Best setting for bic v1220 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-19-2012, 07:20 PM - Thread Starter
joe801's Avatar
Quoted: 118 Post(s)
Liked: 89
To any bic v1220 owners. What are your setting for your sub. Trying to figure out what phase 0-180 does.And whats best. And if setting it to dolby digital or 5.1,6.1,7.1 digital.
joe801 is offline
post #2 of 6 Old 01-07-2013, 05:44 AM
jonrwebb's Avatar
I have the same unit. I have the phase set to 0 and the receiver toggle set to 5.1, 6.1, 7.1. I think the receiver toggle sure turns on/off the subs crossover filter. As far as I know, my receiver is handling the crossover for me. What is your experience with your settings at this point?
jonrwebb is offline
post #3 of 6 Old 01-07-2013, 07:24 AM - Thread Starter
joe801's Avatar
Quoted: 118 Post(s)
Liked: 89
I have everything set up just like yours. My volume is set at 5. And my denon 1613 takes care of the rest.
joe801 is offline
post #4 of 6 Old 01-10-2013, 03:22 PM
kleankord's Avatar
From what I've read, once you set it to 5.1 6.1 7.1 then the receiver controls the sub and the settings on the unit itself don't matter, but I do have my volume set at 7.
kleankord is offline
post #5 of 6 Old 01-10-2013, 03:41 PM
skidog's Avatar
Liked: 27
I beleive you want to turn off the crossover or max it out on the sub itself then run your correction software.
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #6 of 6 Old 01-12-2013, 03:28 PM
Pete7874's Avatar
What is best will depend on how you have the sub set up in your environment. Typically, if you have the sub up front, 0 may work better, but not always. Switch it back and forth and see which one sounds better / produces more bass.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Pete7874 is offline
Bic Venturi Subwoofer V1220
