Rather Off Topic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-22-2012, 09:45 AM - Thread Starter
spyboy's Avatar
Liked: 48
Hi guys. What with the cold weather, my batteries seems to be fading on me. I have ever thing from alkaline to NIMH, NiCad, Lithium, mostly AA and AAA.
I have been unable to figure out how to discharge these batteries and don't like the idea of charging batteries that are only weak but not fully discharged.
Can anyone suggest a simple method for discharging these batteries?
I just hate it when I try to change channels on TV, change songs on my CD player, work with my DVD player, and the devices don't work properly because the batteries are weak.
Thanks In Advance, and Happy Thanksgiving to my many acquaintances on this Forum.
spyboy
spyboy is offline
post #2 of 3 Old 11-22-2012, 10:22 AM
Bill Fitzmaurice's Avatar
Liked: 5625
Don't bother. The issues with 'memory' applied to older NiCads, never to NiMH or Lithium. The newest NiCads don't even go dead in the drawer.
Bill Fitzmaurice is online now
post #3 of 3 Old 11-22-2012, 10:38 AM
BeeMan458's Avatar
Liked: 813
spyboy
Your Li-Ion batteries don't care about recharging as they don't have a memory affect to worry about. As to weak batteries, sometimes the problem can be solved by removing them and wiping both ends on your jeans a few times. This has the effect of removing a minute bit of invisible to the naked eye corrosion and in doing so allows what charge there is to more easily be transferred to the appliance being used.
Hope the above idea helps.
BeeMan458 is offline
