New SVS SB1000 & PB1000 Subwoofers!! - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1261 of 1359 Old 09-22-2014, 09:12 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Originally Posted by jwtallguy View Post
Hey neutro, since we both have dual pc12s I was curious if you had any room measurement showing over 100 db sweeps ?
Looking for comparison to see if im getting the most I can out of mine
Not smart to play sine waves that loud.
fatbottom is offline
post #1262 of 1359 Old 09-22-2014, 10:16 AM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
why is that? A sweep from 10hz to 200hz through the lfe channel over 2.5 secs wont hurt a subwoofer just know the limits of your system and dont run a 20hz sine for more than 2 secs to be safe to protect the VC. But as far as a sweep at 100 db or more on subs that can output 115 db is almost a joke unless doing it continuously over and over.
How else does one check out how their systems for compression and output?
There are movies that are more dangerous to subs then a frequency sweep test and SVS subs are very well protected from high level output spikes so its more about keeping heat from destroying the voice coils which takes time to occur in this case.
jwtallguy is offline
post #1263 of 1359 Old 02-08-2015, 02:06 PM
Liked: 0
Hey guys. I ordered the PB-1000 but unfortunately they sent me the SB-1000. Now I don't really know wheter I should send it back for a change or just keep it. My room size is around 150 square feet. So a small room. I have the Audioengine A5+ speakers. I listen to music, watch movies and play games.
Which one is better in my room. I don't mean which one will be enough for my room but which one will be BETTER for my room? Better quality and so son. Ah and is the SB's bigger driver better than the PB's driver? So can the SB-1000 go lower in my room because of room gain and the bigger driver?
PS.: I don't set the volume to crazy high numbers. I don't have to shake my house
XHotSniperX is offline
post #1264 of 1359 Old 02-08-2015, 02:13 PM
fatbottom's Avatar
Liked: 518
In a small room, sealed box sounds better IMO. SB1000 and PB1000 driver and amp are the same, just one is sealed, one is ported. Watch movies and if you find it incapable with the loudest action soundtracks, change it.
I use a SBUltra 13 in a 900 cu foot room, which is smaller than yours hehehe
Were you charged for PB or SB? As PB is more expensive
post #1265 of 1359 Old 02-08-2015, 02:40 PM
Liked: 0
I paid for the PB-1000 but they cost the same 499. Am I right? And no the woofer is not the same. The SB-1000 has a 12'' woofer and the PB a 10'' woofer.
post #1266 of 1359 Old 02-08-2015, 02:48 PM
fatbottom's Avatar
Liked: 518
You're right I didn't know that, I thought both 1000's are 10", and PB is more expensive.
post #1267 of 1359 Old 02-08-2015, 03:07 PM
Liked: 0
So do you think the SB-1000 is the better one in my room? And maybe its bigger 12'' woofer is better than the PB's 10''. In a small room with very nice room gain the SB-1000 should be better don't you think so? Does anyone had both of the 1000's? I would really love to hear a comparison.
post #1268 of 1359 Old 02-08-2015, 03:21 PM
Montdj's Avatar
Quoted: 18 Post(s)
Ported vs Sealed is always a big question. The first thing I would ask is do you listen to music or movies more? IE witch one do you listen to the most.
IMHO out of the 2 the pb is going to be better for movies. It goes a little lower. The sb is going to be better if you listen to music more. Both are great subs and are real close to the way they perform.
I dont think room size matters in the sealed vs ported thing. Now thats just my 2 cents
MerrlinT likes this.
Montdj is offline
post #1269 of 1359 Old 02-08-2015, 03:38 PM
Montdj's Avatar
Quoted: 18 Post(s)
Here is a good read from SVS maybe this will help you decide.
http://www.svsound.com/t/sealed-vs-ported
Montdj is offline
post #1270 of 1359 Old 02-08-2015, 03:42 PM
Liked: 0
I think room size matters since the sealed benefits much more from small rooms than the ported does if I didn't missunderstand it. But I think the music and movie thing is correct. I will use the sub more with music than movies.
post #1271 of 1359 Old 02-08-2015, 03:44 PM
Liked: 0
I read it already hehe. Thanks anyway
post #1272 of 1359 Old 02-08-2015, 03:48 PM
Montdj's Avatar
Quoted: 18 Post(s)
Well what it comes down to is if you like the way it sounds and are happy well then that's all that really matters.
Try it out for a week or two watch everything you can and listen to all the albums you enjoy. If your unhappy then SVS will swap it for you and free shipping both ways!
Montdj is offline
post #1273 of 1359 Old 02-08-2015, 03:54 PM
fatbottom's Avatar
Liked: 518
I'd send the SB1000 and get dual SB Ultra 13's. It's only another $2500.
http://www.svsound.com/subwoofers/du...ual-sb13-ultra
post #1274 of 1359 Old 02-08-2015, 04:06 PM
Liked: 0
Hehe fatbottom you're funny Give me the money and I'll do that xD
I ordered the PB-1000 now and I will test them both myself.
post #1275 of 1359 Old 02-18-2015, 09:00 PM
Liked: 1
I'm about to buy an SVS PB1000!
I haven't got much space left for the sub.. i was thinking either here:
Would the couch be a problem? Or is it good to absorb the sound?
the other solution would be here next to the right tower but I'm afraid of the stairwell, i mean, im afraid it will bomb downstairs through that and also make vibrate the handrails (they vibrate only if u scream or clap ur hands basically...ahahhaha)
what should I do?
Egidio Concas is offline
post #1276 of 1359 Old 02-19-2015, 06:37 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
what should I do?
The thing with subs is, there is no right place to put them just by looking at photos. You have to try a few positions and see what sounds best, because every room is different. You can also look up the "sub crawl" method, which is an easy way to figure out the best place for your sub. However you also have to balance practicality, so try the sub in either area and leave it where it sounds best.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #1277 of 1359 Old 02-19-2015, 08:25 AM
TyTimp's Avatar
what should I do?
The couch won't be a problem. Having the sub fire into the couch will actually help shake the couch more. I have my PB-1000 facing one of my couches and that's the best seat to "feel" the bass.
TyTimp is offline
post #1278 of 1359 Old 02-19-2015, 10:26 AM
Liked: 1
thanks guys...
ultimately: i can't decide between jamo sub 660 and svs pb1000, 150€ difference, but is there a REAL audible difference? will the svs pb1000 give me more emotions???
EDIT: just ordered the pb1000, seller accepted my offer of 499€ including shipping i made yesterday and raised up the money for everyone else to 549€. I had to take it. Will I be satisfied?
post #1279 of 1359 Old 02-19-2015, 06:10 PM
Liked: 1
okay guys, i ordered the pb1000, can u please sudgest me a cool cable?
post #1280 of 1359 Old 02-19-2015, 06:38 PM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Any well shielded cable will do for a sub cable.
Some even use RG 6 Video cable with RCA ends.
Nashou
nashou66 is offline
post #1281 of 1359 Old 02-20-2015, 09:10 PM
Liked: 1
Nashou
i took this one, nice reviews, lots of people also adviced it: http://www.amazon.it/Oehlbach-20533-...pr_product_top
post #1282 of 1359 Old 02-21-2015, 11:20 PM
MIX_MASTER_ICE's Avatar
Quoted: 1221 Post(s)
Liked: 1005
Just a heads up for anybody considering the SB1000, SVS is closing out the SB12-NSD for $469.99. Slightly larger cabinet and 100w more powerful amp than the SB1000. It's a very nice sub for the money.
MIX_MASTER_ICE is offline
post #1283 of 1359 Old 02-22-2015, 10:19 PM
Quoted: 115 Post(s)
Liked: 6
Just got the SVS PB 1000 last week and I am loving it. I have read it required a break in period (is it 50 hours???) to perform to its full capacity. Awaiting for that sweet period as well!
Has anyone placed the subwoofer along with the cardboard that came with the packing on top & bottom of the woofer like I have placed. Not sure If i can post the image again as I just did in the show your woofer pic thread...
murlidher is online now
post #1284 of 1359 Old 02-28-2015, 01:28 PM
rbf1138's Avatar
Quoted: 64 Post(s)
Here with the now age-old PB or SB question!
Just got JBL Studio 530s, paired with a Marantz SR6008 in a stereo setup. My room is 22ft wide x 11ft front to back. From the speakers to me is about 8 feet. I'd prefer tight, precise bass that allows the speakers to perform their best vs. all-out volume of bass. I'm interested mostly for music but I do also play games/watch movies on my PS4 in this setup.
As far as listening levels, I'd say low to medium volumes are 80% of my listening times, including when we have guests or are entertaining at the house.
I'm leaning towards the SB-1000 but would there be any good argument here to go with the PB instead?
rbf1138 is offline
post #1285 of 1359 Old 02-28-2015, 01:34 PM
Ted Sheckler's Avatar
Quoted: 266 Post(s)
Liked: 185
PB1000 or 2000 for that size a room.
📺 Samsung (PN51F8500)
📻 Yamaha (RX-V475)
🎶 SVS (PRIME BS+CC)
🔊 SVS (PB-1000)
SVS (PC12-NSD)
🎮 PS4□Xbox One 2.5TB
Ted Sheckler is offline
post #1286 of 1359 Old 03-01-2015, 05:27 PM
rbf1138's Avatar
Quoted: 64 Post(s)
I'm really on a budget here, so going to the 2000 (of either the PB or SB, and still leaning SB) might be tough...also, would it be strange to have a more expensive subwoofer than the speakers it's paired with?
I'm thinking I should go with the SB-1000 for now, since it's mainly going to be used for music, and then I trade-up for the SB-2000 in the next year once I've lived with my system for a bit.
Additionally, I'm planning on picking up the "feet" they sell. Are those simple to install, with holes on the bottom of the sub already there so they just screw on?
rbf1138 is offline
post #1287 of 1359 Old 03-01-2015, 05:32 PM
fatbottom's Avatar
Liked: 518
Not really. A good sub costs a lot, more than speakers- as it has plate amp inside. Ie if you have £100 stereo speakers, I wouldn't buy a £100 subwoofer as it'll be low quality.
You don't want to buy a lower quality sub/lower output sub just because you're a bit skint, you will regret it, and you'll need to buy another, higher quality sub
22x11 isn't a small room SB1000 will be lost in there. I'd say PB1000 mininum, but ideally PB/PC 2000
post #1288 of 1359 Old 03-01-2015, 06:25 PM
Liked: 1005
If you can be a little patient, there will probably be some of the SB12-NSD subs pop up in the outlet. They just closed out that model for $469.99 and I'm sure there will be some come back. Your room is probably in the lower medium size range for subs, provided it isn't open to more areas. If it's a mostly isolated room, I think the SB12-NSD would do great in there.
Current subwoofer lineup: SVS PB12-NSD (x2), PC12-NSD (x2), RBH I-12/e Red Burl finish (x2), I-12 Red Burl Finish (x2), Jamo J-112 Dark Apple Finish (x2), Jamo J-12 Dark Apple Finish
post #1289 of 1359 Old 03-01-2015, 06:48 PM
rbf1138's Avatar
Quoted: 64 Post(s)
That's a great suggestion, thanks! I emailed them asking to be notified when one is back ready for sale, if they could set it aside for me.
rbf1138 is offline
post #1290 of 1359 Old 03-01-2015, 06:51 PM
Liked: 1005
Yeah, the SB12-NSD is a little larger than the SB1000 and it's amp is 100w more powerful. Their outlet subs carry their full 5 year warranty and 45 day return policy.
Also, just a matter of preference, but the SB/PB1000 models come with cloth grills. Personally, I prefer the metal grills that the SB/PB12-NSD come with. Obviously more costly on the part of SVS to include and ship a metal grill over a cloth one.
Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
