Does it matter where I place my sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-17-2012, 08:06 PM - Thread Starter
boe
boe's Avatar
Quoted: 945 Post(s)
Liked: 436
Hello,
I just purchased a sub but am having a hard time deciding on placement. I have a small room so I have very limited options. I can put it in the front right corner of the room (between a VERY large speaker and the HT cabinet) or the back left corner of the room behind a chair - there are absolutely no other options. Due to other items in the room and walking paths etc.
Does it matter much where it goes? Or is it likely to sound about the same either way?
boe is offline
post #2 of 9 Old 11-17-2012, 08:11 PM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
Place the sub in your primary listening position and do a sub crawl. This will let you locate the most ideal location(s) for your sub. If you're lucky, one of the two spots you have in mind will be one of those locations. If you're not lucky, at least you'll have some idea of how much less output to expect.
boe likes this.
eljaycanuck is offline
post #3 of 9 Old 11-17-2012, 08:19 PM - Thread Starter
boe
boe's Avatar
Quoted: 945 Post(s)
Liked: 436
Thanks, I don't know what a sub crawl is.
If I put it in my primary listening position, I think it will crush my legs smile.gif
boe is offline
post #4 of 9 Old 11-17-2012, 08:24 PM
Slingblayde's Avatar
Quoted: 14 Post(s)
Liked: 64
Sub Crawl is where you put the sub where you normally sit, and crawl around the room until you find a "sweet spot" of bass, then thats where you place the sub.
boe likes this.
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
post #5 of 9 Old 11-17-2012, 08:25 PM - Thread Starter
boe
boe's Avatar
Quoted: 945 Post(s)
Liked: 436
Originally Posted by Slingblayde View Post
Sub Crawl is where you put the sub where your normally sit, and crawl around the room until you find a "sweet spot" of bass, then thats where you place the sub.
Thanks for helping a newbie. I just finished watching this video http://www.youtube.com/watch?v=AV3oLLMgS-M
boe is offline
post #6 of 9 Old 11-17-2012, 08:29 PM
Liked: 1964
Place the sub in your primary listening position, at what would roughly be ear-level when you're seated there. Your legs will be safe, since you won't be there! smile.gif You'll be busy crawling around the perimeter of the room, listening to some low-frequency tones - or a track such as "Whoomp! (There It Is)" by Tag Team - and finding out which location offers (which locations offer) the best bass response. In an ideal situation, you'd then place the sub in that spot (or in one of those spots). In a less than ideal situation, you put it where you have to and hope for the best.
post #7 of 9 Old 11-18-2012, 09:28 PM
Skylinestar's Avatar
Quoted: 1214 Post(s)
Liked: 227
The best method is to run REW sweep and check the frequency response of your room.
Skylinestar is offline
post #8 of 9 Old 11-19-2012, 07:18 AM
ShaQBlogs's Avatar
Quoted: 27 Post(s)
ShaQBlogs is offline
post #9 of 9 Old 11-21-2012, 05:10 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
Originally Posted by ShaQBlogs View Post
here's a link for the crawl
I'm not sure how I'm going to lift the 140lb Plus/2 I have onto the sofa! biggrin.gif
MemX is offline
