XLR Splitter Issues - AVS Forum | Home Theater Discussions And Reviews
Old 12-02-2012, 03:51 PM - Thread Starter
intangiblefatman's Avatar
Thank you everyone who helped me in my thread a few weeks ago. I decided to cut my budget and bought a pair of Epik Legends when they were on sale. Now I've run into an issue getting them hooked up.
At the moment, I am running the subwoofer output from my receiver into a Behringer FBQ2496. The output of the FBQ is split using an XLR splitter (http://www.amazon.com/gp/product/B000068O59/ref=oh_details_o01_s00_i00) into the inputs for the two subs. Unfortunately, this results in the input signal to the sub being incredibly weak. I can turn off the mains and get decent measurements, but even with the mains set 20dB below the subwoofer on the receiver and the subs' volume controls turned all the way up, the subs are too weak.
Unhooking one of the subs from the splitter results in dramatically increased volume from the sub left attached. This appears to be related to the additional wire coming off the splitter, though, as the unused sub must be unhooked at the splitter not the subwoofer itself. I have never observed this behavior with a splitter before, although I have only used RCA splitters before. Is this a quirk of the balanced cables?
My first thought would be to put the splitter in between the receiver and the FBQ, using a channel per sub, but unfortunately only one of the channels on my FBQ is functional. Does anyone have any other suggestions?
Edit:
Well, switched over to RCA sooner and used an RCA splitter I forgot I owned which solves the volume issue. I suppose the issue is with the splitter I own.
intangiblefatman is offline
Old 12-02-2012, 07:31 PM
Bill Fitzmaurice's Avatar
Liked: 4891
Probably a short in that cable.
Bill Fitzmaurice is offline
