Def Tech Supercube 4000 VS Martin Logan Dynamo 700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-29-2012, 07:11 PM - Thread Starter
Dysmae's Avatar
Good evening, I am looking to expand in the subwoofer category and I have the opportunity to get great pricing on either of these subs. I currently have a Klipsch XW-300D, which is a great little sub. It is a sealed enclosure which I tend to favor over vented subs(I like fast, clean and tight subs over loud and boomy subs). The Martin Logan is a sealed sub while the Def Tech has the two passive radiators. The Def Tech can go to lower depths, however. I have listened to both subs in big box stores, but you can never really get a great impression from a store since they usually crank them up to obnoxious levels. Whatever sub I get, I will be eventually buying two of them. So, what are your impressions of these subs? I actually would be interested in buying another Klipsch XW-300D but they are long discontinued. Any help would be most appreciated.
Dysmae is offline
post #2 of 3 Old 11-30-2012, 09:43 AM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
Well, first the Def Tech subs don't really play as low or even close to the rated specs. I have the SC8000 corner loaded in a 1650 cubic foot sealed room and for the most part is plenty for my needs.
As for the SC4000 and ML 700, if pricing were the same I would go for the SC just for the remote which is very handy. I would thing output would be similar although the ML might actually dig a little deeper.
My Def Tech is nice and tight for music at least IMO.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #3 of 3 Old 11-30-2012, 11:46 AM - Thread Starter
Dysmae's Avatar
From what I heard, the SC4000 did sound pretty tight. Not as boomy as I thought it was going to sound. Yeah I always wondered how it was possible for the supercube to get down to 16hz with an 8 inch driver. Thank you for the feedback!
Dysmae is offline
