Upgrade/Lateral Move from Tuba HT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 11-21-2012, 11:52 AM - Thread Starter
intangiblefatman's Avatar
I currently have a Tuba HT which I am very happy with, but with the recent addition of a spouse the 12 cubic foot plywood box in the room has become a bit of an issue. Can you guys direct me to a few subwoofers with higher WAF that would give comparable performance in small to medium sized rooms?
intangiblefatman is offline
post #2 of 22 Old 11-21-2012, 12:05 PM
BeeMan458's Avatar
Liked: 813
Do you have a budget? What's the size of the theater room? Is it a living room that has openings into a kitchen, entryway or dining room? How low are you wanting to go.
BeeMan458 is offline
post #3 of 22 Old 11-21-2012, 01:30 PM - Thread Starter
I don't have a set budget. I'm more curious what I would have to spend to get comparable performance to what I have now, which I am happy with.
Right now the room is roughly 12'x15'x10' and open on one side to the remainder of the 1000 sq. ft. apartment, but I will be moving within the year and then again a few years later when I graduate, so I unfortunately can't give dimensions for the sub's permanent home.
More or less flat to 20Hz is great.
post #4 of 22 Old 11-21-2012, 02:12 PM
leninGHOLA's Avatar
How hard do you drive the tuba?
leninGHOLA is offline
post #5 of 22 Old 11-21-2012, 02:34 PM - Thread Starter
Not too hard, I think. I find reference level uncomfortable and when the walls start to shake I turn things down to avoid bothering the neighbors too much.
post #6 of 22 Old 11-21-2012, 02:42 PM
BeeMan458's Avatar
Liked: 813
I need a budget or I'm just posting names for subwoofers with no relevancy to your needs and expectations.
Why not keep the Tuba HT? Just tell your new wife that she knew the Tuba came with the deal. tongue.gif
post #7 of 22 Old 11-21-2012, 03:10 PM
leninGHOLA's Avatar
Take a look at something like a Rhythmik FV15. You'd need a bit more to match something as efficient as a Tuba HT, but without knowing your budget, I don't feel comfortable going over $1500 with a suggestion.
post #8 of 22 Old 11-21-2012, 03:13 PM - Thread Starter
Fair enough. Lets say I spend $1000-1250 on say a Rythmic F15 will I be losing cleanliness relative to the Tuba? Would a cheaper sub like an Epik Empire be good enough? Do I need to spend more?
I think her asking that I upgrade my sub isn't a demand I want to take a stand on. wink.gif
Edit:
Thanks leninGHOLA, that's what I was looking for. I can go higher, up to maybe $2000 if it is necessary to keep my current performance.
post #9 of 22 Old 11-21-2012, 03:30 PM
leninGHOLA's Avatar
FV15HP would be closer and still under budget. An Empire wouldn't have nearly the output a Tuba HT would. Anything else I'd recommend would start to get into the large footprint area, again.
post #10 of 22 Old 11-21-2012, 03:41 PM - Thread Starter
A FV15HP is very doable. I'm not concerned so much about retaining the output of the Tuba - as I said, I don't like to listen particularly loudly - as I am interested in retaining the controlled, unbloated nature of the sound.
post #11 of 22 Old 11-21-2012, 04:07 PM
leninGHOLA's Avatar
The Rhythmik will play very flat and tight.
post #12 of 22 Old 11-21-2012, 04:20 PM
BeeMan458's Avatar
Liked: 813
Based on your above, a pair of delivered Hsu, ULS-15's would be a bit more then $2k with marks for high WAF. And if that recommendation is a budget problem, I'd step down a bit and recommend a pair of SVS, PB12-NSD's.
The above two recommendations are based on carefully comparing all available data I've been able to find and these two meet my criteria for the best in each of the above price categories.
Hope you find the above useful in your quest.
post #13 of 22 Old 11-21-2012, 04:27 PM - Thread Starter
Thanks a lot guys, you've been a big help.
post #14 of 22 Old 11-21-2012, 07:39 PM
Bill Fitzmaurice's Avatar
Liked: 5687
No direct radiator can approach the ultra low distortion of a horn, it's just not in their nature. This (and parts 2&3) explains why:
http://www.readresearch.co.uk/loudspeaker_papers/klipsch_modulation_distortion_article_1.pdf
And that doesn't even account for the enhanced low-pass function of folded horns, which further filter above bandwidth harmonics.
Bill Fitzmaurice is offline
post #15 of 22 Old 11-22-2012, 01:39 AM
BeeMan458's Avatar
Liked: 813
Then what's a guy to do when confronted by issues surrounding aesthetics as a big box like this is not going qualify as anything more than utilitarian. I'm not knocking the Tuba HT (which comes across as way cool), I'm just saying that being pretty matters as much as sounding good or being functional. Suggestions in that department.
Me, for perspective, as monies become available, I'm looking to a pair of Funk Audio, 18.0C's in which to solve our subwoofer needs. Yes, a whole lot more in the money department but if you want cool looking and quality, you'll have to hit the hip. Life really can be simple. And once again, no, I'm not knocking Tuba HT subwoofers in my above.
post #16 of 22 Old 11-22-2012, 05:43 AM
Liked: 5687
The same thing he does when making the choice between a Mazda Miata and an F350 super duty pickup. Pick the one that does what you most need it to do.
post #17 of 22 Old 11-22-2012, 07:47 AM
BeeMan458's Avatar
Liked: 813
Big difference between the two vehicles as you're asking the subwoofers to do the same thing, play down low where as a Miata and F-350 serve two completely different purposes. One does not consider a sports car when looking at a work vehicle and the equal and opposite, one does not look at work trucks when wanting a sports car. If I'm to take your comment in the literal sense, I'm to assume the Tuba HT is the pickup truck?
Out of respect, not knowing the history of the Tuba HT and being under the impression this is one of your touted babies by "Tweedpower," I was hoping you'd have a recommendation based on your vast experience. Based on my limited consumer based research and experience, with aesthetics and sound quality "the" consideration, my price/quality/performance path goes from, in pairs, the SVS, PB12-NSD > Hsu, ULS-15 > Funk Audio, 18.0 C. Yes, I understand neither of these are folded horn designs but all succeed in getting generous amounts of energy into the lower end (16Hz - 20Hz), maintain a relatively flat EQ curve and have a flat response on the right side of the EQ curve. In my opinion, all of which are very important consumer based criteria.
There's are many consumer based reasons I increased our budget from a pair of PB12-NSD's to a pair of Funk, 18.0 C's and yes, it was a tough row to hoe. The point, I can't expect another to come to the same conclusions.
post #18 of 22 Old 11-22-2012, 09:27 AM - Thread Starter
I suppose with the aesthetics and footprint of the sub being more important now that tradeoffs have to be made in places other than price. Unfortunate but that's life.
post #19 of 22 Old 11-22-2012, 10:31 AM
Liked: 5687
As do direct radiator and folded horn subs. The former are capable of shaking the room, the latter are capable of cracking the drywall. Not that you can't get a very good result from direct radiators, but it typically takes four times the driver count and amp wattage to do it, at which point the system size becomes equivalent, while direct radiators cannot get the low distortion of folded horns. So while you may be able to take multiple trips to the store in a Miata and carry the same amount of goods as an F350 you'll never fit a 4x8 sheet of plywood in one.
post #20 of 22 Old 11-22-2012, 10:48 AM
BeeMan458's Avatar
Liked: 813
Must be why, as soon as I put together the green, I'm considering a pair of Funk, 18.0 C's. biggrin.gif
post #21 of 22 Old 11-22-2012, 11:26 AM
Liked: 5687
That's not a sub. This is a sub:
http://www.danleysoundlabs.com/products/subwoofers/specialty-subs/dts-10/
post #22 of 22 Old 11-22-2012, 11:30 AM
BeeMan458's Avatar
Liked: 813
My wife is afraid I'll put my eye out with that thing.
