sony mhc-rg33/subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-01-2012, 12:41 PM - Thread Starter
zipperz5's Avatar
Hello.
I have sony mhc-rg33 connected to pc.
Friend gave me his active sub with impedance: 3 ohms (lg_s52a1-d)
I can't connect it to my sony music center (http://pdf.crse.com/manuals/4239873121.pdf), how can i use it with pc. The problem is it has just a pin input (no RCA) - http://clip2net.com/s/2yMjO
Any solutions?
zipperz5 is offline
post #2 of 5 Old 12-03-2012, 08:13 AM - Thread Starter
zipperz5's Avatar
Can someone tell me thee name of the cable in picture?
zipperz5 is offline
post #3 of 5 Old 12-03-2012, 08:24 AM
Bill Fitzmaurice's Avatar
Liked: 4661
That's not a standard configuration audio cable. Chances are your Sony system, like many all-in-one systems, cannot be used with outboard components.
Bill Fitzmaurice is online now
post #4 of 5 Old 12-06-2012, 01:37 PM - Thread Starter
zipperz5's Avatar
But i can use it with pc, just use 2 out sources: sony center 1st and 2nd the sub with wierd cable.
zipperz5 is offline
post #5 of 5 Old 03-10-2013, 05:04 AM - Thread Starter
zipperz5's Avatar
Can I maybe solder 3.5mm wire and connect it to PC, it has build in amplifier, I guess it doesn't need pre-amplefier? Connector has +/- wire, so it could work right?
zipperz5 is offline
