Bass localization: The Old Debate - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 11-28-2012, 07:11 AM
J_Palmer_Cass's Avatar
Quoted: 394 Post(s)
Liked: 118
Originally Posted by Steve1981 View Post
Originally Posted by arande2 View Post
I can't easily vary my subwoofer setup in my own room (plus there would be a large time gap between A/B'ing).
How quick does the switch need to be? I'd think with most newer receivers, changing the XO frequency would take a couple seconds max.
Once I am on the AVR's crossover screen, the change from one crossover frequency to the next one is near instantaneous. I change frequencies while listening to music to evaluate the sound quality at various crossover frequencies. I do the same thing with single frequency test tones to evaluate what various bass frequencies can be located with various crossover settings.
I can not locate 50 Hz, but by 80 Hz you can easily locate the source of the 80 Hz assuming you have a stereo bass setup (AKA two speakers or subwoofers setup for stereo). A test to locate bass with the use of a single subwoofer as a source of bass is a different test.
J_Palmer_Cass is offline
post #32 of 38 Old 11-28-2012, 10:26 AM
Super Moderator
markrubin's Avatar
Quoted: 1272 Post(s)
Liked: 2772
nothing to add?
please hit unsubscribe
posts deleted
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #33 of 38 Old 11-28-2012, 10:55 AM
bfreedma's Avatar
Liked: 51
Originally Posted by BeeMan458 View Post
I see you thoughtfully missed my obvious point completely. The missed point, just because people of authority say it can't be done, doesn't mean, it can't be done. To move knowledge forward, one must learn to not listen to people telling them it can't be done.
All things that are known, have been learned. All things that are not known, have yet to be learned. The point, encourage the OP with your expertise, don't discourage him with your expertise.
"Jonathan Livingston Seagull"
Conversely, some things have been tested extensively enough to know what will work and what won't. If you personally want to reject known science, go for it, but I'm not jumping off any buildings in the hope that we're wrong about gravity being a constant.
Bass localization is based validated science - no need to rebuild that wheel.
bfreedma is offline
post #34 of 38 Old 11-29-2012, 08:08 AM
localhost127's Avatar
Quoted: 32 Post(s)
Liked: 72
Originally Posted by Bill Fitzmaurice View Post
Probably. An RTA might reveal what's going on.
CSD/waterfall would likely provide a clearly indication of a resonance...
localhost127 is offline
post #35 of 38 Old 11-29-2012, 08:54 AM
BeeMan458's Avatar
Liked: 813
It has nothing to do with rejecting proven science. It's about encouraging the learning process by taking a few steps back, encourage the challenging of "proven" science (learning) and then moving forward again and if that means jumping off a few building in the process, then yes, by all means, do.
"Parkour and FreeRunning"
BeeMan458 is offline
post #36 of 38 Old 11-29-2012, 09:58 AM
Bill Fitzmaurice's Avatar
Liked: 5684
In this case it's more an issue of ignorance of the proven science. Those most likely to argue over the validity of proven science tend to be those who don't understand it. Arguing about that which you do not understand is time wasted; learning about that which you do not understand is time well spent.
Bill Fitzmaurice is offline
post #37 of 38 Old 11-29-2012, 01:33 PM
Liked: 5684
I'm not sure saying that the OP is ignorant of the proven science is entirely fair. Putting aside from some of the language he decided to use, ie "denouncing studies", he's made observations contrary to what he believes he should be experiencing based on his understanding of the science. .
Perhaps, but it's not the science that's lacking, it's his knowledge of it. That's an easily cured condition, far easier than repeating fifty odd years of research that's already been done.
post #38 of 38 Old 11-29-2012, 01:53 PM
BeeMan458's Avatar
Liked: 813
Stating the obvious, learning is a curve. It's easy because you know this stuff. I learned late, the folks I speak to don't have my background so I have to drop back about thirty years and start forward as if an entry level discussion. I speak as if the person is clueless and build from there. It's about the inexperienced individual, not the experienced person. Without someone to listen, the person doing the sharing is doing so to entertain themselves. It's not about ego, it's about showing the individual the path and then getting out of their way. Some people understand these points, others don't. I'm old, not my worry.
My sharing formula, I find out what the individual doesn't know, then I start moving forward from their state of awareness, not from mine. Philosophically, it's incumbent on the seeing to teach the blind, not the other way around.
