Can avsforum recommend a decent 10-inch sub for my HT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 11-29-2012, 09:08 AM - Thread Starter
antoraj12's Avatar
Guys,
Can you recommend a decent 10-inch sub for my new HT setup?
I've the HTD level-3 bookshelves and a center channel and a denon 2113ci.
I received my BIC F12 and Aurolex subdude and F12 is way too large for my room and also doesn't fit in the subdude.
So thinking of returning the F12 and getting a decent 8 or 10 inch sub.
The room is 15*12 apartment and i don't like the rumbling or window shattering sounds. Am just looking a sub that can go well with music and play some decent effects for movies.
budget is ~$200 to ~$250
Thanks much in advance !
antoraj12 is offline
post #2 of 21 Old 11-29-2012, 10:19 AM
leninGHOLA's Avatar
Hsu STF-1 or Outlaw M8.
leninGHOLA is offline
post #3 of 21 Old 11-29-2012, 12:10 PM - Thread Starter
antoraj12's Avatar
Thanks for the suggestion.
I've never connected a subwoofer before. I bought a subwoofer cable from amazon and how do i connect my receiver to outlaw m8?
I looked at the backside of m8 and not too sure where to plug-in the subwoofer cable.
post #4 of 21 Old 11-29-2012, 12:16 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Based on this pic, I'd say the left ("mono") input. And you'd set the crossover switch to "bypass".
-- Edit --
Page 5 of the owner's manual (PDF) confirms it.
eljaycanuck is offline
post #5 of 21 Old 11-29-2012, 01:19 PM - Thread Starter
antoraj12's Avatar
How do you compare Outlaw M8 with BIC F12?
F12 looks huge and goes down to 25 HZ. Weigh 42 ls. They have 5 yr warranty on the parts. ($199 incl shipping)
M8 is definitely more compact than F12 and goes down to 29 HZ. Weigh ~26 lbs. I think they provide 3 yrs warranty. ($281 incl shipping)
HSU STF-1 is like M8, but goes down only to 32 HZ. Weigh 30 lbs. They have 7 yr warranty. ($334 incl shipping)
I've been listening to TV speakers all my life and i really don't know what i'll be missing if my sub doesn't go below 30 or 32 hz.
Do you guys think M8 is still a good choice over the other for that price range or is STF-1 a better value for it's extended warranty?
btw, all i do with my HT is listen to soft melodies music\instrumental and watch movies occasionally.
post #6 of 21 Old 11-29-2012, 01:39 PM
leninGHOLA's Avatar
The STF-1 will go down to 29hz with a +/- 3dB window. Hsu lists it as 32hz in a +/- 2dB window, which is more prescise than anyone else lists specs. TheF12 can only be said to hit ~28hz within a +/- 3dB window when measured accurately. It would just have more output than the other 2.
The differences between the M8 and STF-1 are slight, as they were both designed the same way. Outlaw contracted Dr. Hsu for consultation on the design of the M8. The STF-1 will have slightly more amplifier power and slightly more weight to it. Otherwise, they are pretty close. Both are good for their price class.
post #7 of 21 Old 11-29-2012, 01:57 PM - Thread Starter
antoraj12's Avatar
So in terms of going low, there isn't much difference between STF-1 and F12.
Any reason why a 8 inch STF-1 would be $100 more than 12 inch F12?
post #8 of 21 Old 11-29-2012, 02:22 PM
leninGHOLA's Avatar
Sound quality and design. Hsu and Outlaw subs tend to measure better than commercial offerings in their price brackets. The BIC will certainly play louder, but it is not as accurate. More accurate subs will be better for music.
post #9 of 21 Old 11-30-2012, 09:38 AM - Thread Starter
antoraj12's Avatar
HSU STF-1 vs BIC V1020 (just $145 including shipping!)
How is V1020 compare with STF-1?
Any suggestions guys?
Which one of these is less boomy and more musical and apartment friendly ?
post #10 of 21 Old 11-30-2012, 10:27 AM
Bond 007's Avatar
Quoted: 2664 Post(s)
Liked: 2116
STF-1 is all of those. But if you want real bass spend the extra $50 and get the Bic F12. You can always turn it down if it is too much. You may be disappointed with the other 2. What kind of sub do you have now?
Licence to Kill
Bond 007 is online now
post #11 of 21 Old 11-30-2012, 10:39 AM
leninGHOLA's Avatar
post #12 of 21 Old 11-30-2012, 11:07 AM - Thread Starter
antoraj12's Avatar
I received the BIC F12 a couple of days back and it looks like it's way too big for my living room (apartment). I am still waiting for my receiver and not set anything up yet. Just the sheer size of the sub scared me and my family mad.gif
Thinking of returning this and getting a smaller one (8 or 10 inch) which will best fit my living room and my apartment and also something that will give me a decent low end. I really don't care if my sub doesn't go below 25 hz because as I said earlier, this is my first HT setup and I've been listening to TV speakers till now .. So any decent sub will be a big upgrade for me .. my only concern is the sub should not be boomy at all. I am willing to up the budget to ~$300 to get a good non-boomy, musical sub.
post #13 of 21 Old 11-30-2012, 11:11 AM
Liked: 1964
If you can up the budget to $499, order an SVS SB-1000 today:
- 12" driver
- 300W RMS amp
- 24-260Hz +/-3dB
- 13" x 13" x 13"
- 27lbs.
SVS always includes delivery shipping, but their sale - which ends today - includes free return shipping. This means you can buy and try the sub, and if you don't like it, it will end up costing you $0.
post #14 of 21 Old 11-30-2012, 11:30 AM - Thread Starter
antoraj12's Avatar
- 12" driver
- 300W RMS amp
- 24-260Hz +/-3dB
- 13" x 13" x 13"
- 27lbs.
- 13" x 13" x 13" is definitely compact for a 12 inch. But $500 is a bit overkill for me and unfortunately ~$300 will be the max that i can spend on a sub right now
post #15 of 21 Old 11-30-2012, 11:33 AM
leninGHOLA's Avatar
An Energy S 10.3 would be great if you can get one for under $200. They are discontinued, so a little digging around might be needed.
post #16 of 21 Old 11-30-2012, 11:38 AM - Thread Starter
antoraj12's Avatar
I am leaning towards HUS STF-1.
But has anyone here used BIC V1020? - It has got some decent reviews and it's less than $150 right now.
post #17 of 21 Old 11-30-2012, 01:16 PM
Bond 007's Avatar
Liked: 2116
I dug like a madman for the S10.3 before I got the RW12. Very difficult to find and the cheapest was $350.
Licence to Kill
post #18 of 21 Old 11-30-2012, 02:00 PM - Thread Starter
antoraj12's Avatar
Will Subdude help reduce vibrations on a front-firing subwoofer or is it only helpful for a down-firing one?
post #19 of 21 Old 11-30-2012, 02:12 PM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
I would go for the HSU-STF1 and keep your subdude.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #20 of 21 Old 11-30-2012, 04:20 PM
Bond 007's Avatar
Liked: 2116
Some people say those Subdudes are great and some say a waste of money but the type of sub doesn't matter.
Licence to Kill
post #21 of 21 Old 12-07-2012, 09:03 AM - Thread Starter
antoraj12's Avatar
I finally received my HSU STF-1 and the Aurolex Subdude.
Will let you guys know how it works after I set everything up this weekend.
Thank you for all your valuable suggestions wink.gif !
