Y'ing a sub from different sources? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-02-2012, 03:30 PM - Thread Starter
Eric_Connelly's Avatar
Quoted: 97 Post(s)
Liked: 36
I have a Outlaw Audio ICBM along with a Yamaha RX-A1000.
When we listen to DVD-A/CD/SACD I play through the multi-channel/ICBM.
However for some reason the RX-A does not pass the LFE channel out. If I move the sub from the RX-A to the LFE Out on the ICBM things area great.
But it needs to be in the RX-A for BD and regular TV.
Is it a problem to Y the outputs into a single sub?
I'd run one from the LFE channel on the RX-A and one from the ICBM.
Any reason not to do that?
Eric_Connelly is offline
post #2 of 3 Old 12-02-2012, 05:23 PM
eljaycanuck's Avatar
Quoted: 1233 Post(s)
Liked: 1805
Is the "Recombine" switch on the back of the ICBM set to "off"?
eljaycanuck is offline
post #3 of 3 Old 12-03-2012, 08:54 AM
oldschool4life's Avatar
Do not combine two sources to one amplifier via a "Y" cable. Use some kind of source selector or manually swap cables.
Originally Posted by oink
Mr. Cialella is, without question, the AVS honorary MOST ADMIRED PERSON OF THE YEAR.:D
oldschool4life is offline
