My BIC America f12 sub sounds like rubbish - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 11-25-2012, 06:01 PM - Thread Starter
notavailable's Avatar
Anytime I play music, the bass just sounds horrible. 90% of the time, it seriously just sounds like rattle. Is there something wrong with the sub, or am I not setting things up properly? My receiver is a yamaha rx-v371, and I'm playing the music off my laptop via hdmi
Thanks in advanced
notavailable is offline
post #2 of 45 Old 11-25-2012, 06:18 PM
Quoted: 311 Post(s)
Liked: 43
Well, its a budget sub, u cant expect it to have deep bass like the REAL subwoofers have (SVS, HSU etc )
lamonsasa is offline
post #3 of 45 Old 11-25-2012, 06:36 PM - Thread Starter
Is there anyway I can adjust the receiver so it doesn't rattle though?
I'm a complete noob at this..
post #4 of 45 Old 11-25-2012, 07:04 PM
kcnitro07's Avatar
Quoted: 12 Post(s)
Take the front grill off. mine used to rattle with the grille on.
kcnitro07 is offline
post #5 of 45 Old 11-25-2012, 07:07 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
It's such a nice lookiung sub that I took the covers off and placed them in storage when I had them.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #6 of 45 Old 11-25-2012, 07:09 PM
Quoted: 311 Post(s)
Liked: 43
post #7 of 45 Old 11-25-2012, 07:12 PM - Thread Starter
The grille is off...
post #8 of 45 Old 11-25-2012, 07:13 PM
kcnitro07's Avatar
Quoted: 12 Post(s)
What kind of "rattle" is it? Sure it is coming from the sub?
post #9 of 45 Old 11-25-2012, 07:17 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I can't imagine what could be rattling. Mine were built like tanks.
AVR: Denon X2200W
Prime316 is offline
post #10 of 45 Old 11-25-2012, 08:30 PM
bradymartin's Avatar
Quoted: 33 Post(s)
mine doesnt rattle either. how did you set it up? phase, crossover, gain etc.? maybe something went into the port? my nephew threw a fking marble in there. caused rattle and i had to fish it out. try shaking the sub after you unplug and see if you hear anything in there.
bradymartin is offline
post #11 of 45 Old 11-25-2012, 11:43 PM - Thread Starter
shook the whole thing around, nothing
How should my phase, cross over, gain be?
I just keep the gain low so i dont hear the rattle
post #12 of 45 Old 11-26-2012, 01:46 AM - Thread Starter
I notice it on a the low notes of songs. For exmaple, at higher notes, bass sounds excellent. But soon as it goes lower than a certain point, the bass just sounds like rattling. I'm using rattling for lack of better terms, it could be distortion? But I'm positive it only sounds like its rattling below certain low notes.
post #13 of 45 Old 11-26-2012, 02:25 AM
Theresa's Avatar
Liked: 51
As said above, you get what you pay for. This might sound harsh, if so I'm sorry.
Theresa is offline
post #14 of 45 Old 11-26-2012, 07:49 AM
Kini62's Avatar
Quoted: 1722 Post(s)
Liked: 1538
If it rattles when played then it is broken. Send it back.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #15 of 45 Old 11-26-2012, 08:16 AM
GrooveRite's Avatar
I'm looking to pick this sub (Bic Amer. f12) up or the Polk PSW505. Which of these two subs would you guys go with?? I know, I know...they are budget subs. I'm looking for a quick fix until I get my REAL sub biggrin.gif. Besides, one of these budget subs should be fine in my bedroom once I get my powerful, earth shattering sub!
Gamertag: BaneAssassin
PSN: BaneAssassin
GrooveRite is offline
post #16 of 45 Old 11-26-2012, 12:10 PM
Bond 007's Avatar
Quoted: 2625 Post(s)
Liked: 2088
F12
Transmaniacon likes this.
Licence to Kill
Bond 007 is offline
post #17 of 45 Old 11-26-2012, 12:37 PM
wpbpete's Avatar
Quoted: 113 Post(s)
Liked: 99
Take it back, if replacing it is not an option, make sure all the screws are tight on the woofer, the amp, the feet.Try placing it at a different location, it may be something near it that's rattling. If not, then check the gain level of your receiver, it may be set too high. does it happen at low volume?
wpbpete is offline
post #18 of 45 Old 11-26-2012, 01:11 PM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
Yes I agree that you need to have it replaced. I have the F-12 and have never heard any rattling or distortion, even in strenuous movies like War of the Worlds.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #19 of 45 Old 11-26-2012, 06:27 PM - Thread Starter
Yes, this happens at low volume as well.
post #20 of 45 Old 11-26-2012, 06:41 PM - Thread Starter
If I ordered through Amazon, I need to go through them to exchange, correct?
post #21 of 45 Old 11-26-2012, 06:42 PM
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
Really? Your best advice is you get what you pay for???
I own a BIC F12 as well as 2 Ultra 5400's and I can tell you that the F12 doesn't make a rattle sound even at the lowest frequencies although it doesn't have a lot of output down there either.
What are you listening to when its making this rattle?
Shan87 is offline
post #22 of 45 Old 11-26-2012, 06:51 PM - Thread Starter
It can be anything from house music to r&b.
I recorded the sub just now, and finally heard what it really sounds like since my music drowned out most of the rattle. Mother of god, annoying as hell.
Already sent an email to amazon for an exchange.
post #23 of 45 Old 11-26-2012, 06:54 PM - Thread Starter
In all her glory, click to play
post #24 of 45 Old 11-26-2012, 07:35 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
As i was trying to say before the site went down or whatever happened.........Amazon has an amazing return program. I ended up returning my Bic F-12's because I needed something more. I printed off the return label from my order history, put the subs back into their boxes, attached the return auth form and dropped it off at a local ups store. I believe i did this on a Monday and by Tuesday I had an email from Amazon stating they would be returning my money.......minus shipping of course. They didn't even get the subs back until that Wednesday.
In your case, they should refund all of your money if you are returning the item since the item is defective. Not sure about how returns work. I guess they would send you out another once they get the return but I would say give them a call. They will probably send you another one at the same time you're returning the defective one.
spddy101 likes this.
AVR: Denon X2200W
Prime316 is offline
post #25 of 45 Old 11-26-2012, 07:43 PM
Liked: 1394
Yes that F-12 is clearly defective, I am confident when it is replaced you will be pleased with it.
post #26 of 45 Old 11-26-2012, 07:47 PM
Auditor55's Avatar
And not very helpful.
likemovies likes this.
Auditor55 is offline
post #27 of 45 Old 11-26-2012, 07:52 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Yeah, telling someone you get what you pay for isn't cool at all in this situation. Not everyone can afford an expensive sub and others just don't want to pay a lot for a sub. No matter what it is, if you paid your money for it, it should work properly.
AVR: Denon X2200W
Prime316 is offline
post #28 of 45 Old 11-26-2012, 08:06 PM
XStanleyX's Avatar
Liked: 1270
Wow, that sub really sounds messed up. I returned a defective sub to amazon. No problem. They sent a UPS truck to my house and picked it up. The driver had a pre-made shipping label. They credited my debit card the full amount two days later.
Didn't have to pay a nickel.
XStanleyX is offline
post #29 of 45 Old 11-26-2012, 08:36 PM
capricorn kid's Avatar
Liked: 25
Wow...that really does not sound good at all. Clearly there is something wrong with it. As far as the silly comment you get what you paid for....I got 2 BIC PL200s. I think they are about a step up from the F-12 and I have had no issues at all with them. I got them for $300 each. When you sent it back see if you can upgrade to the PL-200. It looks just like the F-12 but just a little stronger.
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
120" 16:9 screen
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #30 of 45 Old 11-26-2012, 08:56 PM
Bond 007's Avatar
Liked: 2088
That was a stupid comment. Like if you "only" pay $200 you should expect it to rattle.
Licence to Kill
Bond 007 is offline
Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer , Yamaha Rx V371bl 5 1 Channel Av Receiver
