerse DVR + Panasonic P42S2 plasma
Theater: Denon 2313ci + Klipsch RW12d + Panasonic BDT220 + Mac mini + uVerse wired receiver + Epson 8350 PJ + 100" screen
JakeRobb is offline
post #2 of 8 Old 11-12-2012, 07:23 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
The Hsu VTF2 is on sale right now for $518, although after shipping it is closer to $600. That will sound much better than a pair of BIC subs. Your planned speakers are deserving of a higher quality sub than budget subs anyway.
shadyJ is offline
post #3 of 8 Old 11-12-2012, 09:47 PM - Thread Starter
JakeRobb's Avatar
Believe me, I know I'm leaving a lot on the table at this price point. Someday down the road, I'm hoping there's a $1000+ sub in my future, like maybe the Rythmik Audio subs that Ascend recommends with their speakers. If things go well for me financially, maybe it'll be even better than that. The more I spend on the initial round, the harder it'll be to justify upgrading later. So, for now, I really want and need to stay under $500 shipped. Any other options I should consider?
JakeRobb is offline
post #4 of 8 Old 11-12-2012, 11:30 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Grab the Klipsch RW-12d next time it goes on sale for $299 at Newegg. Good sub for the money. You'll have trouble doing any better without spending over $500. Might like it enough to convince yourself to get a 2nd later on smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #5 of 8 Old 11-18-2012, 07:38 AM - Thread Starter
JakeRobb's Avatar
Okay, I've done a bunch of research, and I think the Klipsch is the right answer if I can get it at that price point. I've added a camelegg.com price alert for the Klipsch, and I'll buy it as soon as the price is right. Thanks!
JakeRobb is offline
post #6 of 8 Old 11-18-2012, 01:03 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
The new svs subs are hard to overlook at 499$
Brian Fineberg is offline
post #7 of 8 Old 11-18-2012, 08:28 PM
daninsd's Avatar
Quoted: 18 Post(s)
I just posted that the Polk PSW110 is on sale at Best Buy for $125. One of their best deals of the week, at least $50 cheaper than I've seen anywhere else. I compared it against a bunch of $500-$600 subs and they weren't that much better. Figured I'd give you the heads up since you mentioned the wife was hoping you'd find something under $200. If you end up liking it, that's worth its weight in gold!
Check out the reviews on Amazon. Overall, very well rated. Good luck!?
Sent from my cm_tenderloin using Tapatalk 2
daninsd is offline
post #8 of 8 Old 11-19-2012, 07:07 AM
lirong's Avatar
Quoted: 36 Post(s)
I wanted to hop onto this thread.
My Hsu STF-2 died on me and I need to buy a new sub.
Room dimensions are: 14' x 13.5' x 8' (1,512 cu. ft.).
Ive been reading these threads and have heard recommendations for some of the following: Rhythmik FV12, Outlaw LFM-1, HSU VTF-2, Epik Legend.
I also have seen some Klipsch recommendations. I tried out the SW-450 but dont know exactly where this fits compared to the other Klipsch subs. Is this a good alternative?
This will really only be for movies, not music. If it matters, I will be running it with a Denon 2112.
Id love any more guidance people have? Am I missing one I should consider? Does one of these stand out compared to the others?
lirong is offline
