Polk PSW10 to Klipsch Sub-10 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-24-2012, 05:35 PM - Thread Starter
vextrum's Avatar
I am slowly upgrading my home theater system and I am looking to replace my old Polk PSW10 sub. Newegg appears to have a deal on a Klipsch Sub-10 and I'm wondering if this is a decent upgrade path. I currently have Polk Monitor 70s in the front, a Polk CS2 center, and Polk Monitor 30s in the rear. All of this will be driven by a Yamaha RX-V671 once it ships (it's replacing an Onkyo TX-SR505). Any help or advice would be appreciated.
vextrum is offline
post #2 of 9 Old 11-24-2012, 05:41 PM
XStanleyX's Avatar
Liked: 1269
What's the max you are willing to spend? We like to spend every last cent of your money.
XStanleyX is offline
post #3 of 9 Old 11-24-2012, 07:32 PM - Thread Starter
vextrum's Avatar
I'm pretty much in a budget price range of around 250 or less.
vextrum is offline
post #4 of 9 Old 11-24-2012, 07:35 PM
XStanleyX's Avatar
Liked: 1269
You'd be better off going with a Polk PSW505. They can be had for $200 when on sale. Much better than the one you're considering. Keep an eye on amazon and
newegg as they go on sale fairly often.
post #5 of 9 Old 11-24-2012, 08:52 PM - Thread Starter
vextrum's Avatar
I'll keep an eye out for them. The PSW10 just wasn't cutting it anymore. I was watching the expendables 2 last night and during all the scenes with explosions the sub was producing a lot of port noise/rattling noises. If I turn the sub down, you don't hear anything coming from it. After I replaced the front speakers (had monitor 50s before), the 70s seem to be out doing the sub. It's just time for a new one.
vextrum is offline
post #6 of 9 Old 11-24-2012, 09:22 PM
XStanleyX's Avatar
Liked: 1269
I use the same front three speakers as you for movies and the PSW505 will definately put out much more bass than the Monitor 70's.
post #7 of 9 Old 11-26-2012, 09:09 AM - Thread Starter
vextrum's Avatar
The PSW505 has dropped back down to $199 at both Amazon and Newegg. It was $250 at both during the last week and Black Friday. I'm going to pull the trigger, thanks for the help!
vextrum is offline
post #8 of 9 Old 11-26-2012, 09:16 AM
XStanleyX's Avatar
Liked: 1269
Good for you. You'll notice a big difference over the PSW10 sub. It's a great deal for the price.
post #9 of 9 Old 11-27-2012, 03:11 PM
vettefool's Avatar
I just upgraded from the polk psw 10 to the Klipsch RW-12d ( reading this forum is a sure way to spend money darn it) even though the little polk performed better than you would think, the Klipsch is quite a bit better. I've just got to run Audyssey.
vettefool is offline
