Gramma pads? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Gramma Pads?
Definitely noticeable, worth it 10 41.67%
Subtle difference or none at all 5 20.83%
Better off with DIY isolation 5 20.83%
Isolation not significantly important for sound 4 16.67%
Voters: 24. You may not vote on this poll
post #1 of 29 Old 11-20-2012, 05:46 PM - Thread Starter
spddy101's Avatar
I've just recently discovered "gramma" pads and I was wondering what people's experience has been with them. My bass has been very boomy/house shaking before and I've heard that this can help clear up the sound quality. What do you think? Are they worth the $50? (used with an Outlaw LFM-Plus)
spddy101 is offline
post #2 of 29 Old 11-20-2012, 08:13 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Maybe, but not likely. All they can do is prevent vibration of the floor, caused by its resonating in concert with the sub output, from being transferred back to the speaker cabinet. It will not stop the floor from vibrating. That cabinet vibration is not the source of boom, which is usually caused by room modes. Room mode fixes and other treatments are explained here:
http://www.realtraps.com/articles.htm
spddy101 likes this.
Bill Fitzmaurice is online now
post #3 of 29 Old 11-20-2012, 08:15 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Depends on your situation somewhat. What kind of floor do you have? More likely another reason than what the gramma will do for you.
lovinthehd is offline
post #4 of 29 Old 11-20-2012, 09:52 PM - Thread Starter
spddy101's Avatar
Floor is carpet over concrete. And Bill, thanks for the input, I was just surprised at how many people (via reviews and another AVS member) said that gramma made a very noticeable improvement in their sub sound.
spddy101 is offline
post #5 of 29 Old 11-21-2012, 06:52 AM
Liked: 4631
I'm amazed at how many say cables make a difference, but there again people have been known to recover from cancer when they were only taking placebo pills, so convincing them to hear what isn't there is a small task by comparison. One thing you'll notice about glowing reviews of dubious products is that they're never backed up by data. Not that pads don't do anything, they just don't do everything that's claimed. If they did there would be measured data on the Auralex site to back it up. They do have data on their room treatment products, and those products do work as advertised. If the Gramma and SubDude (it should be named SubDud rolleyes.gif) did what they claim it does it follows that they'd have data on that as well. There is a chart for the SubDude, but I can't for the life of me figure out what it's supposed to be measuring, and measuring speakers and room response is what I do for a living. This is what they say it does: 'Its purpose is to prevent sound from transmitting through your subwoofer to surrounding surfaces' and that's hogwash, pure and simple.
post #6 of 29 Old 11-21-2012, 08:53 AM
Glashub's Avatar
Quoted: 60 Post(s)
Liked: 167
I've used Gramma for years. I like my subs on the floor but wife swears the house vibrates much less.
Glashub is offline
post #7 of 29 Old 11-21-2012, 09:05 AM
Liked: 4631
Only because she saw the pads there. I've actually measured in room response and also response in the basement below the living room, with and without not only 6 inches of the same foam that Auralex uses but also spikes and rubber feet. No difference.
post #8 of 29 Old 11-21-2012, 09:35 AM
Glashub's Avatar
Quoted: 60 Post(s)
Liked: 167
That is interesting but I doubt that your measurements will sway my wife. smile.gif
Glashub is offline
post #9 of 29 Old 11-21-2012, 10:21 AM
Liked: 4631
So long as she thinks it's better it is better. That fact isn't lost on those who make and sell products that claim to do what they cannot. rolleyes.gif
post #10 of 29 Old 11-21-2012, 11:39 AM
leninGHOLA's Avatar
It will make pretty much zero difference if you're on a concrete slab. You should try a sub crawl instead. The LFM Plus shouldn't be boomy.
My sub isn't entirely inert, so my DIY solution did reduce transferred vibration in a top floor apartment setting. I think I spent $5.
leninGHOLA is offline
post #11 of 29 Old 11-21-2012, 11:45 AM - Thread Starter
spddy101's Avatar
And I also will be using my sub on carpet over suspended wood. And Bill, I think I will try and get one and do blind tests, if there's no difference, Amazon always has a great return policy biggrin.gif
spddy101 is offline
post #12 of 29 Old 11-21-2012, 11:45 AM - Thread Starter
spddy101's Avatar
What materials did you use?
spddy101 is offline
post #13 of 29 Old 11-21-2012, 01:14 PM
leninGHOLA's Avatar
We had some left over 3/4" MDF, acoustic dampening foam and carpet at work. All I did was buy some 3M spray adhesive and put it together.
If you had to buy it yourself, a 1/2" thick flat of MDF, 2 pieces of sturdy open cell foam, glue and a can of paint or carpet should do the trick. Maybe $20-25 worth of material.
It didn't change the acoustical properties of my sub, just reduced a little bit of rattling dishes.
post #14 of 29 Old 11-21-2012, 01:15 PM
Liked: 4631
That's the one instance where a pad can have a real effect, but of course the sub should be inert. If the panels vibrate energy that should be heard as sound is wasted vibrating the panels. Vibration also causes coloration, especially in the midbass and mids, as that's where most of the vibration will occur.
post #15 of 29 Old 11-21-2012, 01:22 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1561
I've just recently discovered "gramma" What do you think? Are they worth the $50?
You should have had another poll option: definitely noticeable, but not worth the $$ they charge. I love how the Gramma quiets down the things that rattle in my room, but for what it is they charge too much. They must make a nice profit on each of them.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #16 of 29 Old 11-21-2012, 01:25 PM
leninGHOLA's Avatar
It measures flat, I just wanted to be extra sure as at higher levels you can feel a tiny bit of vibration with your hand directly on it.
post #17 of 29 Old 11-21-2012, 01:46 PM
Liked: 4631
A tiny bit of vibration is no biggy, and means it's in the midrange, which isn't going to cause a floor to vibrate. Ideally a sub can be played at normal volume and a glass of water atop it won't move, but not all are built to that standard by any means.
post #18 of 29 Old 11-21-2012, 02:59 PM
leninGHOLA's Avatar
I'm usually not trying to play anywhere near reference anyway. More of a cheap and simple DIY precautionary measure for apartment living. I'd steer clear of the commercial offerings.
A little OT, but how many hours do you think an AutoTuba build would take for someone who had put together several transmission line style cabinets in the past?
post #19 of 29 Old 11-21-2012, 08:45 PM
Liked: 4631
Perhaps 16 hours, spread out over a few days for adhesive to set. Half that for the second one after you've figured out how to do it.
post #20 of 29 Old 11-22-2012, 03:49 PM
Troll
ufokillerz's Avatar
Liked: 47
these worked for me
i have my L/R speakers JTR Quintuples on Gramma Pads
my 2x Danley DTS-10 subs, each stand on 2 Gramma Pads
I have hardwood floors
previously i had a Partsexpress Titanic 15" sub, then 2x MFW-15s, the pads worked for all of them, i had so much damn rattling prior to the pads.
ufokillerz is offline
post #21 of 29 Old 12-15-2012, 03:10 AM
tlb48's Avatar
is this thread shutdown
tlb48 is offline
post #22 of 29 Old 01-19-2013, 08:42 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 195
I have a suspended wood floor in my apartment - one story, attached. When I lower my foot down, the floor goes boom. The SubDude made a BIG difference in the sound. The boominess was gone. The bass was tighter and I could turn up the amp level.
I'm glad I got one. (Now, if my floor was on concrete, I wouldn't have gotten/needed one.)
charmerci is online now
post #23 of 29 Old 01-19-2013, 08:47 PM
Liked: 4631
That's fine if you want to jump in your room without making a lot of noise. That's not how subwoofers and sound waves work. Argue all you want, science is always right, even if you don't believe in it.
post #24 of 29 Old 01-19-2013, 08:57 PM
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Have a suspended floor also and an LFM-1+ on a SubDude, I got it to try and stop the vibration going in through the floor and up into the sofa but it didn't really stop that, it reduced it slightly. About the same a thick piece of carpeting wood or some MDF.
Doubt it has any effect on sound quality, any differences you hear will be from it reducing the vibration of your floor / other crap.
BB1111 is offline
post #25 of 29 Old 01-20-2013, 10:00 PM
charmerci's Avatar
Quoted: 310 Post(s)
Liked: 195
Well yeah. Putting the sub on the Subdude stopped all the floor vibrations which muddied up the sound.
post #26 of 29 Old 01-21-2013, 06:35 PM
Archaea's Avatar
Quoted: 2843 Post(s)
Liked: 2425
I like my subs to splash my glass of water around on the table next to me. tongue.gif
In a different house I had a suspended floor and a kitchen table in the center of the that wooden floor. I had an DIY ottoman subwoofer setup I made with 4 car audio subwoofers and a couple thousand watts and that subwoofer setup actually would shake a heavy glass pitcher full of water and make it walk off the table. Another suspended floor house I lived in had a very small backyard with an in ground pool. The water in the backyard pool (about 8 foot from the back door) would actually ripple a bit due to the bass. Some folk like the tactile effect and crave more of it! Perhaps we have sensory deprivation!!! biggrin.gif
I'm most happy when I'm vibrating...
Archaea is online now
post #27 of 29 Old 01-21-2013, 07:08 PM
JimWilson's Avatar
Liked: 1561
That's not depravation Jonathan, that's depravity.
post #28 of 29 Old 01-22-2013, 04:45 PM
stitch1's Avatar
Quoted: 297 Post(s)
Liked: 236
I used one while living on the top floor of an apartment. Now that my theater is in the basement of my house I don't have any use for it.
stitch1 is offline
post #29 of 29 Old 01-22-2013, 06:06 PM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
I use SubDudes under each one of my four budget subs.
The thing I miss most using the pads, is that I no longer get that tactile sensation of bass energy,
rolling across the floor and up my legs.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
