Klipsch RW-12D - Silly noob question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-27-2012, 03:35 PM - Thread Starter
123
123's Avatar
Hi guys,
My AVR has a single RCA jack for the subwoofer, while the subwoofer has L and R channel RCA jacks. I went ahead and bought a splitter, but have noticed that it looks like the setup figure in the instructions seems to indicate to use a single M-M RCA cord to connect the AVR to just one (can't remember from memory which one in particular) of the channels on the subwoofer. What is the best way to make the connection?
123 is offline
post #2 of 11 Old 11-27-2012, 03:37 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
The owner's manual (third page, IIRC) says you can connect to L, R or both:
RW-10d / RW-12d / RSW-10d
“LINE IN” - ... Connect to the “RIGHT” and/or “LEFT/LFE” inputs on the subwoofer’s rear panel ...
eljaycanuck is offline
post #3 of 11 Old 11-27-2012, 03:42 PM
hermeslyre's Avatar
By using the Y splitter, you are gaining about 3db in extra output. That's all. Either way is fine. The Y-splitter shouldn't effect sound quality either.
hermeslyre is offline
post #4 of 11 Old 11-27-2012, 03:47 PM
BeeMan458's Avatar
Liked: 813
You should check with Klipsch customer service as they told me when asking other questions to hook up to either RCA jack but not to both as running the sub hot, causes problems that can burn things out.
BeeMan458 is offline
post #5 of 11 Old 11-27-2012, 03:49 PM - Thread Starter
123
123's Avatar
Ok great. I'll go ahead and use the Y-splitter. Thanks guys.
Eljaycanuck, interestingly enough, that critical sentence was missing from my Manual. Or perhaps I missed it. Who knows.
123 is offline
post #6 of 11 Old 11-27-2012, 03:50 PM - Thread Starter
123
123's Avatar
That's very odd. Why would they include both jacks then? As an aside, I hooked up my dad's RW-10d about 2 years ago with a Y splitter and it seems to be working just fine.
123 is offline
post #7 of 11 Old 11-27-2012, 03:52 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Just to clarify, you don't get more "output", you get more input signal. The sub will sum the 2 inputs and you'll 3 dB more input signal. This will change the output at any given gain control setting. However, the maximum output of the sub will be unchanged.
One other benefit is that it takes less signal to activate the Auto-On feature.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #8 of 11 Old 11-27-2012, 03:57 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Klipsch CS was wrong. It won't hurt anything. Just be sure the subwoofer trim setting in the receiver is 0 or a negative number and you'll be fine.
Craig
Lombardi said it:
My System
post #9 of 11 Old 11-27-2012, 03:57 PM
hermeslyre's Avatar
Craig
I knew it simply increased input voltage, but didn't actually know the rest. You've refined my knowledge banks, good sir.
post #10 of 11 Old 11-27-2012, 03:58 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Lombardi said it:
My System
post #11 of 11 Old 11-27-2012, 04:00 PM
BeeMan458's Avatar
Liked: 813
I can't say the why of anything as that's the warning they gave me and why I suggest giving customer service a call. It never hurts to call and check but it can hurt to not call and not check. Just sharing as it's no biggie to pick up the phone and give customer service a call. It could be that it's just for my sub and no other sub as our Klipsch subs (SW12-II's) are some eighteen years old and this warning is only valid for our subs.
Klipsch Rw 12d 12 Subwoofer Each
